91 318is progress thread
  • jhaurimn
    • Nov 2012
    • 2224
    After recently selling my first e30 in May due to rust, a few weeks later a deal popped up near me that was too good to pass up. Went to see it in person within an hour of being listed on facebook and bought it on the spot.
    1991 318is in brilliant red slicktop with ~130,000 miles, and very importantly rust free. Quite a rarity for MN. Guy owned it since 09 and it sat neglected for a few years.
    Andddd its official. In my driveway, right where my old 325i was parked. Spot did not stay empty for long.
    Few things about the car. It is very original, and by far the cleanest e30 I have bought out of the 4. A lot of original paperwork was included. Still has the original floormats. Was told by the seller the car needed brakes badly. More on that later.
    The car came with a shit load of spare parts as the seller was moving.
    Wasnt thrilled about some of the stuff, but there was definitely some good stuff hiding in the stash. Notable parts include...
    Mtech 1 spoiler
    Maplight
    Clean hvac panel
    And two 15" center caps which I learned were worth $250 when I was offered that price for them
    Alright, onto fixing the car. New headlights, orange turn signal covers and sidemarkers, and the cca badge and is lip from my old 325i.
    There was an ecosystem growing in the turn signal housings lol
    Zhp knob for EVERYTHING. Also from the 325i.
    And out with the airbag wheel.
    Now on to some mechanical fixes. First thing I tackled was the mess under the intake. Every intake hose was cracked, including the boot. No idea how the car idled.
    Valves looked good. Injectors looked like they were recent replaced as well so I didnt touch them. There are 4 spare rebuilt injectors in the part stash as well.
    Much better.
    New fuel filter
    And now suspension and brake time. Car came with new rotors and pads so just had to buy suspension stuff. Ive installed this vogtland/kyb setup in 3 of my e30s and its a very nice combination of performance to comfort.
    Time to get started.....oh.
    Both front rotor screws were fucked and took quite some persuasion with a torx and sledgehammer to come loss. Eventually got them both thankfully.
    Remember when the seller said the car needed brakes? He wasnt kidding.
    Muuuuch better. Not sure how I feel about the rotors, but they came with the car and the center parts are painted to prevent surface rust so whatever.
    And the rears.
    And perfect ride height obtained.
    And thats where we are currently. Upcoming plans for the car:
    -New thermostat and water pump (rad was recently replaced)
    -Try and find fabric to repair the front seat
    -Control arms and tie rods eventually. Ones in the car are still ok but id like to have it all new
    -Get a fuel line replaced that goes to the filter. It was leaking a bit and I was able to cut the hose end off for a temp fix.
    -Drive it maybe? The M52 from the 325i I sold is going in my vert soon so I have a feeling I will be driving that car quite a bit.
    Anyways, thanks for looking. I am not active on here much but I do like to track all the progress on my cars here. Nice to have the documentation to go back on.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
  • 2.5-12
    • Jan 2010
    • 1814
    a few weeks?! it was ONE day. lmao
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • 325isman
      • Dec 2010
      • 299
      great job.... look forward to seeing more updates.
      • 82eye
        • Jan 2009
        • 2104
        looks great. nice job.
        • Il Duce
          Non-Mod M42 Modder
          • 5046
          Beauty! Congrats.
          • jhaurimn
            • Nov 2012
            • 2224
            Time to tidy up a couple more things.
            New water pump and thermostat were in and ready to replace. Easy enough, fan clutch and shroud come off easy enough. Pull out thermostat, undo bolts for water pump. Use wp bolts to push pump out and..........
            Well...thats a first. Apparently its a m42 thing. Struggled with a bit with the pry bar I had but would not budge. Quick trip to harbor freight for a bigger pray bar was needed
            And it came right out with some wood between the pry bar and timing cover. Something something right tools right job.
            New wp
            New thermostat
            All buttoned up. :) Then filled with coolant and got leaks out the thermostat housing. :) So took housing back off and used rtv on both sides of the new gasket which fixed the leak.
            Also when I did the mess under the intake, for some reason the hose that goes from the water pipe to the bottom of the radiator was leaking. Had to take the upper intake off to adjust the hose. Thankfully that went back together and didnt leak again.
            Now time for some fun stuff. If you saw the interior pics, you probably noticed a huge hole in the driver seat. Time to take care of that.
            Donor seat disassembled for the side bolsters
            318 seat with top and bottom separared
            Interior work is not fun but also not worth paying a shop to do. Pretty straight forward.
            Sourced a new center section with nla oe cloth. Expensive, but high quality piece and definitely worth to get the interior fixed up.
            Lumber piece in
            Cloth piece gets a light adhesive coating to stick to the foam
            And a few staples later
            Now for the side bolsters. Old vs new
            Pbr is fueling me at this point. Light at the end of the tunnel in sight
            Phew.
            This car sat outside for quite a few years before I got my hands on it, to the cloth interior is very faded. So there is a noticeable difference between the center section and side bolsters that were replaced that arent quite as faded, but still very much an improvement. Side bolsters definitely match the headrest cloth much better as that got less sun. Just small details that are more noticeable to me. But I am happy with everything!
            Things left to do with the car:
            -Needs new tires
            -Muffler keeps hitting the body of the car, going to try replacing the exhaust hangers
            -Not priority but Id like to get a quote to dent repair the hail damage on the car​​​​​​​​​​​​​​
            Its a very nice car, that doesnt need much at this point. Going to get new tires and enjoy as much as I can with the rest of the summer. But it will be up against my vert that I just 24v swapped so we will see.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
