Strict budget, slow restoration. *Now with moar budget*
  • kronus
    • Apr 2008
    • 13032
    #706
    so you've put your blingy suspension and then didn't tell us how she drives? come on dude
    how fucked are the old konis? are they rebuildable?
    cars beep boop
    • Wh33lhop
      • 11705
      #707
      Because it drives horribly, lol. Driveshaft is flopping around. Ordered a new giubo and CSB for it but I suspect I will need a reman'd driveshaft as well. When that is done and the rears ASTs are on, I'll take it to get an alignment and THEN come rave about it. Deal?
      Old Konis seem to have no gas charge left. Some of them still do general dampy things though. They are rebuildable but likely not for lemons car prices.
      Also, need to buy wheel bearings and repack with redline grease. Mine have a little play in them.
      paint sucks
      • canakami
        • 743
        #708
        So....we can haz updates?
        Always chasin'
        • illest318i
          • 1472
          #709
          Updates?
          IG: @_j.wn
          • ak-
            • 12422
            #710
            Video of driveshaft flopping around because of reasons? ;D
            1991 325iS turbo
            • serdar255
              • Feb 2013
              • 395
              #711
              I need updates, for reasons. ;D if you know what i mean ;D
              image (10) by serdar.gurhan, on Flickr
              PM me for custom shift knobs and stickers!
              Originally posted by marshallnoise
              You ain't done working on a car unless you are bleeding.
              • tinkerputzer
                • Jun 2008
                • 508
                #712
                I think he's showing off with his new dampers at solo nationals in lincoln :)
                • Wh33lhop
                  • 11705
                  #713
                  Actually the driveshaft is good now. Gave it a used DS with new CSB and giubo, no more flaccid floppy shaft. ;D
                  Ha! No point in taking this thing to nationals, it's nowhere near competitive in SM. I autox it but it's not built to any class.
                  Also my shocks are at elephant awaiting return shipping. Make sure you have adequate droop travel if you get ASTs. I had to lower it another inch after it topped out and they started making funny noises.
                  paint sucks
                  • tinkerputzer
                    • Jun 2008
                    • 508
                    #714
                    Werd. I'm in the same boat. Though i've never been to an scca solo event, i autox with the local porsch club and a lot of the scca guys run with them too. After seeing some of the cars that i'd be in SM with i realized my car won't be remotely competitive. I just try to have fun and close the gap between the top guys.
                    Dang that stinks. How much travel each way do AST's have when they're at ideal ride height? I'm currently having some ix bilstein inserts revalved and was planning to set it up to have 2.5" compression tavel and 2.5" droop travel at my ride height.
                    • Wh33lhop
                      • 11705
                      #715
                      Spring swap! New swift 780# 60mm (5")
                      vs old rear 600# 2.5"
                      Old front 450# vs "new" front 600#
                      Cam swap and vanos!
                      pulling the last bearing cap... slowly
                      cam trays and lifters (didn't touch em just took a cool pic)
                      M50 cam right vs S50 cam left.. there is a noticeable difference in the shape of the lobe. Check out how pointy the M50 cam lobes are vs. the S50 which are a lot more rounded.
                      New chain tensioner
                      Vanos piston
                      Installing new vanos seal from Beisan Systems
                      Aaaaand... on
                      later/S50 style cam dowel vs. early style. I reused the early style... don't do this. Get a later model washer stack for the intake cam sprocket if you are doing this cam swap.
                      super official cam timing check... turns out this isn't even the right way to check it. I realized later that the "squares" on the back of the cams aren't perfectly square. What really matters is the right angle between the head surface and the upright surface on the square. Unfortunately the actual official factory cam timing blocks don't fit my car due to lack of space, so we had to do it this way.
                      S50 cams in.. new vc gasket.. good to go
                      Donezo
                      Lot more pep up high now. Tune is on the way as well as the updated intake sprocket washer stack ($100 for three washers... ugh)
                      paint sucks
                        • 37834
                        #716
                        Nice job on the upgrade yo!
                        Grover Beach, California
                        BimmerHeads.com
                        • ngampleh
                          • Jul 2012
                          • 466
                          #717
                          what's problem with GC eibach spring?
                          or you just wanna upgrade it to stiffer one
                          great job buddy ;)
                          [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                          [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                          Transaction Feedback
                          • cyberkaa
                            • 1698
                            #718
                            Makes good noises (minus the rattle).
                            Can't wait for the tune for moar powar!
                            -Kalim
                            British Racing Green, IE Springs/Bilsteins, IE exhaust, IE SSK,
                            Momo shift knob, Miller MAF conversion, K&N intake,
                            Blackworks Aluminum Radiator, 5MT swapped,
                            Ellipsoids w/DDM HIDs, OEM Recaro Sports, Momo Mod07 Wheel,
                            Drilled+Slotted Rotors, Alpine HU/Amp/speakers, 12" enclosed sub
                            • Wh33lhop
                              • 11705
                              #719
                              Woo!
                              Handful and a half right now, it has no alignment (It has a Wh33lhop "good enough" alignment) so it oversteers everywhere.
                              Besides that I have fixed a few things and changed the springs to 600/780 and have the ASTs on 8 clicks. Biting at the heels of a few slick-shod Evos at that autox.
                              paint sucks
                              • tinkerputzer
                                • Jun 2008
                                • 508
                                #720
                                Great driving! Car looked very composed throughout the course.
