Cant get low enough!
  • sticksdaman
    • Apr 2005
    • 2987
    raise the rear a tad add a lip and its titties.. i mean even more than it is now
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
    • BMDub
      • Sep 2006
      • 122
      Originally posted by M42Technik
      They look like Enkei 92's but they are not. Well...they might be.
      They could be SSR Reverse Mesh, Very Rare.
      • buhnah7
        • Oct 2007
        • 65
        Originally posted by Spec
        Add a lip.
        The stock iS lip is 3 inches at the sides and like 2 in the middle it will look so much lower
        • stevofthahill
          • Apr 2005
          • 2468
          You're missing the point. He wants to get rid of the wheel gap and tuck some tire, not simply make it "look" lower. BTW car looks sick, and that s13 = ill na na na na.
          • mattdk318i
            • Jun 2006
            • 3953
            he should talk to 92MtechnicCabrio. Have you seen his sig?
            • E30SPDFRK
              • 5715
              That e36 is hot, I dont like the wheels though. I think ebelements did something with corrado springs and shocks to make his front end lower.
              Byron
              Leichtbau
              • e30prideTN
                • Apr 2006
                • 442
                I love both of your cars spastic! When are we going to meet ;) I might see you on the Tail of the Dragon trip if you go. I'm still unsure if I can make it.
                • SpasticDwarf
                  • Sep 2006
                  • 1062
                  Thanks everyone.
                  The 240's wheels are SSR reverse mesh, 16's, I think they're 7.5" wide, -5 offset.
                  The wheels on the e36 in that pic are a set of drift wheels. My main wheels are Borbet Type A's/HRE C20's.
                  Thanks for the tips guys. And E30PrideTN, you better make it!
                  • psloan
                    • 9815
                    So, you're gonna be there?
                    • M42Technik
                      • 9781
                      Keep your dick in your pants. :rofl:
                      Reminiscing...
                      • psloan
                        • 9815
                        Believe me - I will. That was in reference to the old "tail of the dragon fund" thread. Good times.
                        • Skafrog
                          • 1732
                          get GC or vorshlag camber plates. It lowers your stack height, and stops you from bottoming out your shocks.
                          I thought we already talked about this?
                          You need to come over and see where my adjuster is set :)
                          NASA MidSouth TT Director / GTS2 #018
                          Mods: Coastal PS Fluid, 10w40 Oil
                          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                          • M42Technik
                            • 9781
                            If you get GC camber plates on a GC setup you will have way more suspension travel:
                            http://e30m3performance.com/installs...p/GC_susp3.htm
                            Reminiscing...
                            • whiltebeitel
                              • Apr 2007
                              • 2098
                              K-Mac and Vorshalg are two different beasts.
                              '89 325i track sloot
                              '01 530i daily
                              -Enginerd
                              • 4ce30
                                • Feb 2006
                                • 2762
                                you need to cut the stock spring perch then weld on a new pearch for the GC spindel to sit on.. Then to obtain greatest spring travel/performance you must buy the GC camber plates...
                                -Brandon
