Finally got some very crappy random pics of my car, its dirty and the photos speak for my photography skills..hahaha.
I have had the car for a while now alittle over 6mo. My goals for this car is to build it from the ground up. Its no track car mainly a toy with performance in mind but I have learned from past projects to build it right the first time.
Here's what I have done so far:
All the normal maint. has been preformed. belts, plugs, seals, valve adj, blah blah trans fluid, diff fluid... radiator, hoses. you get the point!
..................................ENGINE.......... ............
8mm plug wires
Aem dry flow hot air intake
.................................DRIVETRAIN....... ........
4.10lsd
5 speed swap
JB racing 8lb flywheel
New stock clutch (upgrading once I burn this one out)
..............................SUSPENSION.......... ...........
IE stage 3 race springs
IE urethane trailing arm bushings
IE subframe bushings
IE urethane motor mounts
IE urethane tranny mounts
IE billet rear shock mounts
ST sways with adjustable endlinks
Bilstein sports all the way
THR cabs
New Control arms
New tierod assem.
..........................BRAKES.................. .......
blueapplesoda SS brake lines (BTW they are awsome!!)
Stuff I have collecting dust and soon to be installed:
Complete black interior mint condition
gray carpet
crack free dash
Yet to buy..
Poor man BBK.
HP pads
Wheels- haven't picked any yet
MegaSquirt
Sparco strut bar
I should be able to install my low boost turbo setup...umm..soon..here is what I have so far:
New Holset H1C
524td mani
38mm wastegate
24lb injectors
rrfpr
Custom SS 3" downpipe and exhaust (need to fab)
elec. cutout
Smc alcohol injection kit
The e30 shares the driveway with my 99 Mroadster that is not worthy of pics at the moment due to a new top being installed, then RE dual mount diff cover and RF subframe reinforcement kit. pics of this later...of course the e30 with get the finned diff cover from the M..
On to the horrid pics.
you can see the prev owner used a forklift to pick up the front of the car...dumbass gosh!
I will take some better pics once I do a few more things like clean the car. I need to get a better camera and read up on pic taking tips.
8mm plug wires
4.10lsd
5 speed swap
THR cabs
New Control arms
New tierod assem.
gray carpet
crack free dash
Yet to buy..
Poor man BBK.
HP pads
MegaSquirt
Sparco strut bar
New Holset H1C
524td mani
38mm wastegate
24lb injectors
rrfpr
elec. cutout
