How to tell about timing belt condition?
  • 5spoke
    • Sep 2007
    • 1729
    Hey guys, I bought an 89 325i convertible a few weeks back. When I bought it from the guy he told me that he just replaced the timing belt. I am a little bit worried whether he told me the truth or not. Is there any good way to visually tell how worn the belt is? I really dont want to have the thing break and kill the engine.
  • aschmidt
    • 457
    Just take a good look at it. You can see if it's extremely worn and/or tearing around the edges.
    -Adam Schmidt-
    1988 Zinnoberrot 325iS ::dead::
    1988 Bronzit 325iS ::sold::
    1991 Alpine 318iS
    • erik325i
      • Jan 2005
      • 3567
      You should not wait until you can see a worn or damaged belt. If you can see any wear or tears, you're probably already past due.
      If you are unsure of it, replace it anyways.
      -Erik
      • e30lyf
        • May 2007
        • 4553
        -Erik
        +2
        - Fercy -
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
        • 5spoke
          • Sep 2007
          • 1729
          I actually bought the car off a guy who was a member of this forum. His name on here is "Willsol" or something like that. The car definetaly needs work, but I am hoping to get her back to top shape. heres a few pics.
          • thereisnoyun
            • Feb 2007
            • 2301
            replace it
            its a good start to learn to diy your car. Do it soon, if there is no record. Also check under the fuse box, sometimes people put the sticker of when they change the belt there.
            • Alecs MacDonald
              • 729
              "If there is any doubt, then there is no doubt" it needs to be replaced. Congrats on the purchase.
              '88 325ic
              • 5spoke
                • Sep 2007
                • 1729
                I checked the timing belt today. From what I can tell it looks new. The stamp on it that says "Made in Germany....random other things" Is bright yellow still, and there is no visible wear marks.
                • delatlanta1281
                  Dart Master
                  • Mar 2006
                  • 10317
                  I agree, it isn't too expensive to do, you will need to do the water pump too. I can't believe there isnt a receipt or anything. I keep all my shit and a member would do the same. Sounds scetchy to me.
                  Yours truly,
                  Rich
                  you kids get off my lawn.....
                  • sirsteezo
                    • 577
                    you bought this car off of vadriven, right? im a member on there as well. Yea I had the same question before about my timing belt...no sticker, no indication but I did find paper work from the previous owner on when he ordered/installed the part, luckyly everything is good to go. I also did what you did...looked at it, no visible marks of being torn, or damaged. im surprised the guy ended up selling it...he was iffy about selling it.
                    • LivingLegend06
                      • Dec 2006
                      • 1604
                      I keep most of my receipts but I have lost a receipt or two before so it is understandable. I'm not even sure why keeping receipts is necessary is for me, I don't ever plan to sell the car, EVER.
                      • delatlanta1281
                        Dart Master
                        • Mar 2006
                        • 10317
                        I like to keep it so I can go through it and cry a little.
                        For me with four cars I can't remember when I did half the shit, so I keep everything for each car. Granted my e30 doesn't get driven that much, it's still nice to have.
                        Yours truly,
                        Rich
                        • rodrigo
                          • Aug 2007
                          • 923
                          It's your call...know when it was done or leave it hanging. The cost to change the timing belt is much less than what would cost to repair the motor if it broke, so I would replace the timing belt, water pump and gasket, tensioner, all of the shaft seals and lower seal carrier plate gasket, accessory belts and start off with a base for future repairs. Address everything in there and forget about it for a while...most of all that mentioned stuff comes off anyway to replace the belt.
                          Mine looked OK, but when I removed it and arced it in the opposite way from how it sits on the gears, I could see splits on the belt teeth, some fraying fabric on the ends...looked OK when I took the covers off.
                          At worst, you will know when to replace it next if you do it now, and sleep well at night.
                          • 5spoke
                            • Sep 2007
                            • 1729
                            I actually bought the car off craig's list. I was looking for an e30 and it was advertised about 10 minutes from my house, so I went and checked it out.
                            I am probably just going to go ahead and replace it, as well as replace any other things I can to prevent any typical future issues. This car is not my DD so I will be slowly rescuing it from its life of neglect. I need to drive it home this weekend and then I will start the process of revival!
                            Thanks for the help guys!
                              • 34839
                              if there's any question about the timing belt condition, just replace it. a timing belt kit is about $30, and another $30 or so for a waterpump and thermpostat. then you need some non-phosporous coolant and a couple hours of your time.
