Franken Kar
This topic is closed.
    Originally posted by gstuning View Post
    Then why are you claiming without any evidence of ANY kind but a picture of what could be anybodys engine and your word?
    And for you owning one of these 11k engines and not have a race team you own, sounds even more implossible.
    also a 7mm valve stem is a production sized valve stem for a euro S50.
    S50B32 and S54B32 use a 6mm valve stem for a good reason,
    a 11k S42, S20 would never use a 7mm valve stem.
    You can´t forget that the internet isn´t on the internet anymore,.
    What you say HERE get´s out THERE.
    I´m not even going to touch your "engineered" rear braces.
    Euro-ownage
    Nice my friend, very nice :pimp:
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
      Originally posted by DCColegrove View Post
      SAE HP is:
      Torque times RPM divided by 5252 always
      Exactly. So at 5252 rpm, HP = torque * (5252/5252).
      So what exactly do you mean? Still a bull shit .graph
        Okay... If you say so.
          Originally posted by TwoJ's View Post
          But you do pot bogus ass dyno graphs? That plot is not real.
          Torque = horsepower @ 5252 rpm. Always.
          Mr. TwoJs, that assumes that both vertical axes have the same range. They don't in this graph.
          -OVULATOR (as named by jflip2002)
          Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
          Now: Blake-stitched mediocrity :(
            At least somthing is sinking in.
            Gunni
            @ Prodrive / Aston Martin Racing
              busting out the loller truck for a lol thread
                Can you explain it because I honestly don't get what the hell it means...
                I had it because I was going to e-mail it to someone to interpret for me.
                  I'll stand toe to toe with you on chassis braces though...
                    Ah hah. Correct you are. That is foreign to me.
                    STILL ISN'T A GRAph from an NA m20 though.
                      So if you look at the data at 3660 rpm, you can see torque = 288 ft-lbs (or so). Multiply these numbers together, divide by 5252, and you get 200. At 3660 rpm you can see the power is right around 200 hp.
                      QEAD.
                        QEAD.
                        Thank you...
                        I have never seen a graph that looked like an x though... Can you explain a bit more?
                          You can stop playing games and jump in any second now with your infinite wisdom...
                            QEAD.
                            Did you mean QED? My set theory prof made us end proofs with QED; which is quod erat demonstrandum. I've never heard QEAD though.
                              I´m so assuming you took the chassis and BENT it in a bench and derived all your construction parameters from there.
                              i.e the bending stresses and how much angular movement there was with x amount of force to the shock towers and subframe and where thus able to find the the ideal bracing to stop the chassis from bending. Or did you just weld some stuff in a few times to make it stop bending?
                              There is a difference between imperical "engineering" (fiddling) and engineering (good old math)
                              I´m all for discussion , but only when people answer with discussion and not little remarks.
                              Gunni
                                Wow, i came back from a psych final and BOOM
