Won't be slamming this one... 88 325iS Build Up
    • 37834
    #196
    Originally posted by Matt-B
    or an 84-85 318i front console. only 2 button holes
    Actually all early model 2 door cars only had 2 holes.
    Grover Beach, California
    BimmerHeads.com
    • D-rock
      • 714
      #197
      Does the subframe bushing make a HUGE difference?
      Nice work keep it up!!!
      • dinanm3atl
        • Feb 2007
        • 7305
        #198
        I wish I knew... I haven't driven the car yet! roflmao
        Jumped into the garage this evening and started the stereo clean up. Zapco I-Force installed. Setup/Glued the tweeter housings. Trimmed wiring, tucked wiring and reinstalled the front kicks and underpanels.
        And my 'helper' barely lasted for half of the process.
        • dinanm3atl
          • Feb 2007
          • 7305
          #199
          Ground control sent me a teaser shot before they boxed up. Then I installed my urethane boots for the control arm/tie rod ball joints. I ordered them because I knew my boots on my new parts would get messed up while swapping suspensions. Glad I did. Put much more grease into the pocket/boot. Happy to have done this. Tweeter housings finished and installed. My trim pieces are coming together(before picture and after posted last)
          Ground Control Teaser
          Urethane Boots
          Tweeter Housings installed/done - Looks pretty stock
          Before... and now... looks WAY better. Unfortunately my plastic had started to break down so it isn't 100% smooth but is worlds better.
          And now... yum!
          • Gnarles
            • Dec 2008
            • 342
            #200
            Where did you get those urethane ball joint boots? How is the fitment with them?
            • dinanm3atl
              • Feb 2007
              • 7305
              #201
              BMP. I wish I would have gotten their FULL kit and done the other boots but the control arm is already installed. It was 12 dollars or so for 4 boots AND they included grease(which I didn't even know).
              Really happy with them!
              • TrentW
                • 2815
                #202
                Are there clips that hold the urethane boots on, or what seals them?
                Duplicolor Trim Paint on the bumper pieces? Turned out nice.
                • dinanm3atl
                  • Feb 2007
                  • 7305
                  #203
                  There is no 'ridge' like a rubber boot. It will go down and it stays all by itself. Once you put the spindle on it will be applying pressure down and all set!
                  SEM Trim. Turned out quite nice. I want to pull the door trim as well but might try forever black on it.
                  • TrentW
                    • 2815
                    #204
                    FWIW I've not had good luck with Forever Black.
                    • dinanm3atl
                      • Feb 2007
                      • 7305
                      #205
                      It did work. It HAS to be CLEAN. VERY clean to work. So use the cleaner that comes with it. Maybe even alcohol before the cleaner in the kit. I decided against using it completely as my trim pieces were sun baked and starting to pit. With the adhesion promoter and a couple coats of SEM Trim it has mostly hidden that.
                      • jefffribourg
                        • Nov 2009
                        • 127
                        #206
                        whats the body color? do you have the paint code by chance?
                        • dinanm3atl
                          • Feb 2007
                          • 7305
                          #207
                          Lachssilber. I think it is 203...
                          50% of the final puzzle pieces JUST arrived! Just waiting on UUC and this thing will be DONE. For now!
                          And.... lunchtime I get these on there and we are inching closer!
                            • 37834
                            #208
                            That's some purdy shit.
                            BimmerHeads.com
                            • Cabriolet
                              • 9620
                              #209
                              i want!!!
                              Much wow
                              I hate 4 doors
                              • Bishop
                                • 4913
                                #210
                                Did they redesign the camber plates again? I don't think those look like the ones I have
                                PM me for detailing services in the Longmont / Boulder Area in Colorado!
                                Originally posted by DTM190
                                "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
