The drop looks good.
Going lower
BUMP okay, would these be a good buy? http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245 I am new to e30s btw and if i get that kit on ebay do I need anything else to it? How much does the auto shop charges for springs installation or its easy to install them my self?Comment
learn which sets ups and which mfg are legit and have good products.. and yes you can do suspension yourself.. just need tools and use a write up.
depending on how low you go you might need new shocks as well.
M50B25tuComment
IE's are nice. I have the same springs but with koni's
get real suspension like this OP did.
And yes you can install the suspension yourself.
Use the Search feature, its wonderful.-Frank
1987 325is m50nv (schwarz)
1990 325is (sterling silber)(sold)
2001 525iComment
If you have to ask if you can do it yourself you're prolly better off having a friend or someone that knows how to do it for sure do it to your car. Suspension is not to be fucked with.
Anyway, the drop did really good things to your car. I really like it, those rims are dope btw, my buddy has a set of them on his IX.clutchCTRL!Move with a purpose.- 1991 325iX 4dr/5spd- 1976 2002 SlickTop/2.7i M20/G260- 2000 323i AT2016 Mazda CX3 Sport AWDComment
Im looking into getting new tires since these are a bit much... what do you guys think would look better... 225/45/r16 are the same overall size as stock. Or should I go with a little smaller and get 225/40/r16?
What do you guys think would look best?
M50B25tuComment
205/50-16 or 205/55-16 still ride nice and cheap to buy!
Discount Tire Direct is retiring, but check out our partners at Tire Rack! With tires and wheels for virtually every vehicle make and model, Tire Rack is your new source for the best prices and selection for online and mail-order purchases.
they are PLUS 1 sizingseien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Cutting a spring will raise the spring rate. I can't remember the formula for it right now, but it does.Matt
sigpicComment
225/45/16 is the perfect looking tire for an E30 I think.
Or a 215/40/17
Car looks good!Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Yes, it does. The formula for the force a spring exerts is F = k*dx, where F is in newtons, k is the spring constant (usually in N/m), and dx is the change in the spring length.
For a clear example, consider a compression spring with a k of 10 N/m. Applying a force of 1 N to it, then, decreases its length by 10 cm. Consider one half of the spring, though. With the same 1N force applied, it has only been compressed by 5 cm. (both halves contract by 5cm) Therefore, k for half of the spring is double of what it is for the entire spring.
From this, it follows that if we reduce the length of a spring to x% of its original length, it will become 100*(100/x) % stiffer. For example, reducing the spring to 80% of its length makes it 100/80 = 10/8 = 5/4 = 125% as stiff as it was. (increases the spring ratio by 25%)
Sorry, I've been doing math proofs for the last 6 hours and couldn't resist... I'm in the proof zone.Comment
I always hated proofs... you just boggled my mind.
M50B25tuComment
Sorry, I've been doing math proofs for the last 6 hours and couldn't resist... I'm in the proof zone.Matt
sigpicComment
