Erik's M3 track car thread
  • erik325i
    • Jan 2005
    • 3567
    I finally decided to make a thread about my M3 build. I hope you enjoy the thread...
    Here is the first pic of my M3 once I received it in May '06. I bought it from a forum member on s14.net as a rolling shell (body, suspension, and a couple boxes of misc parts).
    If anyone local wants the wheels in the above pic, I still have them and you can have them for Cheap. PM me.
    I originally planned on dropping in a low mileage s50US motor in the car but I ended up changing my mind, sold the US motor and had a Euro s50b32 shipped to me from the UK. I received the motor somewhere around September '07
    Motor pics:
    After removing the AC compressor and emissions pump, I had to make a plate to block off the opening on the exhaust side of the head where one of the emission piped bolted to.
    As with the US motor swap, you must use the e34 m50 oilpan, pump, and pickup tube to clear the subframe. Some people have been able to keep the Euro dual pickup pan and pump setup, but it requires a lot of fabrication to the pan and subframe to get it to fit.
    I installed the s54 crank pulley since it is smaller/lighter and will free up some extra power by underdriving all of the accessories.
    s54 pulley on left. s50b32 pulley on right.
    Installed a Z3 steering rack to my reinforced subframe. I put the spacers below the rack, in order to raise the rack up and reduce bump steer.
    Got the motor in the car late one night. Was using the black cylindrical e28 m5 motor mounts. The motor dropped in so easily it was funny.
    After doing all of the rewiring, I got the motor fired up at the beginning of '08. Still had a lot of work to do (still no brakes at this point). My goal was to get it running well enough to make it to Bimmerfest '08.
    I decided I wanted to run a side-exit exhaust, so I started cutting away and building the tunnel for the exhaust. Our welder welded everything together and build me the exhaust. It is dual 2.25" all the way back to a 2 in- 2 out Magnaflow muffler
    These pictures show the clearanceing needed for the headers to clear the subframe:
    I bought the Brembo GT brake kit. (4 piston calipers, 13" rotors) To put over the brakes, I got a set of 18" BBS RC's wearing 245/35-18 tires.
    I also got the dual master cylinder boosterless setup made by Mike B. I also removed ABS at this time.
    I ended up not being able to take my car down to bimmerfest '08, so I borrowed the brother's 318is and drove down with that:
    July '08
    I finally got my car sorted out enough to drive it around the parking lot. I loaded it into the trailer and we headed up to Thunder Hill for a track day the next day. Let me emphasize the fact that I got the car driving around for the first time the day before I took it to the track. I didn't push it too hard at the track, as I was using it as more of a testing day. I expected things to break/fail/ or somehow go wrong. It lasted all day long with no failures besides the IE urethane motor mount melting and coming apart.
    My M3 and brother's 318is:
    The boss bought me a carbon fiber intake plenum. Here is the test fitment.
    I had to fabricate a bracket to hold the throttle cable, and figure out a filter setup.
    My boss also bought me the VAC billet oil filter housing. I built up my oil system as follows:
    VAC piece > remote mount oil filter > e28 m5 oil cooler. Also, I plumbed in a 2qt Accusump oil accumulator. which I located in the back seat area. Everything is hooked up with AN10 stainless lines.
    At this point, I decided to have a cage built in the car. It's a little basic right now, but I still plan on adding some more (gusseting/diff mount/strut towers).
    I removed the whole sunroof cassette and bolted in a carbon fiber sunroof filler panel before doing the cage.
    I started sanding and smoothing out any dings in the body.
    Bought an MA Shaw evo rear wing
    After many hours of sanding/priming/light body filler/more sanding/more priming, I finally trailered the car to Maaco. $300 later, I had the whole car sprayed including 2 spare fenders. I had all glass/trim removed, and had the fenders, bumpers, sideskirts, rear wing painted off the car. The results were excellent.
    M3 is mine (obviously), white car with silver Borbets is my brother's, and white car with black Borbets is mine:
    I had a windshield installed the day we left for Bimmerfest.
    I took a big risk, and drove the car down to Santa Barbara for Bimmerfest '09.
    Had lots of that ^^^
    My M and the ladie's 135:
    Just recently, I made a set of Lexan rear quarter windows.
    I am currently working on an electric water pump setup, and an alternator relocation.
    I am also working on a fuel surge tank in the trunk with all new AN lines, Bosch Motorsport 300 lph pump and an adjustable fuel pressure regulator.
    Once I finish all my pending projects, I need to install my fiberglass dashboard, Stack instrument cluster, Tilton pedal box, and rear Brembos.
    It's hard to know when to stop.
  • TheB1G Lebowski
    • 593
    Great job. I love the exhaust. Any plans on filling in the back bumper?
    1989 325i - sold
    1987 RX-7 Turbo II - sold
    1990 325i
    • erik325i
      • Jan 2005
      • 3567
      I will be chopping out the lower part of the rear bumper to make room for the rear diffuser so no need to fill it.
      Erik
      • Holland
        • Nov 2008
        • 7212
        I never heard of the smaller pulley upgrade before. How does it feel to have a real M motor in the car?
        Originally posted by DEV0 E30
        • E30SPDFRK
          • 5709
          Awesome. I've always seen it in your sig and wondered about it.
          Any reason for the side exit besides for weight/packaging?
          Byron
          Leichtbau
          • richardb
            • 2121
            Damn, nice work! I never would have guessed a Maaco paint job! How much was the rolling "shell" back in 06?
            Transaction Feedback!
            • HarryPotter
              • Jan 2010
              • 3642
              Probably cause it also looks badass.
              Love the car.
              John F. Kennedy
              • reelizmpro
                • 9544
                What did you use for engine management?
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • erik325i
                  • Jan 2005
                  • 3567
                  Feels amazing. Oh, and I didn't mention it above, but my brother's 318 seen in some of the pics above is getting the same motor. We should have his in by this Bimmerfest.
                  Love the car.
                  Thanks
                  If I recall correctly, I paid $3000 and another $975 to have it shipped here from Texas.
                  Stock for now.
                  • White325is
                    • Oct 2006
                    • 5947
                    Looks good man. Was that Doms old motor?
                    • erik325i
                      • Jan 2005
                      • 3567
                      No, I do have Dom's old motor, but that is going into my brother's white 318is seen in some of the pics above. I also have Dom's old car, which I have pictured above as well.
                      Erik
                      • surebimmer
                        • Jan 2004
                        • 978
                        Looking good erik. Where's the electronic water pump from? Custom?
                        • Blip Bavarian
                          • 236
                          Your car is straight business dude. Very well done.
                          Do you have anymore info on the Mike B boosterless brake setup? How do you like it? im trying to decide what brake setup to run with LS1 swap.
                          My LS1 swap thread:
                          http://www.r3vlimited.com/board/showthread.php?t=160030
                          • erik325i
                            • Jan 2005
                            • 3567
                            I got the electric water pump from:
                            The stock water pump housing had all the guts pressed out, chopped shorter, and welded shut. Alex Lipowich helped me out sourcing this.
                            Thank you. I like the setup a lot but it has a pretty firm pedal, so you may not be used to it. I guess smaller masters would have given me a softer pedal. When on the track and the brakes are warmed up, it feels great.
                            I'm going to be swapping to a full tilton pedal box when I have time, so my current setup will be for sale eventually.
                            Erik
                            • She loved E
                              • Aug 2007
                              • 363
                              nice ride. looks like it means bizness.
                              M119 M42 M62 S52 S62
