Budget M42 turbo build
  • gearheadE30
    • Jun 2007
    • 3734
    #91
    Thanks guys :). I think I'm going to end up putting the boost gauge in the driver knee bolster, left of the steering wheel. That way it's kinda hidden but I can still see it if I need to. I don't really want to cut up a nice airbag knee bolster, though...
    And the new trans from Bavarian Auto Recycling just showed up, so I'll be swapping that in sometime this week. It's gonna be nice to have 3rd gear and a synchromesh transmission again haha
    EDIT: more interesting news-the manifold doesn't fit with the AC compressor. The external wastegate mount has to go right there...
    So, should I just get rid of AC, which is a nice convenience that I don't use much, or should I make mounts to put it on the driver's side where the AC pump is, and get rid of AC? If I do the latter, it will be taking place a while after the turbo gets done.
    Project M42 Turbo
    • Danny
      • 14217
      #92
      Get rid of it. AC is for suckas.
      • Schnitzer318is
        • Jan 2008
        • 2057
        #93
        You're wrong there Danny. :)
        I know we need it here in SA where everyday is now in the mid to high 90's and going to get hotter.
        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
        91 318is Turbo Sold
        87 325 Daily driver Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        92 325ic Sold & Re-purchased
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • gearheadE30
          • Jun 2007
          • 3734
          #94
          yeah, luckily every day temps here rarely top 90, so it's not totally vital. Its just a very nice convenience... Wish I could keep it, but I'm not seeing a way right now heh.
          Project M42 Turbo
          • e304me
            • Feb 2006
            • 1374
            #95
            Updates!!!!
            Megasquirt writeup!!!
            also, what are you going to do for tuning? I am going to get the turboxs knocklite that i am going to leave installed, and some sort of mic headphone setup for when i am tuning
            • gearheadE30
              • Jun 2007
              • 3734
              #96
              Well, updates are kinda limited. I got the boost gauge in, and pics of that will be up shortly. I'm not too happy with the placement, but I do like how it looks where it is. It also doesn't waste any interior space. Its a little bit of a pain to look at, but I'm so used to looking across the car at my laptop that it's not a big deal. The backlight is also very bright, so it's pretty visible unless there is a lot of direct sunlight.
              I relocated the coil packs to the battery tray. Again, pics will be up soon. I don't have any pics of it all finalized, but you'll get the idea
              The oil pan is also installed, now with a (currently plugged) turbo oil drain and a temp sender bung. When I pulled the pan, both oil pump pickup bolts were loose, but all of the upper pan bolts were fine.
              The intercooler from the 740 is in the car with temporary ziptie mounts until I can find time to fab up some real sheetmetal ones. I figured I should probably wait until I have all of the piping finalized, as well as rerouting some of the wiring at the front of the car.
              Haha I'll try to get an MS writeup going soon, but I've been hella busy with work, and my GF is leaving this week for a month, so I need to get some quality time in there :).
              For tuning, I'm just doing the drive and tune route with my laptop, and be very conservative with the timing. I want to get the AFR very very close with reasonable timing before I spend the money for the dyno, which will take care of the finalized timing curves. Dyno time is pricey, haha.
              EDIT: pics. yeah, I know the first one sucks, haha. And the gauge is turned off in the second pic.
              Project M42 Turbo
              • e30guydownunder
                • Jul 2008
                • 874
                #97
                Nice work mate, pretty much exactly where my coils are currently as well :) Keep up the steady progress. You will get there.
                - Chris
                Project M42 - 255 @ 19 psi
                • einstein57
                  • Jun 2007
                  • 10780
                  #98
                  I was thinking about putting my coils there when I go wasted spark but placing them inside a ecu box out of a different car. Maybe e34 or something. I'll have to hit up the yards and see what's availalbe and how well it fits.
                  www.gecoils.com
                  • TooTall90
                    • 338
                    #99
                    good work so far, i cant wait to see more progress!
                    anyone ever retrofit the e36 coil pack into an e30? i think it would really clean up the engine bay. is it even possible? im talking about #1 in this image.
                    Strategic Alpine Command:...sig loading
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      #100
                      I actually seriously considered that (to the point where I bought a used module haha) but the wiring is different and I didn't feel like messing with it.
                      As far as updates go, not much. The manifold is going to the shop next week for wastegate relocation so I can save the AC, I found a shop to make AC lines, and I'm getting ready to buy some adapters so that I can get the intake more or less figured out.
                      Project M42 Turbo
                      • Schnitzer318is
                        • Jan 2008
                        • 2057
                        #101
                        Good for you. It would suck to lose the AC even if you guys have more mild weather than we do here.
                        Is that the boost gauge in your center console by the handbrake? I'm not a fan of that. Especially after the other 2 gauges came out so well.
                        Are you running MS2? Using stock ICV or 3 wire? I am going to give putting the stock 2 wire ICV another shot as I hate balancing the gas pedal at lights when I want to use the AC. Nothing worse than forgetting and having the car shut off on you because you didn't heel toe some throttle during braking.
                        91 318is Turbo Sold
                        06 4.8is X5
                        06 Mtec X3
                        05 4.4i X5 Sold
                        90 325i Sold
                        97 328is Sold
                        01 323ci Sold
                        92 325i Sold
                        83 528e Totaled
                        98 328i Sold
                        93 325i Sold
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          #102
                          Yeah, I know, I am liking the boost gauge less and less. Now I just need to decide if I want to lose another vent (the small one to the left of the wheel), if I want to put it in the knee bolster on the left side of the driver, or if I want to replace the ashtray with gauges. The last one sounds the best to me, right now. any opinions?
                          Project M42 Turbo
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            #103
                            I'll take pics of my new gauge setup. I moved mine from up top where the check panels are, down to the open area above the ashtray. Came out fairly well. Will post them here when I get them.
                            91 318is Turbo Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • e304me
                              • Feb 2006
                              • 1374
                              #104
                              any updates? I want to do this asap!
                              also what did you do with the check engine light? I'm gunna need to do something with that for emissions. needs to be on when the ignition is on then off when the car is running edit: looks like it has a check engine light feature!
                              • gearheadE30
                                • Jun 2007
                                • 3734
                                #105
                                yeah, actually haha. I have a track day on monday, so I had to keep it NA because I didn't have time for everything. I did, however, fabricate intercooler mounts, install an oil catch can, made a second temporary intake, got all the hoses and adapters that I need and a BOV line, did transmission seals and put new fluid in, and took the manifold to a welding shop to get the ball rolling on modifications. I should have everything ready to hook up by the end of July :).
                                Megasquirt is also getting continuous updates with tuning, and hopefully I can get a lot of ignition tuning in at Gingerman on monday. Progress has been hindered slightly by the addition of a WWII light aircraft tug to the garage along with all of my college preparations. I didn't know I had so many e30 parts that I needed to get rid of, hah.
                                Project M42 Turbo
