The inlet to fuel pump has to be below the sump of the fuel cell, so I don't have many mounting options. I'm not lowering my car a lot (because low cars fucking suck) so I think it will be OK. It doesn't sit much lower than the rear dif.
Newman's E30/Skyline swap thread
If it's really close to the ground and concerns me, I'll build a protective cage for it.Comment
soft lines cmon man i'd expect you to hard line it with some thick walled 3/8 316SS lines rated at 7500psi ; / i'd move the pump for sure. put it on the side if anything, not the bottom. or put it by the stock fuel filter location.. probably better. glNo more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
The sump hangs below the tire well, so if I were to move the pump up, it would be way too high.
I can't put it at the stock fuel filter location because it's too far from the tank, and in order to get there the lines need to go up really high. Keep in mind the inlet to the pump needs to be gravity fed...
And I thought about hardline, but -8 stainless tube is kinda hard to bend by hand.Comment
I'll let the pix do the talking...
I read your build site today... opening line: I hate bmws'
Strange... Strange indeed, your right though, hondas' are much more attractive... yuck
p.s. how many civics do you see still running from the mid-eighties? Thats' right... there made out of coke cans...Comment
are you keeping the awd?Originally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
this weekend I pulled all the fuel lines and brake lines out, painted the holes I had drilled for the mounting hardware. I also added some mounts for the brake lines.
While i was under there, I had to put por 15 back on places where i had welded the seat rails in, because it had burned off.
I also installed the oil restrictor that I made in the block.
Lastly, I made brackets from 3/8 304SS to mount my new bigger front brakes, which arrived today (so did my wheel studs... FINALLY)
Here are the new rotors (foreground) old rotor (background) and new 6 piston differential bore caliper.
WHEEL STUDS INSTALLED. Love the "extended stud look"
New caliper on new bracket with OLD ROTOR
for reference, here's where the old caliper sat:
No i read it, and loved all pages. This is great, an atrocity...kinda. But ballsy and i love it. Im an wankel at heart and would to see a sweet FD3S motor in single turbo trim would be great.1989 325i - sold
1987 RX-7 Turbo II - sold
1990 325iComment
