Can't wait to see this. I know it's going to be done the right way.
Budget M42 turbo build
Well, not much has happened recently, but megasquirt is assembled save for some of the in- and outputs. It works great and is going to be running MSextra 2.1.0 and will be tuned with megatune, as with most people. I'm going to try to run it with the OEM ecu controlling idle as well, just for convenience's sake, although the PWM valve shouldn't theoretically be too difficult to run with megasquirt. The coil drivers will be the factory grounding transistors wired into the Megasquirt controller, because I know they work and I already have 4 of them that I know work. Wiring might be interesting, though. I'm still between running wasted spark with the packs run in pairs or trying to rig up full sequential ignition, which, as far as I can tell, may not be much more difficult.
Also, I'm shooting for getting megasquirt operational in the car this weekend, but I'm not sure how realistic that is yet.
haha same. It does give one a sense of progress, even if there isn't any...
Well, Megasquirt is now completed. I have a little bit more work to do to get the coil drivers working, which may be why I'm not getting a tach signal. The other issue there, though, could be that it is a VR signal, and Megasquirt stimulators apparently don't do a very good job of replicating that signal.
Also, I just picked up a Dell Inspiron 8100 for $100 for in-car tuning purposes, so I should be all set to go for getting it wired this weekend.
Little update here; I'll get some pics up later. Still not sure what the deal is with the tach signal, but I need to build another VR circuit for the cam sensor and finish the coil drivers. I'm actually going to be using the stock drivers, for what that's worth.
The LC1 showed up yesterday, so that is being installed now. The control module is in the center console, and it will all be wired into the factory harness just to make it look pretty and such. I'm really hoping that the narrowband mode will work with motronic for a little while, though, untill Megasquirt is done.
LC1 is in and working after a few glitches. The module is under the center console, the access ports have been routed to the glovebox along with wiring for the inverter to power the laptop in the car. All of the wiring is into the factory harness, with the white and blue ground wires (LC1) soldered to one of the whites (pin 3 iirc) and the grey. The signal wire, is black, and is connected to the yellow output as a NB simulator for the time being. The brown output isn't used yet. Power is taken from switched power in the aux fuse box. The black calibration wire was extended and then run back into car to the center console. The LED and the switch are both under the ashtray.
Pics, as promised:
midway through the install
The glovebox
Nice and factory looking, just the way I like it. Minus the dirt.
So, you're going to be my "go-to-guy" when it comes to doing this myself? Love that you made it all look stock. Never anything better than keeping the refined elegance of an e30 in tact when you do some "serious" mods such as turbo's and stand alone management. What's your boost goals? I'm considering staying mostly stock engine management and running only 6-7psi.Need a part? PM me.
haha works for me; you aren't the first who has been interested.
Progress is coming along, but I don't really have any more pics. The adapter board is about half done and I have figured out how to wire the coil drivers, so those parts have been ordered.
I did some datalogging with the LC1, and it turns out that my engine runs an AFR of about 14.0 at a cruise and around 13.6 at WOT, so there should be a little power and perhaps quite a bit of economy to be gained just by going to megasquirt, assuming a good tune.
Well, the issue that has stalled my progress recently was my inability to figure out why my tach and injector circuits were flaky. For any of you using a stim to test DO NOT USE 9V BATTERIES! They die unbelievably quickly and don't quite have the juice to make everything run right. I'm using a 12v power supply now, and as a word of warning, the stim voltage reg will get a bit warm, so you can't leave it on all the time.
I got the first part of the MS adapter done, so now I have pickup points for the entire factory harness without having to cut everything up. This box will also contain the cam sensor circuit, and will have plugs running out of the case for the LC1, the Megasquirt module, and a pickup point for testing cam, crank, injectors, and coils. Note that the coil drivers are still on the board; one has wires hooked to it for testing.
Sorry, I've gotten a bit lazy with the updates, heh. Megasquirt should be installed and in the car by tonight, assuming that everything tests correctly. I have all of the wiring diagrams drawn out, so I will likely be scanning those in and posting them at some point for future reference. There isn't a whole lot to take pics of, but here are some. The first two are the adapter board with most of the wiring installed for the coil drivers, spares, the DB37, and the LC1. There are a few circuits on there for the PWM, the coil drivers, the cam input, and the relay running power to the drivers. The last two are of the MS unit.
Just a heads up... not sure of your power goals, but if you plan on more than 180 torque, you will need a new clutch soon. I don't know where mine is at, guessing 210rwhp and not sure on the torque, but my clutch lasted about 3 months before starting to slip. Now it slips really badly with 10psi of boost in 3rd, 4rth, and 5th.
Will follow as I am a sucker for a boosted m42... good luck, have fun, and keep up the good work."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
Megasquirt will be installed tomorrow! Everything is up and running save for the tachout circuit, which I can mess with later.
Also, I have discovered an issue, although I'm sure it's been adressed somewhere: how are you other turbo guys running your charge pipes from the IC to the intake around the ABS unit?
e30guydownunder-yeah, I saw your thread; looks like your project is just a wee bit more involved than mine though haha.
Schnitzer-yeah, I'll only be at 7.5 for the time being; I'll probly go with the metric mechanic flywheel later on when this one goes. It'll be a fair bit of time before the turbo is all done and such, though.
Originally posted by gearheadE30 View PostAlso, I have discovered an issue, although I'm sure it's been adressed somewhere: how are you other turbo guys running your charge pipes from the IC to the intake around the ABS unit?
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
