Suspension upgrades. Yay!!!
  • fwappy
    • Feb 2007
    • 362
    Well, I finally decided on the suspension that'll match my photoshopped signature and perform like a dream e30: Koni yellows and Vogtland Sport springs. Mmmm, mmmm good....
    I've also got new control arms, all front and rear suspension bushings, new brake rotors, pads, and stainless brake lines. Also, I've got a 5-speed swap ready to go once I finish the suspension! Recently I've swapped out the tan interior for black vinyl with gray/black houndstooth. Man I love that look!
    There's a few hold-ups in the tool area though. The rear wheel bearings are giving me a hard time, although a trip to Home Depot for the proper diameter pipe will do the trick. One thing that's really pissing me off is the front control arms. I cannot, for the sake of all F$#%ing ridiculousness, get the pivoting bolt to come out of the cross-member. I've actually bent a pickle-fork into complete deformity and bruised the hell out of my arm just trying to get that sucker to pop out. Any ideas?
    Well, I hope to be cruisin' soon!! I guess I'll be putting some miles on the e36 for a couple more weeks.
    "If I were filthy rich I'd still drive my E30."
  • Willis
    • May 2007
    • 22
    Dude, just use the expanding tool that the BMW techs use. Find an independant shop and get them to let you use the special toolthat they use. You use a 1/2" drive impact that drives a screw that separates the control arm from the cross member. Works like a charm, i had to use it for my car which had never had that link broken free before.
    • Fanzotti
      • 1255
      NICE KONI'S!!! Please PM me your parts list. I'm about to do the exact same thing to pretty much the exact same car, except mines an 89. Just want to see if you thought of anything that I'm forgetting. Where did you find the best deals on your parts? Can't wait to see your results. I think I'm going all oem rubber bushings, is that what your doing?
      • fwappy
        • Feb 2007
        • 362
        Yeah, mostly OEM on the bushings since I don't intend to hit the track. I figure by the time I wear these out the car will be either a) not be mine anymore, or b) be ready for a complete rebuild.
        As far as the parts list goes, are you doing the tranny swap, too? Or just the suspension?
        • Low Level E30
          • 1646
          Which Vogtland springs did you get?
          They sell TWO spring kits --- "Sport" and "Club Spec" --- what's the part number on yours?
          • whelton70
            • Mar 2004
            • 115
            Did you get the ground control rear adjustable konis ? If not you will wish you did !! You want have to take the rears out to adjust them. They adjust in the car like the fronts do. My set will be here next week to go with the H & R races for my build !!
            • sticksdaman
              • Apr 2005
              • 2987
              you should be looking at a drop similar to that im on vogtland sport springs too and im just shy of tucking in the back and the fronts have like 1/4 inch between tire and fender on 195 60 14s check the members gallery for a few shots of my car
              Originally posted by ebelements
              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
              • Jand3rson
                • 37587
                Are you talking about the bolt on the inner ball joint that holds the arm to the front subrframe?
                This is what you do. You need two long handled wrenches, one of them a 22mm on the nut, and another long wrench, locked onto the end of the 22mm as kind of a breaker bar (insert the open end of the 22mm into the box end of the second wrench, making it so they interlock), and just pull on that sucker. It will work, I just did it 2 weeks ago, and was actually shown that method by a tech at Pacific Motorsports in Portland.
                I just did pretty much everything on the front end you are doing, including new tie rods and tie rod ends, M3 offset cabs, and some other stuff. My car feels like it's brand new when driving. Just make sure you get an alignment before you any kind of driving that isn't down the street and back.
                • Fanzotti
                  • 1255
                  I'm doing suspension, Motor and tranny mounts and possibly the 95 M3 rack.
                  I just PM'ed you my parts list to see if it would help you.
                  • fwappy
                    • Feb 2007
                    • 362
                    Front: 9161006
                    Rear: 951014 (Club Spec, I believe)
                    I ordered everything as a kit from Vogtland here in SoCal. Their packaging job was frickin' horrid, btw.
                    No, they are not adjustable while in the car. That's perfectly ok with me though. I'd actually rather disconnect the bottom shock bolt and twist, than remove the trunk carpet, IMHO.
                    The instructions for adjustment are pretty vague. The picture shows it being compressed then rotating the bottom half either 180, 360, or a max of 720 degrees. But how do you know where the adjustment starts and stops? It never stops in either direction!!
                    • Low Level E30
                      • 1646
                      Awesome setup - looking forward to seeing what these look like on the car!!
                      When do you plan to put it all on?
                      • fwappy
                        • Feb 2007
                        • 362
                        I was working on it yesterday, but like i said above, I cannot get the control arm to pop off the cross member. I don't know what I'm gonna do.
                        • Low Level E30
                          • 1646
                          SOAK it in PB Blaster or some such lubricant / water displacer. Give it some love-taps w/ a wooden sledge, also.
                          • redhatpat
                            • Aug 2005
                            • 656
                            I think he's saying he has the nut off, but cant get the ball joint out of the subframe.
                            Bent a pickle fork? Holy crap. I used a pickle fork for that and it came out with no problem. Just make sure you have the right sized pickle fork or the amrs will just bend outwards.
                            • BUDNUNTA
                              • Apr 2005
                              • 996
                              Put a pry bar on the control arm and wedge it against the subframe right next to the ball joint.
                              I repainted my subframe so I wasnt worried about gouging it a bit. But it didnt dent it it worked perfect(used the same method on my freinds e36 today).
                              Hunter
                              We're out there in here.
