So uhm yeah, I washed my car
  • achtunge30
    • Apr 2006
    • 1029
    Well spur of the moment, I snapped a couple of pics after washing her..lemme know what you think...I've got several more pics but alot came out blurry (worse than these)...gonna shoot again later today/tonight.
    - Frank
    '87 325ic M-Tech 1 For Sale!
    http://r3vlimited.com/board/showthread.php?t=407503
    Build Thread http://www.r3vlimited.com/board/showthread.php?t=229347
  • BingM3
    • 863
    Nice, you got the Euro look going on:)
    • egk2
      • 2426
      To be honest, I like the wheels but it's not sitting right for
      stretched tires and wide wheels, it's gotta come down alot esp in the front.
      • achtunge30
        • Apr 2006
        • 1029
        Thanks EGK2 for the comments...
        While I do value your opinion and love the way your previous car looked, I do value my ground clearance (esp up front), survivability of my front end/oil pan and handling characteristics over aesthetic appeal. If there was an option that could give me a fair compromise of safe ride height/handling and giving the front a little less wheel gap, I'd go for it for sure.
        Not sure how it was on your M52 stroker but on the M42s the oil pan sits quite low.
        - Frank
        • T3rd Ferguson
          • Aug 2005
          • 3076
          Ed's car was a M20 2.8 liter. Loving the car, I would suggest a 60/40 drop just like he had. My brother's car has the same set up.
          1989 Bronzit 325ia- Sold
          1988 Delphin 327i- Sold
          1995 Cosmos M3- Current
          • mtechnik
            • 6156
            So you washed her up huh.. :)
            • silversleeper
              • Mar 2005
              • 2032
              lookin good... now slam it on some coilovers!
              Claus Luthe is my hero.
              • FredK
                • 14763
                Yeah, unfortunately the m42 oil pan sits LOW. That is a safe ride height you're rockin there.
                • DarkWing6
                  • Apr 2004
                  • 7144
                  If you want the ground clearance then get properly sized tires. The car looks great, and I love the wheels. The fender gap with stretched tires is a killer though.
                  • egk2
                    • 2426
                    55/35's and taller tires or switch up your wheels/tires to a more converntional setup with normal tires and higher offset.
                    • FredK
                      • 14763
                      Even with properly sized tires you will be risking the oilpan if you switch to COs or lower front springs. Especially in NJ or anywhere there are bad roads.
                      • achtunge30
                        • Apr 2006
                        • 1029
                        I cannot tell you how much people with lowered cars are easily surprised driving on Jersey highways, esp Rts. 9/287/35/1&9 etc...perfectly smooth, then craters, then dips, then speed bump indentations - even in my FX35 with 20s its quite a surprise.
                        I've already bottomed out a few times on my E30 setup on these highways. While stretched tires and slammage are the consensus - I'm pretty happy with the way my car looks :)
                        - Frank
                        • egk2
                          • 2426
                          /\ c'mon roads in Jersey aren't that bad, you should see detroit.
                          Try a taller tire when these wear, it will fill in that front gap a bit without compromising ride height.
                          • ACHTUNG
                            • May 2005
                            • 2397
                            I love monoblocks
                            1989 US E30 Cammed S52
                            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                            • euroshark
                              • Apr 2006
                              • 3491
                              The back looks good, but the front end looks so wrong to me with the wheels coming out past the fender opening... It looks like the lobo Fords we get in Denver, though those are a bit worse with about 4 inches sticking out past the fender so they can fit 295/50/15s. A staggered setup would fix that right up!
