M3 update (no April fools joke here)
  • cramer
    • 1812
    The last few weekends I've been working on installing parts I've built up over the last year or two.
    Goals: #1 Replace the entire cooling system which means:
    PWR aluminium radiator (E30 M3 direct replacement)
    Spal cooling fan
    Waterpump
    Samco hoses
    Thermostat
    Overflow tank
    temp sensors (4 total)
    Electric fan fix (typical broken wires at the switch)
    Only thing unchanged is the heater core.
    #2 Alternator vibration: I couldn't keep the alternator belt tight as the alternator itself moved too much. After installing new poly bushings that did little to help the movement, I found the bolt holes in the mounting bracket had elongated and allowed the mounting bolt to shift around. So new bolts, bracket, adjuster arm and metal sleeves later, it's just like new :)
    #3 Oil leaks: Yup, S14 oil leaks - got the timing chain tensioner to stop leaking and replaced the valve cover gasket for a 3 rd time... it appears that those are holdling. Now I have narrowed it down further to the upper oil pan gasket. This will have to wait until the next oil change ;)
    On to the pics!
    All torn down ready to be cleaned up
    Shiny new alternator mounting brackets and sleeves
    Test fitting the radiator (great fit, just needed to space the lower mounts a tad to ensure no movement)
    and back together (that was quick! ;))
    13" Spal fan installed
    Last thing to do is finishing wiring in the switch for the Spal fan and go for a drive :)
    Chris
    90 Corrado/91 M3/01 M5
  • backtrail69
    • Jul 2005
    • 4471
    Looks good Chris, you shouldn't need an oil change very often with how much that thing is leaking. :) I suppose I am not one to talk, since I have filled lots with blue smoke before huh... :)
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • golde30
      • 11464
      hot damn thats a sexy engine bay. i also need to hunt down some mystery oil leaks on my s50, arent they just annoying as hell??
      IG: @Baye30
      • dmoney(AB)
        • 1372
        nice install.
        how thick is that spal fan?
        looks like its floating lol, how does it mount?
        mtech1/2jzgte/r154/275tire
        function>form
        • e30lyf
          • May 2007
          • 4516
          nice and clean engine bay.
          - Fercy -
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • crunk3
            M5
            • Sep 2006
            • 1182
            OMG your Engine Bay is sooo Clean.
            More PICS!!!
            91 318iS http://www.cardomain.com/ride/2396154
            • BBY1104
              Looks god man
              • andrewintraining
                • Jan 2008
                • 78
                I came
                Looking for an e30.....
                • Jonathan M3
                  • 1837
                  How much did the radiator run? Thats the only thing I haven't replaced in my cooling system.
                  '05 E46 M3 Imolarot/Cinnamon - CURRENT
                  '98 E36 M3 Estorilblau/Dove - SOLD
                  '90 E30 M3 Brilliantrot/Black - SOLD
                  SRS BSNS Motorsports - 24hrs of LeMons Racer
                  • BingM3
                    • 863
                    I think they run between $400-700 depending where you get them from. Jonathan, nice engine bay! Pure SEX!
                    • Garageaholic
                      Freestyle Fabricator
                      • Dec 2005
                      • 5204
                      What did you do about the electric fan? Manufacturer? what is the thickness of it? How much did it run you? Thanks
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      Instagram.com/garageaholic
                      Youtube.com/garageaholic
                      • WillisE30
                        • Jan 2007
                        • 831
                        S14s certainly look more interesting than any S5X motors ever will. Glad you got the Exon Valdez cleaned up.
                        sigpicFormer professional wrench thrower.
                        Current:
                        1988 325is S52
                        Former:
                        2008 Sparkling Graphite M3 Sedan(victim of home ownership)
                        1988 M5
                        1996 328is
                        • jpsfab
                          • 134
                          love that C/F intake!
                          THE ONLY WAY TO DRIVE AN S2K IS TOPLESS AND BOOSTED! GO BIG OR GO HOME!!!!
                          • KangamangusDriver
                            • Aug 2005
                            • 1870
                            If that fan is mounted to the radiator using plastic style zip ties, get them out of there!!
                            I have seen them round out the radiator fins and cause a leaky radiator, no bueno!
                            Engine looks great!
                            Love the CF intake mani!!
                            • cramer
                              • 1812
                              The radiator is from Bimmerworld, $539
                              The mounting is the Spal quick mount (zip tie style). BW recommened it for mounting and said they had no issues with it on their race cars. I'm not sure how it would round the fins causing a leak as it's a snug fit when they are inserted into the fins (the horizontal fins, not the main vertical ones that transfer coolant). I guess we'll see how it holds up :)
                              The 13" Spal fan is the narrow one, 2.05" 920 CFM
                              Chris
