Good gosh that thing will be awesome!!
BMW E30 M-Tech Cabrio (M-tech2, BBS RS, M30 etc etc..)
I'm using S62 flywheel as an example because i've E39 M5 gearbox), upgraded clutch (E34 M5 Sachs racing pressure plate, S62 original clutch plate)
bigger brakes (E34 540 calipers and master cylinder, 312/32mm front discs, 294/19mm rear discs)
Lots of stuff need still to be done but i've couple of months time still :)
Fist question is I noticed in you pics that you have fabricated a collar for the release bearing, Why? does it have anything to do with the clutch you are using? Specs?
Second what car did the brake discs come off of?"A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
Friedrich NietzscheComment
I think it moved a little...
Im suddenly demotivated to work on my cabby cause it will never look that nice....Comment
i honestly hate the wheel color
but other then that drool that car is sex. well done
e24 e9 e30
IG: peterkaczynskiComment
Brakes are like in the kits on www.300mm.de (audi 312x25 front, bmw 294x19 rear).- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
The collar for the bearing is to make the total height of flywheel + clutch to be the same as it was originally, so the clutch slave cylinder works as it should.
Brakes are like in the kits on www.300mm.de (audi 312x25 front, bmw 294x19 rear)."A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
I have a E46 Getrag 6SMT going in my E30 with a S52 in front. I would like to run a S52 flywheel and clutch setup with the 6speed friction disc. Can you tell me how you came up with your measurement difference between the stock flywheel/clutch and what you are running? Did you just set the whole thing up on a bench and compare the heights or do you have any info from research you have available to you?
To unmount clutch you need to take the v8 engine out, that's why i didn't want to try whether it works fine without the collar. Well, i'll see how this works in couple of weeks :P- E34 M5 (x 2) -
Yes i just put it on the table and measured the total height. Of course the clutch forgives you some, but it can't be too low (clutch stick will pop out from the slave cylinder).
To unmount clutch you need to take the v8 engine out, that's why i didn't want to try whether it works fine without the collar. Well, i'll see how this works in couple of weeks :P"A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
Yappadai, the engine is up'n'running again :)
Startup video here. First start so no fuel in the lines, that's why it takes so long.
Still lots to do..
- E34 M5 (x 2) -
