Did you ever get this thing on the dyno?
Budget M42 turbo build
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
No, I never did. At some point I really should, just to see what kind of numbers it's putting down. I also really need to post some updated pics...looks like the last ones I posted still had the sketchy wastegate piping and such.
electronic boost control parts just came in, by the way. :DComment
With 7.5 psi, it has been extremely reliable. I've put something like 30k miles on the turbo setup so far, with a lot of autocrosses thrown in. It has also done maybe 400 miles on the track as well, and the only issues I've had have been high oil temperatures and cooking the brakes, the latter of which is no fault of the turbo.
bump updates?318iS Track Rat :nice: www.drive4corners.com
No one makes this car anymore. The government won't allow them, normal people won't buy them. So it's up to us: the freaks, the weirdos, the informed. To buy them, to appreciate them, and most importantly, to drive them.Comment
Wow, only been a few years since I posted here last...
Most recent update is that I took the car to Indianapolis Motor Speedway for a track weekend (3 days) with PCA. I managed to blow up a CV joint, lose a few manifold bolts, break the flange off of my new exhaust manifold, crack both front brake rotors fairly catastrophically even with ducting, and burned through more than half a set of PFC08s. I also burned a hole in at least one piston due to detonation, so I'm in the process of pulling the engine out for a rebuild. Rather than a 6 cylinder swap, I intend to keep the M42 and will likely drop the compression and run a bit more boost.
I think I underestimated the power this car was putting out, as with 7.5 psi and a full interior, it wasn't much slower than a well-built caged and stripped S52 E30 with all the usual bolt ons in a straight line. However, I was obviously running too much timing. The plus side is that, with a new custom oil cooler setup (I'll have to add pics here eventually) I'm keeping temps right around 230F. Intake air temps are also staying within 40F of ambient (which is good; I try to stay within 60F as a goal), coolant temps never went over 211F, and the rest of the car did great.
Here's a quick video:
Okay, I give up. No issues embedding on other forums, but it's not working here. Here's a link:
Thanks for sharing, whats your timing map look like?
All your pictures are down :/318iS Track Rat :nice: www.drive4corners.com
I will have to grab a pic of the maps when I get home from the holiday. I'm using table switching with the primary (vacuum up to atmospheric) table modeled after an M50. The secondary (boost) table basically just pulls a degree of timing per PSI of boost from there.
When I was at the track, I had noticed some detonation around peak torque and ended up pulling about 4 degrees of timing across the board by the time I thought I had eliminated it. It must have still been pinging some, but I couldn't hear it in the car. With no knock sensing, it's kind of a crapshoot. I had done most of my tuning on the street, but temperatures overall are somewhat lower, and I hadn't retuned when I built the new exhaust manifold. Since I've had it on the track numerous times with the turbo previously, I'm inclined to think that the new manifold for some reason had more back pressure or something, reducing cylinder evacuation efficiency and increasing knock.
I know all of the pics are down....unfortunately, I am one of the many Photobucket fee structure change victims. I'm not paying hundreds of dollars a year just to get my links back, so I at some point I'll have to rehost elsewhere and put some new pics up.
In the meantime, here's a pic of the car at Putnam:
I've finally torn the engine down after having very low compression after the IMS DE. For a 300k mile engine that has been rather abused, it looks fantastic inside. Cylinder bores are fine, head is great, and even the rod and main bearings are serviceable. The cause of the failure has been traced back to collapsed pistons, which is kind of an oddball problem.
My ignition map was overly aggressive, as I may have mentioned, and the result was a bit of pregnition. The M42's combustion chamber shape is limited by being a 4 valve engine, and the piston crown is also pretty old school compared to modern squish bands. As a result, you get localized preignition at the top and the bottom of the piston crown. Mine showed quite a bit of evidence of this, particularly on cylinder 1. I think the piston cooling nozzles (i.e. oil squirters) probably saved my life on this one, considering the oil deposits on the underside of the piston crown. There is no coking, but definitely evidence of heat. It's also kind of a circle of death once the deposits start, as they insulate the piston and hinder cooling. I've seen 20C changes in piston crown temperature changes just from a thin layer of oxidation in the engines developed for work.
So ultimately, the pistons got hot. The result is a slightly deformed top ring with definite evidence of wear, and completely stuck mid rings and oil control rings on all four cylinders. This is why it ran okay, but had a lot of blowby - much of the combustion pressure was going straight past the rings. Based on some FEA magic from a friend who does power cylinder development, it looks like excess heat and load can actually cause the ring grooves to collapse, which is what happened here. They're so stuck that I broke one trying to get it out, and I can't get the bit I broke back into the groove because it collapsed so much.
Fortunately, this makes the rebuild pretty straightforward. New pistons, rings, bearings, all the seals, etc. Also updating to an M44 oil pump and timing case slider instead of the early M42 idler gear. Bonus nachos: with the engine torn down, I can tap the block for the oil drain instead of returning oil flow to the pan below oil level and get rid of my sketchy turbo oil drain vent setup.Comment
For your new pistons are you going with a different crown design?Comment
Good luck with the engine refurb.
Curious, how would one describe the sound of preignition detonation in an M42?sigpic
January 2012 COTMComment
Hey, decided to dig through some old forms and hopefully i can find some answers here. Just wondering what you did ecu wise for the m42. currently doing my own turbo build and i am stuck at this point?Comment
Woo it's been awhile since I've been around here. Unfortunately I have not progressed much with the engine build. Roadbook rally racing dirt bikes has taken priority and time.
In my case, it also didn't show up at lower intake temps on the street. It took higher intake temps running in boost for many minutes at a time to put it over the edge.
Hope I can help! I went with Megasquirt 2 running the Extra firmware. I've got two cars running MS2E now and have been very happy with them.Comment
