my own personal hell
This topic is closed.
  • whatt18yahoo
    • 619
    #916
    you do understand that i am building a new plenum, right? probably not cause you read 1 in every 10 posts like the rest of folks on here
    • Bimmerman325i
      • 6854
      #917
      I hope so, your first one was an abortion.
      2017 Chevrolet SS, 6MT
      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
      98 M3/4/5 (stock)
      • Iain
        • Oct 2005
        • 2815
        #918
        *edit*
        I am dumber for actually posting in this thread. I am getting out while I can still tie my own shoe-laces together and speak to women, unlike the OP.
        Pork Hunt Motorsport
        eBay is like the summit racing catalog for today's special Olympics crowd
        • Mstngcobr761
          • Apr 2008
          • 557
          #919
          Originally posted by Iain
          *edit*
          Just spit my coffee out...
          • whatt18yahoo
            • 619
            #920
            Originally posted by PeaveyBassist
            ITB. Ran great. I used Motronic 1.3 with a RRFPR and 19 lb injectors. I attached the TPS to the back side of the throttle assembly by the firewall. I needed money for a while so I ended up selling it to a guy in Sweden. Its now on his turbo m20 car that makes 700hp. He has a setup that is similar to your's actually. Just needs the right tuning and boost to get that power.
            the way my setup it the tps is by the radiator how was yours by the firewall? i thought these throttlebodies were the same what year were yours? can you clarify the rr in rrfpr i assume this is a kind of Fuel Pressure Regulator? was the motronic 1.3 a stock ecu? how did you monitor the air input?
            i am pretty sure that the sensor on the throttlebodies is a throttle position sensor and not a switch do you know for sure? i can take pics if it helps you.
            • PeaveyBassist
              • Sep 2004
              • 3511
              #921
              I modified them to have the TPS by the firewall. Easier and cleaner looking IMO. I modified the pivot rod for the throttles to go into the stock TPS and mounted it on that side. RRFPR is Rising Rate Fuel Pressure Regulator. Fuel pressure goes up when vacuum goes down. Motronic 1.3 is the stock ECU and harness from the latest model e30 325i. I monitored air input with a GM Map sensor with some trick electrical stuff, that George Graves made me, in the harness to use the stock ECU. It worked very well. I had a built 2.8L M20 with a 288 Shrick cam with that setup that put down 215hp at the wheels.
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • whatt18yahoo
                • 619
                #922
                do you have pics of your throttle linkages? this is something that has been causing me some restlessness (mostly due to space issues).
                well i just ordered the last of the parts for this setup (hopefully cause fittings are expensive) i have to go to lowes tomorrow and pick up some round stock so i can make my vacume rail and fuel pressure regulator adaptor (honestly at this point it might just have been cheaper to order the nuke rail but the rest of the system won't support it so oh well) in any case the parts are ordered, and i'll have pics when they get here, believe me i cannot wait. oh and if anyones offended by my exhaust now just wait til you see what i got coming lol it's going to be insane i had no idea that anyone made something like this. lol
                • lukem23
                  • Mar 2008
                  • 296
                  #923
                  This is a fuckin' shame. Waste of an E34.
                  • SamE30e
                    • Sep 2007
                    • 4319
                    #924
                    I just read this whole thread. I think my IQ dropped.
                    But I am anticipating moar!
                    1985 325e 2.8 Turbo VEMS
                    • dranttna
                      • 127
                      #925
                      this thread caused a lean-missfire in my brain. ouch
                      325es/24v's/20psi/meth injection/
                      • JTapper
                        • Sep 2009
                        • 847
                        #926
                        Are you fucking serious?
                        You're building a boosted M20 with ITB's, you're a supposed fucking engineer, and you don't know what a RRFPR is?
                        Wow.
                        Fucking wow.
                        I nominate this thread of the decade right here...
                        Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                        • accident
                          • 7303
                          #927
                          at the risk of sounding like a noob, what is MTI?
                          Moral of this story?
                          • NC325iC
                            • Mar 2004
                            • 6565
                            #928
                            its multi throttle intake, dont know why he calls it that when each cylinder has its own throttle body, making them individual throttle bodies aka ITBs
                            • whatt18yahoo
                              • 619
                              #929
                              Wow.
                              Fucking wow.
                              hey i don't get into acronyms and most of the time while reading this i've been drinking some guiness. so back off buddy
                              the main difference between MTI and ITB is a plenum in which or before which airflow is monitored, thats about it, ITB can have a plenum but not air monitoring in the plenum. thats the key - where the sensor is
                              • Bishop
                                • 4913
                                #930
                                So... You're finally admitting they're the exact same thing, it just depends where you tap for a sensor?...
                                PM me for detailing services in the Longmont / Boulder Area in Colorado!
                                Originally posted by DTM190
                                "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
