Got bit by the turbo bug.
  • yobless
    • 360
    #91
    E85 is the stuff... I use to boost 28lbs on my Evo running the corn juice.
    Nice build up
    • e30polak
      • 6136
      #92
      Hey Nigel, finally took a peak at your thread again, and WOW!
      Mad props on all the fab work! That's awesome that you had the opportunity to learn on this car.
      Car is a lot of fun, and will be a beast when you up the boost with longer gears! ;)
      INSTAGRAM: @UNDR8D_EMPIRE
      • einstein57
        • Jun 2007
        • 10780
        #93
        Picked up these little puppies to shield the spark plug wires from the wastegate. The WG currently touches the wire.
        www.gecoils.com
        • ethrtyiS
          • 8147
          #94
          post up an engine bay shot sir.
          '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
          my feedback thread
          • einstein57
            • Jun 2007
            • 10780
            #95
            Never the feds are watching. We all know what happens when they find out
            www.gecoils.com
            • ethrtyiS
              • 8147
              #96
              awh...
              my feedback thread
              • einstein57
                • Jun 2007
                • 10780
                #97
                So i got tired of having to have my EMS dangle un mounted in order to do any tuning so i decided to do something about it. After coming up with many elegant and simple solutions i decided to do the most elaborate and expensive way possible. lol. Excuse the crap photos and work station. My desk was taken over by a six year old.
                So the first thing you have to do to modify an existing completed MS unit is to de solder the db9 plug. I fount the easiest way was to pop off the back and heat up and pull each pin one by one.
                Next was to modify a idc 10 plug to work on the board. I removed the # 10 pin and bent the remaining pins to fit. Pins 1-5 need to be spead apart and 6-9 need to cocked over. (no homo)
                Then i soldered in place and test fitted idc to db9 cable. Now i could have stopped there but that would have been to easy. So i decided to make an extension cable so it could be remote mounted anywhere in the car. Almost everything used had to be purchased in bulk so i have enough to make 9 more kits if anyone is interested.
                www.gecoils.com
                • ethrtyiS
                  • 8147
                  #98
                  ^ very good work. i like that idea of the ashtray plug and play.
                  my feedback thread
                  • einstein57
                    • Jun 2007
                    • 10780
                    #99
                    If you ever wonder why people say "use this tune at your own risk." Needless to say CA has crap gas and we need our own special tune. Unfortunately the moment i changed my timing maps to IXERS map my computer took a dump. So the two weeks i drove around waiting for new parts and software created irreparable damage which led to a blown head gasket once i did correct the tune.
                    Took everything out at once. Seemed like a good idea until i picked it up off the block. Lol. But it was to late to set it down and risk causing further damage
                    New parts
                    I had the head rebuilt and its back on the car. Did not take any pics cause i was trying to beat the rain.
                    www.gecoils.com
                      • 37833
                      #100
                      That sucks man! Glad you're fixing it quickly.
                      You got the wrong oil filter. ;)
                      Grover Beach, California
                      BimmerHeads.com
                      • einstein57
                        • Jun 2007
                        • 10780
                        #101
                        Lol. Thats for the e60.
                        www.gecoils.com
                        • einstein57
                          • Jun 2007
                          • 10780
                          #102
                          So after much deliberation i finally put a gauge in my boost pod. Not sure i'll keep this or the custom gauge i made. I like this one cause it goes to 20psi and i plan on running 18lbs. The one i'm making fit the e30 only goes to 15 and does not show vacuum.
                          www.gecoils.com
                          • ethrtyiS
                            • 8147
                            #103
                            looks good. you cant use that gauge wherever your making it go?
                            my feedback thread
                            • einstein57
                              • Jun 2007
                              • 10780
                              #104
                              Basically i'm too lazy to finish it. Lol. Plus it only goes to 15psi. I'll probably sell it when its done. It has orange LEDs to perfectly match the interior lights and a glass needle like the e36s
                              After working on pulling the head and such i decided my intercooler plumbing needs to be more stealth on the drivers side. So i'm going to take a shot at making it more like e36 bottom mount setups. Here is an inspiration pic from AA.
                              www.gecoils.com
                              • mwscircle
                                • Oct 2009
                                • 92
                                #105
                                wooott is it running yet??? I need to pay a visit to you and Castros soon
