Finally: Rims, More Suspension Work....
  • denisbmwm5
    • 347
    Were did u get the is lip from? and how much?
    • spencers
      • Jan 2004
      • 1150
      Originally posted by randomtask37
      there is something about it that just doesnt quite look right to me.
      Unpainted lip
      Originally posted by Skafrog
      Matt, I dont want to paint the lip body color as it will get chipped at the track, and SEM Trim paint is a hell of alot cheaper than Calypsorot Metallic :-).
      Grab another and paint it! :) Put it on whenever you want the car for looks.
      • peteM3power
        • 450
        Your car looks sweet! I just love the stance together with the Ronals, they really make it!
        --Pete :D
        • M42Technik
          • 9781
          I just got RTRS subframe bushings and CAB's
          Why did you choose Treehouse over RTRS for CAB's, just wondering?
          And where can I pickup a set of RTRS Trailing Arm Bushings?
          Looks great, the highbeams are awesome and unique, don't change them.
          Reminiscing...
          • Skafrog
            • 1732
            Treehouse's are far superior in the fact that they are basically solid with a small delrin bushing. This eliminates ALL flex, as even delrin bushings flex. The bushing also has a lifetime warranty on the insert, and it is very easy to install/dissasemble, plus they work with m50 swaps (thats why they were designed). It is also very moderately priced. I bought the bushings before I started working for them, so I am not biased, I looked long and hard at Bimmerworlds bushings, and ended up getting Treehouses.
            You can call Jon at 615-500-1331 and order the trailing arm bushings, or check if http://www.bmwbushings.com has them, they carry RTRS stuff.
            Also, thanks for the compliments.
            NASA MidSouth TT Director / GTS2 #018
            Mods: Coastal PS Fluid, 10w40 Oil
            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
            • M42Technik
              • 9781
              BMW bushings doesn't carry trailing arm bushings for E30's.
              As for the Treehouse CAB's, I might have to return my RTRS ones...but 15% restocking fee? Damn.
              Anyone want RTRS Control offset bushings?
              Reminiscing...
              • bmwm3n528
                • 3654
                I'm diggin' it...LS's are still one my favorite reasonably priced wheels for e30s to this day.
                Trevor Ely
                '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                • Digitalwave
                  is a poseur
                  • 6299
                  RTRS CAB's are also solid with a delrin insert, I don't see the different in those and the Treehouse ones...?
                  RISING EDGE
                  • M42Technik
                    • 9781
                    True there is no HUGE difference, but if you're heading for a engine swap, these help out along the way, mostly in terms of wheel placement inside the wheel well...but other than that, not a significant difference, so I'm sticking with the CAB's I got. (RTRS)
                    Reminiscing...
                    • Digitalwave
                      is a poseur
                      • 6299
                      How are they better for engine swaps? And aren't they just offset like the offset RTRS ones?
                      RISING EDGE
                      • M42Technik
                        • 9781
                        They pull the wheel further forward, and closer to the center of the wheel well, a common problem after installing an M50, S50, etc is the wheel is too far back, and this fixes it.
                        Reminiscing...
                        • Digitalwave
                          is a poseur
                          • 6299
                          So do the offset RTRS ones, which I have. They make a nice difference. But are the Treehouse ones even more offset than the RTRS ones? Because mine seem about as far offset as they can be.
                          RISING EDGE
                          • Skafrog
                            • 1732
                            No, when you do an engine swap you have to modify the exhaust in order to clear the regular designed CAB's. With Treehouse's, you can bolt up a whole e36 exhaust and still clear the CAB, no modifying the downpipes required. It is also the same offset as a regular M3 bushing, giving you 9 degrees of caster in the front end, but there is room with our design to give more caster. Also, there is very little bushing material, as with a stock lollipop there is still a lot of bushing material, permitting it to flex, even though it is made of hard delrin.
                            M42, thats a problem with 5 lug swaps, not m50 conversions.
                            Digitalwave: If you dont plan on swapping in an m50 and have already spent the money on RTRS, they are great. RTRS makes some damn good stuff, as I am sure you found out with your rear bushings (BTW: How do you like them?). However, if your bushing cracks, check out Treehouse's as they have a lifetime warranty on the bushing material.
                            • Digitalwave
                              is a poseur
                              • 6299
                              Thanks for the clarification. I understand what you are saying now. I get my RTRS stuff for free, and it has made a tremendous difference on my car. If I hadn't gotten them for free I would buy them anyways. The subframe bushings have taken a ton of "flex" out of my car, and that wicked squeeking and squatting I had from my old bushings is gone.
                              RISING EDGE
                              • M42Technik
                                • 9781
                                Ahh my mistake, forgot all about that!
                                Thanks for the clarification, and yes I'll be keeping my RTRS stuff. Although I still can't find the rear trailing arm bushings from them for the E30...
                                Reminiscing...
