Pics of my car from Ofest...
  • gobuffs
    • Dec 2004
    • 513
    Not fast enough.
    • Annie
      • Aug 2007
      • 48
      Is this Bruce that runs the SCCA autox around Albany?
      • gobuffs
        • Dec 2004
        • 513
        Nope.
        • RyanZ06
          • Apr 2007
          • 226
          Originally posted by gobuffs
          Not fast enough.
          Need some help setting the car up?
          • Teaguer
            • Sep 2004
            • 6167
            Bruce , nice to see it coming togeher visually .
            I'd seen the paint in stages but never complete, looks like Greg did a nice job for you .
            • Teaguer
              • Sep 2004
              • 6167
              How's the twin-cam doing these days ?
              • BrandC
                • Jul 2006
                • 444
                Lexan windows = HARDCORE
                -Brandon
                • Stu Mc
                  • 4083
                  Car still needs suspension tuning and figure out why I am down on power over 6500 rpms. Car could be somewhat competitive in CM with the right driver (read: not me), but probably will not when the big dogs come out to play.
                  Nice setup. Any idea on the engine problems? Fuel? Vanos?
                  Are you running coilover rear or stock?
                  • Digitalwave
                    is a poseur
                    • 6298
                    Fucking gnarly!
                    RISING EDGE
                    • luTTz
                      • May 2007
                      • 204
                      Can you give me some info on the lexan you are using? What is the thickness? Does it tend to bow at all? How did you go about attaching it? Did you end up using pop-rivets? I'm going to run my car in GTS next year with NASA and I plan on doing this, just wondering about how you did yours.
                      • gobuffs
                        • Dec 2004
                        • 513
                        I got MORE than enough offers to do that.
                        • gobuffs
                          • Dec 2004
                          • 513
                          Thanks. He did a better job than I asked for.
                          • gobuffs
                            • Dec 2004
                            • 513
                            Vanos. curve is strange down low (no big deal), but drops off a cliff over 6500. Peak power now is around 6500 (265 on one dyno), but is around 185 at where the peak power should be (7400). I expect once it gets sorted the peak power should be around 275. I replaced all 4 vanos solenoids, but the problem still persists. I had 255 stored exhaust vanos actuator valve codes. Not sure what part that is, but it sounds like the solenoids. I had a problem with the harness on the crankshaft position sensors, so I am thinking it might be a wiring issue. I need to check continuity on that wire.
                            I am running true coilovers in the rear.
                            • gobuffs
                              • Dec 2004
                              • 513
                              I bought it from MAShaw, but it was drop shipped from Percy's High Perf (percyshp.com) in St Louis. I believe it is 1/8th. Percy's has a few thicknesses. I used pop rivets. I need to add some tabs to be rules compliant.
