Originally posted by newman
View Post
Newman's E30/Skyline swap thread
Originally posted by newman View PostSaw that. lol.
More boost tomorrow. :) Fingers crossed she holds together...
Holy shit did that thing haul ass mid pull when it got stuck, I knew something was wrong lol.1985 325e 2.8 Turbo VEMS
Is that all? haha j/k.
Well done, bet its a weapon to drive now.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by der affefirst try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
Haha, I know. In an autocross though, high-hp turbo motor throttle response and powerband, while great to wind out under normal circumstances, aren't that great. If you were to keep it in the powerband you'd be shifting like a madman (probably into first a few times), and a lot of the time you wouldn't be going fast enough to get any traction.
Post up a dyno, I'd like to see the powerband shape.paint sucks
I will when I get them... The 500 hp curve looks a little weird because we spun on the dyno a bit... The torque curve on the 23psi pull is a lot better...
Right now we set up boost by gear so it makes 12psi in 1 & 2, 16 psi in 3, and 21 psi in 4 & 5... It still spins a bit at like 120 or 130, so I don't wanna throw much more at it til I get a Mickey Thompson street radial on there...
I'm just gonna make this easier on my by quoting what my friend posted in his blog:
Originally posted by Inn-Tune View PostI've missed a few days of blog posts but wanted to get something up about Newman's Skyline GT-R powered BMW which I tuned for more boost today on 93 octane pump gas.
After checking to make sure the car was running as I left it, I started bringing the wastegate duty cycle up until the boost went over the 8 psi wastegate spring pressure. As the boost started to go up it was clear that I would be able to achieve Neman's goal of 450 whp on 93 octane with no external injection.
Here's a graph showing some of the pulls during the tuning process. I've chosen these ones since they're close to the boost levels we decided on for the boost by gear setup I've calibrated via the ViPec standalone ECU.
After the pull to 449 whp shown above Newman and I decided we had to go a bit further to break the 450 whp barrier. I knew there was a good amount of room left to grow so I bumped the boost up a bit and made a small timing adjustment which resulted in a pull that I aborted because the car spun the tires hard on the dyno.
After adding some weight to the trunk and adding some volunteer "passengers", we were able to get a pull in with less wheelspin. You can still see when it spins going into boost in the following video:
high quality vimeo video:
http://vimeo.com/11200475
low quality youtube video:
And here's the graph of the high pull in the video:
After dyno tuning was complete, I set up gear calculation and then boost by gear which is now set to provide 12 psi in 1st and 2nd gear, 16 ish in 3rd gear, 22 ish in 4th and a little more in 5th gear. In the future if Newman adds a wheel speed sensor on a non driven wheel I can set up active traction control for him uses % slip calculation based response to get the most performance out of the available traction.
The Usain Bolt of the car world, aint real pretty but fast as fuck!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
