DCColegrove's Daily Driver:
This topic is closed.
look i can understand someone making a simple math error. im not the brightest guy myself. but can you please elaborate on the lightweight seat frames and padding and lightweight wiring loom and other things you stated? i have a 6700lb f250 super duty plow truck and id like to get it down to maybe 1800lbs so its as nimble as one of my 02's
Excellent Office Space quote FTW.
Dude, don't leave just because some people don't believe your claims. You should back them up and prove everyone wrong. Hurry up and post some epic pics that'll get everyone to clam up and admit they were wrong. Your car on corner-weighting scales would be a good start. You might want to wait until your car is nearly out of fuel, though...
MTech2 wheel | Husco Armrest | Smoked Hella Smileys | 5k HID | Stromung | RS003 | Shadowline | Amber Fogs | Too much else to list
Dude...
I'm not going anywhere...
I'm just getting tired of plowing through DVD after DVD of images...
I moved a few months ago and they king of got spilled out of the file boxes...
In the spirit of getting shit done... They were re-filed in random order...Comment
I'm more interested in hearing the methods of dropping so much weight. Pictures aren't so necessary.
drilled out cams ~.5 lbs
"alloy rivets"~ 1 lb.
reworked sport seats ~ 6 lbs.
lightweight wiring ~ 2 lbs.
~10 lbs.
+10 lbs. of chassis braces
= net zero weight change
The means you have mentioned will not remove 600 lbs. from your car. Your weight claim is bs and your defenses for the claim are even weaker.
S50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
Your estimates are a bit off.I'm more interested in hearing the methods of dropping so much weight. Pictures aren't so necessary.
~10 lbs.
A cam weighs about 5-6 lbs, by coring it you can lose 2 (going from sheer amount of material removed)
Have you ever completely stripped a car, put all the hardware in a bucket, and tried to pick it up? It's quite heavy.Comment
Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
I'll sit on this...I'm more interested in hearing the methods of dropping so much weight. Pictures aren't so necessary.
~10 lbs.
You have a very narrow view.... I mentioned a very few examples pertaining weight reduction here.
And do you know how many assumptions you've based on bad guesses...
Okay I'll give you one clue
Do you know how much the wiring in an e30 weighs?
...find out and cut that by about 65%Comment
The Nuts and bolts are steel...
Go take off one of your fenders and weigh the screws... you have to cut the captured nut off to weigh it but...
Then go weigh enough av skin rivets to put it back together... The devil really is in the details...Comment
post a pic of your fenders attached with aviation rivetsComment
