Schwarz '90 Coupe Build
  • derz
    • Sep 2019
    • 16
    Hey everyone, I am a long time lurker who finally picked up his first e30. I got into these cars about 6 years ago in high school. Couldn't pass up an e36 I found, so that has been my project for the past few years. I finally sold it to make room for this, which is my dream car. I've spent countless hours reading people's threads so I figured I would start my own. This is my 1990 325i that I bought earlier today. It is a little rough around the edges, but it is mostly original and pretty well taken care of. Its still rocking the m20b25 and has about 210,000 miles, although the odo just broke. I am happy with the condition, especially for a NE car. I bought it from the 2nd owner, both were older gentlemen who babied it and kept up with the maintenance.
    Some of the mods done are:
    Bilstein Shocks
    H&R Springs
    Dinan Chip
    Cold Air Intake
    Magnaflow Catback
    4.10 LSD
    Recent maintenance, including timing/other belts and hoses
    Its got a few quirks like any old BMW, but I am excited to work on this when I am home from college. My plans are to fix the small problems, like the driver's door gasket, slight oil leak, temp gauge malfunction, and some squeaky belt.
    As far as future mods, I am thinking:
    Airbag wheel delete, probably replaced with MTech-1 or Nardi/Momo
    Pop-out window conversion
    All red tails
    is lip
    5 lug conversion
    Either 17" Style 5s or Style 32s
    Upgrade the seats, I am thinking about just finding sport seats but bucket seats are kinda appealing
    Suspension bushings
    Sway bars
    Euro Smileys
    I have no clue beyond that what I want to do in terms of forced induction, 24v swap, etc. It'll be a while before that is a realistic option. I'll post more pics once I get the car home in a couple days.
    '90 Coupe Build: https://www.r3vlimited.com/board/for...90-coupe-build
  • roguetoaster
    Biggus Tippus
    • 7830
    Looks like a great starting point. Take your time, mod slowly, it generally will hold your interest for a longer time, and result in fewer regrets.
    • 2mAn
      Señior Mod
      • 21035
      Not a bad starting point at all. I would suggest doing plenty of research before doing any mods and get the maintenance done ASAP, when was the last time the timing belt was done?
      Welcome
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • derz
        • Sep 2019
        • 16
        Welcome
        PO said 180k and its at 210k. I have no way of verifying this so I will do it asap in order to get a baseline. Anything else you'd recommend right off the bat?
        • 2mAn
          Señior Mod
          • 21035
          Typically water pump and timing belt are the things to knock out first. Chances are you'll see stuff "while you're in there" like the v-belts, coolant hoses, etc
          If the valve tick is a bit noisy, might need a valve adjustment, but other than that just deal with the issues as they appear and enjoy it!
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • derz
            • Sep 2019
            • 16
            Finally drove it home today!
            The car took the 2+ hour drive surprisingly well. The 4.10 LSD had it screaming a little bit on the highway but it was bearable.
            After a good amount of time behind the wheel, a few things are apparent. this is definitely a 30 year old car. Once i get it inspected, the suspension will have to be addressed.
            • derz
              • Sep 2019
              • 16
              • derz
                • Sep 2019
                • 16
                Pretty productive now that I have had a break from school.
                Replaced the brake pads and rotors.
                Got a new hazard light switch from ebay and spent 45 minutes trying to get the head unit out
                Took off the airbag and steering wheel, pulled out the gauge cluster and replaced the odo gears
                picked up some pop out windows for a crazy deal
                oil pan cleaned/ gasket replaced
                currently working on the timing belt
                now in serious financial jeopardy lol
                pics below
                • derz
                  • Sep 2019
                  • 16
                  Picked up these sport seats a few weeks back for a solid deal, but unfortunately the struts need to be replaced. Hopefully they’ll come in soon because the comfort seats currently in the car are all sorts of jacked up. Sent from my iPhone using Tapatalk
                  • derz
                    • Sep 2019
                    • 16
                    This is how it’s sitting currently. Replacing the clutch, changing diff fluid, and tracking an abs gremlin are top priority right now. Once I finish this semester I’ll have a lot more funds to play with and I’m shooting to do a 5 lug swap, z3 rack and shifter, and a few other little things Sent from my iPhone using Tapatalk
                    • derz
                      • Sep 2019
                      • 16
                      Had to order new struts for the sport seats. They’re not perfect, but a definite upgrade from the mismatched comfort seats. My plan is to eventually get a black or cardinal interior so these will work for now. Also sold a set of style 5s I had lying around. I’m likely gonna use that cash to get a set of CCW style wheels as street wheels. Eventually I’ll get a lightweight set, but that’ll come later.
                      • derz
                        • Sep 2019
                        • 16
                        Reviving my thread since I have other responsibilities to avoid. It’s been a while, and I have basically just been driving the car when I’m home from college. It hasn’t given me too many issues luckily, aside from not starting back in December. Turns out the engine ground wire was frayed and basically shot. Easy fix luckily. It’s sat since January. My dad has helped me out and has been chipping away on bits and pieces. Unfortunately it needs to be inspected this week, but in PA if you’ve put less than 5,000 miles on your car you don’t need smog for that year, which is one less thing to worry about. Still chasing an ABS system gremlin, but we’ll wait and see if it passes. This summer I’ll hopefully have more time/money to waste on this car, so I’ll keep the thread alive.
