Brianna GPs SpecE30 build for KishG
  • Spiff325iS
    • Jun 2004
    • 1263
    #31
    Do most SE30's remove the heater core? I figured it was usually all the interior bits + tar and the AC unit, and maybe tar in the trunk too.
    The Red Dragon V.5 1991 318iS / 2013 F800GT
    "You gotta fix the nut behind the wheel before you fix the bolts on the car"
    • kishg
      • Sep 2006
      • 2624
      #32
      Some do, some don't. it's another potential failure point though. we'll fab up something with an inline blower to get air onto the bottom of the windshield for rainy days. shampoo works well as a defogger too :)
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • Dave
        E30 RAT
        • 11675
        #33
        a lot of guys removed the tar, and then later wished they had not.
        I think it depends alot on the weight of your cage and driver. A buddy of mine lost the chance to win the regional title this year in May when he was a couple gallons of fuel underweight and was selected for impound after the race. A shame as he is probably the fastest driver in our region. (Though the next fastest guy is darn fast as well, and is a deserving winner).
        The approach I am taking in building my car is to wait until it is "complete", then weigh it and look for places to take things out if needed. I carry enough ballast on my own . . . :-)
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • ZM Blue Devil
          • Dec 2006
          • 13836
          #34
          Time to take the engine/trans out...
          Levent
          %20levent@gutenparts.com
          Ladies:
          • ZM Blue Devil
            • Dec 2006
            • 13836
            #35
            Out...
            When you see it you will $hit bricks.
            Levent
            Ladies:
            • ZM Blue Devil
              • Dec 2006
              • 13836
              #36
              Cant wait to clean the bay out... Who ever invented the pressure washer I salute you....
              Before...
              Levent
              Ladies:
              • ZM Blue Devil
                • Dec 2006
                • 13836
                #37
                After...
                Levent
                Ladies:
                • e30Rob
                  Master of Adaptation
                  • 1182
                  #38
                  holy shit that thing was dirty in there...nice work!
                  Need Custom spacers and adapters?
                  PM for information
                  • Joe318is
                    • Sep 2005
                    • 6451
                    #39
                    ah, that pic its a little scary
                    Originally posted by vlad
                    • e30guydownunder
                      • Jul 2008
                      • 874
                      #40
                      i didn't shit bricks, but i laughed.
                      Subscribing on this one
                      - Chris
                      Project M42 - 255 @ 19 psi
                      • Stu
                        • 4083
                        #41
                        Damn, just spent 20+min on a response to this only to lose it by the computer! Great to see GP do a SE30 (especially swap) build for next year. I do worry about ballast using a 318is chassis with no trunk tar and no sunroof equipment, however. It seems that the SE30 powers that be have made it feasible to only use a standard '87-'91 325i/is car. Early cars arn't competitive due to no ABS and 318is/M42 cars due to restrictions (A caged 318is is 100+ over min weight with full interior).
                        Early on, rules were that ballast was either in the standard 14" spare (~30#) or aft the firewall but forward of the passenger seat, so basically all the weight went to the passenger footwell. Now it appears you can place it anywhere aft the firewall but within the four points of the passenger seat. The 125# max might be an issue in the case of a no-sunroof car. Hoping that all pans out well for you guys and I'll definately be watching the SE30 2010 ...as always. : )
                        This is my understanding of the weight rules...SE30 guys, correct if wrong!
                        9.3.13.2. Ballast is permitted, and shall be securely mounted in the passenger foot well, aft of
                        the firewall, and shall be forward of the passenger seat. Alternatively, ballast may be
                        mounted using the passenger seat mounting points, if the passenger seat is removed.
                        9.3.13.2.1. Ballast shall be in segments no heavier than fifty (50) pounds.
                        9.3.13.2.2. Ballast may not exceed one hundred twenty five (125) pounds maximum. Spare
                        Tire weight per 9.3.9.7 is considered separate from this rule and may be added in
                        addition to the allowed 125 pounds.
                        9.3.13.2.3. Each segment shall be fastened with a minimum of two (2) one-half (1/2) inch
                        bolts and positive lock nuts of SAE grade 5 or better unless the ballast is mounted
                        using the four (4) passenger seat mounting points and replacement bolts, and shall
                        utilize large diameter, load distributing washers.
                        9.3.13.2.4. Holes may be drilled in the passenger foot well floor pan for purposes of
                        mounting the ballast and the floor pan may be reinforced for the same purpose
                        • kishg
                          • Sep 2006
                          • 2624
                          #42
                          your interpretation is correct stu, however, i don't see it being too much of an issue once the cage and all the rest of the gear is in. #2750 shouldn't be hard to do, we're keeping most of the interior sound deadening and the spare in the trunk.
                          '91 SpecE30 #523
                          128290
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #43
                            min wt...
                            ..great thread.......
                            for those who havent met Kish...great guy.........
                            and meeting min. wt. will be the least of his issues.
                            • kishg
                              • Sep 2006
                              • 2624
                              #44
                              haha.. tks joel (i think) ;)
                              '91 SpecE30 #523
                              128290
                              • Stu
                                • 4083
                                #45
                                I goofed my numbers thinking about your car. I was thinking it needed to be 2600 with driver since it's a 318, I forgot for the moment that it was going to be an M20 car. Shouldn't be an issue like you said.
