3.1 Build Project Resurrection.
  • SPAGHETTO
    • Jul 2018
    • 9
    Originally posted by Panici
    Have you tried track riding on a motorcycle?
    I found having that outlet to go fast makes me ride calm and collected on the road.
    That is your home shop with triple level storage racking? Epic, I hope I have a setup like that one day! :)
    I Haven't been on a track with a bike. Maybe some day ill give it a try. lol
    The workshop isn't at my home. about 10 minutes away. We found the 3x3 car lift on Ferrari chat for $7500 about 7 years ago. Disassembly, shipping, and assembly was not included.
    The only downside of it is that it severely increases the temptation to buy broken cars.
    • SPAGHETTO
      • Jul 2018
      • 9
      Progress Report...
      Work has been incredibly busy, so my progress is not as much as I would like, but I am getting somewhere.
      I finally disassembled, cleaned, and reassembled the HVAC unit.
      The pictures don't do it justice, but this thing was filthy.
      E30 progress
      E30 progress
      I didn't want to, but I ended up drilling the rivets out and splitting it in half so that I could throw it in the ultrasonic bath...no pictures of the completely disassembled state...the ultrasonic was definitely better than scrubbing this thing by hand.
      I did get to confirm that my 3D printed recirc/fresh air flaps fit very well!
      E30 progress
      E30 progress
      I have no idea what these little copper contactors do for the "face air" and "foot air" on the HVAC control levers, but the one for the foot lever had come off and was rattling around in my parts bag for the HVAC unit.
      I got out the pin vice and a 2mm bit and sent some machine screws through both contactors to make sure that they would never fall out again. (the spring pressure on these things is pretty high! I used all 8 of my hands to hold it in position and get the screws installed!
      E30 progress
      E30 progress
      I hope the screws hold better than the rubber cement that the factory used.
      Here it is all reassembled...
      E30 progress
      E30 progress
      That's all the photos I have from this round. I did actually install the HVAC unit, but then quickly realized that it was in the way of reinstalling the Windshield wiper assembly, so I pulled it out.
      After pulling it out, I realized that I should really get a new firewall boot, and replace the heater core tubes. so now I am waiting for those parts in the mail before final assembly.
      I have also made some other progress, but didn't take any photos.
      ABS Unit installed.
      E32 brake master and booster reinstalled.
      Accelerator Pedal assembly installed.
      late model 325i wiring harness modified (to send tach and consumption signal to eta OBC) and installed.
      I also spent a fair amount of time cleaning up my work bench in the shop today. It's amazing how fast the clutter can build up.
      I feel like I am missing something, but I can't think of it right now.
      I've spent a lot of time going through old parts purchases and sorting out my memory.
      I hope that as some fresh parts show up, progress will ramp up quickly!
      • SPAGHETTO
        • Jul 2018
        • 9
        More Progress!
        Heater Pipes fixed up and a new foam gasket.
        E30 progress
        HVAC Finally Installed!
        E30 progress
        E30 progress
        E30 progress
        Lots of Scrubbing, but got the Transmission cleaned up!
        E30 progress
        E30 progress
        E30 progress
        E30 progress
        E30 progress
        Rebuilt the "proportioning valve" and got the rear brake lines and fuel lines reinstalled.
        E30 progress
        E30 progress
        E30 progress
        Installed some Dynaliner. Probably could have done a better Job...
        E30 progress
        Flywheel, Clutch, and mating of the Engine and Trans.
        E30 progress
        E30 progress
        E30 progress
        E30 progress
        I realized while doing a cold valve adjustment that the alignment of the rockers on the IEM rocker shafts was less than desirable, so took a couple day detour to change them out for the original shafts.
        Finally installed the engine!
        E30 progress
        E30 progress
        That's about where I am at right now. most of my big ticket items have been checked off the list. Now I've got the long process of figuring where everything else goes or plugs in. lol
        Speaking of... can anyone help with location/usage for the brackets in these photos? (one in my hand and a little black bracket in the background that was in my transmission mounting parts bag...) any help would be greatly appreciated.
        E30 progress
        E30 progress
        Additionally, I need to get some measurements of the bottom bracket size/location for the late model coolant expansion tank. Is anyone on here located in Colorado Springs and would be willing to let me measure it?
        Until Next Time!
