Vorshlag $2010 GRM Challenge car - BMW E30 V8
  • Fair!
    • Mar 2007
    • 202
    Project Update for Feb 18, 2010: With last week's Thursday work night snowed out (we had over 12.5" of the white stuff - a 24 hour record for Dallas) and some missed work nights over the holidays, the team was getting itchy. We had 6 of the $2010 Team members here Thursday night to turn wrenches on the E30 again - it was bedlam! :D I'm behind on posting pics so here goes:
    Chris and Paul pressing in the '95 LCAB bushings. We might go back with poly or Nylon (we'd machine them to save $). The "composite" bushings (aka: wood shim!) had to go
    We had 2 different teams working on different things to stay busy, and in less than 2 hours we had the pair of '96 M3 LCAs on, new offset '95 M3 bushings (eBay) in the LCAB "lollipops" in, the E36 steering rack installed, with trial fits along the way. We also decided to up the scheduled "first test" date by 3 months, including some road course testing (more on that at the bottom).
    Costas, Dave and Derek thrashed on the LCA's and E36 steering rack
    The old E30 steering rack brackets were bent up pretty well. Once we finalize the up/down location we're going to beef up the lower mount with some steel. Hopefully this will then withstand the higher cornering loads of 275mm Hoosiers at high speed track events.
    The rack mounts were cleaned and straightened
    The E36 rack has about 1/2" gap to the factory E30 mounts. This is nice - it will allow us to shim the rack up/down to correct for bump steer
    The holes on the E36 rack lined up perfectly with the E30 brackets, and the end-to-end length was fairly close to the E30 rack. The E36 rack moves the power steering hose ports to the outside of the rack, away from the V8 motor we're adding. Its also a lot faster ratio rack than anything that came in an E30 - and was a freebie! A cool customer who had swapped in a Z3 rack into his E36 track car donated this well used (275K mile!) E36 325is rack to the cause. Don't let the cleanliness fool you - that's just my pressure washing and OCD detailing on what was a dirty old rack. :p
    The '96 LCAs on and the rack in place
    The wheel has indeed moved forward, but as expected after reading the great write-ups on these swaps on R3vlimited forums, this is far from perfect. The right fix probably does involve E36 M3 spindles, but we cannot and will not do that for this project car. Why? It will pound our budget, and doesn't fit the theme for this car - a fast car built with cheap parts that nobody wants.
    Going to E36 M3 spindles mean we'd need M3 rotors, calipers, and more. We're not going to even try to pull that one over. The two sets of E36 non-M spindles/rotors/brakes we've picked up were free because nobody wants them, and that's why we're going to use them. The non-M E36 brakes are still 1" larger than the E30 4-lug garbage, so its still an upgrade. The stock 24" tall tires on the car now just barely clear the inner unibody structure at full lock, which they didn't even come close to doing before. If the shorter (275mm) Hoosiers can work like this, we'll keep it as-is. Otherwise we'll modify or build a LCA to correct for the E36 spindles in the E30 chassis. We came up with a game plan if this proves necessary, but we're going to move onto the rear 5-lug swap next, for now.
    more below...
    Terry Fair - www.vorshlag.com
    Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
    • Fair!
      • Mar 2007
      • 202
      And now some new parts we've acquired for the project:
      Derek scored this "sweet" eBay steering wheel. The 1.5" smaller diameter will help for auto-x and track use
      Derek also offered up a used steel Camaro driveshaft, which we'll use pieces of to make our driveshaft. Seats we're test fitting team members into
      So why are we worrying about better seats, now? Aren't the eBay reclining seats good enough for auto-x, drag race, and the car show? Well, these seats are as comfortable as sitting on a piece of plywood, and aren't up to snuff for track use, so they're going to be sold. Wait... did I just say TRACK USE? Why would we worry about that on a GRM $2010 Challenge car.
      Because we're going to take the E30 to the 2010 GRM Ultimate Track Car Challenge (UTCC) in July.
      Assuming everything goes as planned, we can have the car completed in time, track worthy/safe, and maybe even sorted. We had planned on going to UTCC this year with team member Paul Costas' ungodly fast tube framed GT1 car (see below). He went to the UTCC in 2007 and was very fast, but plagued by a rushed build schedule. He wants a rematch at VIR's big course this year. So since we're towing to VIR, and have a 2 car trailer... why not take the $2010 GRM E30! It made sense to me, at least after a few beers.
      Costas' GT1 Camaro
      So yesterday I talked to the guys at GRM and they loved the idea. Since a $250,000 Daytona Prototype won last years UTCC, its getting a little beyond "grass roots". Maybe bringing a dose of reality in the form of a $2010 crap box will slightly realign UTCC with the magazine that sponsors it? And it'll be a damn good shake down for the October $2010 Challenge event. I mean, if the E30 survives 150+ mph straight away speeds and corners at VIR, then it should withstand 5 drag runs and a few minutes dorking around in the parking lot for the $2010 Challenge, right? :D
      We're going to throw down the gauntlet on the GRM forums and challenge more $2010 Challenge teams to drag their low-buck builds to the 2010 UTCC, and Per Schroeder has offered up a free beer and a cheeseburger to the fastest $2010 Challenge car at UTCC. A beer and a cheeseburger? I've done crazier things than this for less.
      So we're upping the attention on the E30 project to add more emphasis on road course safety and speed. We're going to add a Kirk Racing 4-point competition roll bar for sure (ordering 5 of these units on Monday for various Team members' cars, including my DSP E46 project and the E30), as well as a good FIA harness (G-Force Pro 6-point). Neither of these items will count against our budget, according to the folks at GRM - whew. But the seat will... so we have to sell the eBay seats in the car now on CraigsList for maximum $$$ to afford one racing seat we'll need. The Pate swap meet is coming up so we'll be trolling the aisles for a good deal on an aluminum Kirkey or UltraShield seat, or maybe even a composite road race seat from Sparco or Cobra? We can only dream. :D
      The car has to pass NASA tech inspection before it can run at UTCC, so we'll try to finish it sooner than originally planned so we can run it at a local NASA Texas Time Trial event, and get a full tech inspection and a log book issued before we drag it to VIR in July. This moves up the schedule and ups the ante considerably, but our $2010 budget isn't going to change. Can we do it? Can we make a safe, sorted track car for $2000 that isn't embarrassingly slow? We'll see. We'd be happy if we go to UTCC and beat the bottom 3rd of the field, but even those cars are going to be stupid fast and have at least $30-40K+ in their construction. Time will tell if we bit off more than we can chew...
      After a noted engine builder stopped by last weekend and checked out our motor, the horsepower plans have ratcheted up a bit. He knows these motors better than almost anyone on the planet, had some really good low-cost ideas, and we're going to follow his advice. We aren't sharing ANYTHING about the motor until its in the car and running. The oil pan we need (and have horse traded 3 levels deep to get!) is arriving this week, then we can finally do our mockups in the car with the actual oil pan and trans we're running for the Challenge event. We've already done drivetrain mock-ups with.... another trans.
      No more details - I've already over-shared, so I'll stop there. Back to to the shop to thrash on my DSP E46. We spent a couple grand yesterday buying parts for that car, and I need to put the mountain of parts I already have here now to get ready for what's inbound. Then hopefully I'm going target shooting with McCall (haven't done that in 3 years). Guns and cars - not a bad way to spend a Saturday!
      Stay tuned for more.
      • Fair!
        • Mar 2007
        • 202
        Project Update for Mar 5, 2010: Wow, we haven't had an update since early February!? Believe it or not the GRM team has met every week and worked on the E30, and I burned the entire weekend last Saturday and Sunday, mocking up and building motor mounts and a transmission crossmember. The final parts are done and look great, if I say so myself. Of course I cannot show any of this...
        These pictures don't show much detail on purpose... and that's a borrowed trans.
        Last night we pulled the mockup drivetrain out, removed the borrowed trans, and started to tear down the engine for the last time. The modified oil pan was cleaned (yuck! it was like mud in there), the intake manifold was disassembled and cleaned, injector seals were checked and oiled, connecting rod and thrust bearing clearances were checked and looked great, and we started to button it all back up for the last time. Since we're not revealing the motor we're using just yet (be patient!), that's all I can say about that, so I will discuss some of the other mods we're working on.
        More on the 5-lug swap: We need the 5x120 mm 5-lug to be able to use GM pattern 15x10" steel wheels. The front E36 non-M spindle and brake parts we've added to the E30 are already documented here. The non-M E36 bits are never coveted by BMW folks, who usually chuck them in favor of larger E36 M3 spindles/hubs/brakes. So we were able to pickup several sets of spindles, rotors, calipers, and hubs for nothing. Of course our budget will take the usual hit of "fair market value", as found on a nationwide salvage yard website price list. Some GRM Challenge teams put $0 towards their $2010 budgets when they use free parts, but you're supposed to use Fair Market Value, and we will because its The Right Thing To Do. :)
        The rear brakes are still 4-lug stockers for the moment. This is holding up our 15x10 whee;/tire/flare mockups. We thought about just re-drilling the rear 4-lug E30 hubs for the 5-lug pattern. So last week one of the GRM Team members pulled the rear brakes apart and we did a quick visual check with an E36 front hub. There's not enough metal to properly support the larger bolt circle of the 5 x 120mm BMW pattern. The 4 x 100 mm circle is a good bit smaller. See the pictures below.
        So this weekend we're going to prowl the junkyards looking for the Z3 rear brakes and hubs we need, based on knowledge we learned on R3vlimited forums and this guy's excellent tech article on E30 5-lug swaps. We found one junkyard willing to sell the Z3 rear hubs for $25, so we'll swing by there if we strike out elsewhere.
        Seats: We've got a pair of eBay specials in the car now that "look pretty" but pretty much suck at supporting a driver in hard cornering. For auto-x and drag racing they might do the trick, but since we're gearing up to run the 2010 UTCC event at VIR, these seats have got to go. They are not cut out for road course used.
        To help reduce the cost of the $500 car, these seats will be sold. To avoid spending many hundreds per seat on race seat or seats, since seats are not considered a pressing safety item and DO count against our $2010 budget, we're going to MAKE OUR OWN SEATS. Yes, we're crazy... but we were inspired by watching this show:
        We've used aluminum seats in several of our other race cars, from UltraShields in McCall's '91 BMW 318is to Kirky Road Race seats in Costas GT1 car. They are simple, comfortable, strong, lightweight, and very easy to mount.
        So we'll make some cardboard patterns based on one of those aluminum seats, buy a sheet of aluminum, cut our patterns, do some bending and TIG welding, and try to build a seat or two for this car. Since the car is already stupid light, we'll likely make them stronger than many of the aluminum seats we see other racers using, so don't fret about safety. This way we minimize the budget hit for real race seats, get a better/more supportive seat(s), and get to be probably one of the only teams to have homemade seats at the GRM Challenge. :D
        More safety: Since we're going to (hopefully) be bombing down the straights at VIR at 150+ mph, we're going to step up the safety preparations significantly. We just bought a pair of G-Force Pro 6-point FIA cam lock harnesses for the E46 330 that I'm racing this year, and they are affordable at only $153.set. We'll get some for the E30 as well (and these are safety items that don't count towards the budget). We'll get another SPA 5 liter fire suppression system for the E30, the same as we used on the LS1 E36 Alpha car. This is money well spent, and also not counting against our budget, nor is it performance enhancing at all. I really dislike car-b-ques and crispy skin.
        Rearend: We're going to hit the junkyards this weekend and look for a cheap diff while we search for the Z3 rear brakes. Fingers crossed...
        More soon,
        • Fair!
          • Mar 2007
          • 202
          Originally posted by TOOLEAN
          Terry, why even bother with setting up a passenger seat and all the equipment that goes with it? Seems unnecessary.
          Good Luck!! Nate.
          We have like 9 people on the team, so we'll have passengers aplenty for most autocross runs. Some track test days we attend regularly (member days, privcate test sessions, etc) allow passengers as well, and many of the team members are instructors for NASA and other HPDE groups, so that 2nd seat would get well used in the near future. :) At about 15 pounds and for roughly $40 in aluminum, it won't ding the weight or cost budget much to have that 2nd seat.
          Originally posted by kablammo
          http://denver.craigslist.org/pts/1623893896.html
          -edit: ratio is problably not right for your application though.
          Yea, with the tire height, trans mission gearing, and rev limit of our V8, that rear end ratio is not ideal (3.73). Neither is the price. We need "pick-a-part" prices, hence, the junkyard crawl we have planned for tomorrow. :stickoutt
          Originally posted by lughed
          Can you take a side shot of them seats? From the front they look like they have plenty of bolstering
          Which? Here's the lovely eBay specials we have now, along with the aluminum seats we plan to copy.
          Left: UltraShield Rally Sport seats. Middle: eBay specials that came in our E30. Right: Kirkey Racing Intermediate Road Race seat
          We'll be copying either the aluminum UltraShield Rally Spot seats in McCall's '91 318is, or Costas' GT1 car's Kirkey Intermediate Road Race seats.
          Originally posted by Dirt32
          Terry sent you a pm, have a set of good calipers for you
          Sweet! I'll respond shortly...
          • Bimmerman325i
            • 6854
            Thanks for posting the build here, Terry!
            2017 Chevrolet SS, 6MT
            95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
            98 M3/4/5 (stock)
            • iwantspeed
              • 3164
              great job guys
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • Alpina
                • Oct 2004
                • 838
                Absolutly stunning projects
                Sveinbjörn Hrafnsson
                E30 CABRIO V12 M70B50 ///
                ALPINA B10 BITURBO 346 @ 507
                E34 550 V12 JML
                Finnish wisdom : If you want to Win,, hire a Finn
                http://alpina.123.is/pictures/
                • Fair!
                  • Mar 2007
                  • 202
                  I should have posted the thread here sooner. I'll copy all major posts and updates here every week, from now on.
                  Calling junkyards and making plans for tomorrow. Already found Z3 calipers, brackets, pads and hoses for the rear, and hubs from another place. Cheapness! All E30 LSD diff calls have been fruitless so far, though.
                  Cheers,
                  • Bennetts22@aol.com
                    • Jun 2006
                    • 171
                    what size diff do you need? i have some cheap ones for your project
                    Cheers,
                    • xLegendOZWest
                      • Jan 2009
                      • 406
                      amazing build! i was really interested to see the individual weights of various e30 components. thanks for being so detailed!
                      Live Fast. Drive Faster.
                      "Nitrous is like a hot girl with an STD... :)
                      You wanna hit it, but your afraid of the consequences :(
                      • Lof8
                        • Oct 2006
                        • 2827
                        Looks pretty impressive! I'm a veteran challenge spectator and looking forward to seeing it in person. It looks like you've got a good chance at competing with the turbo widebody e30. Their car was very impressive last year. You gotta love seeing the sub $2000 e30s tear shit up.
                        S50'd
                        Originally posted by TDE30
                        What is this faggy shit I have happened upon?
                        I can always live in a M3. Can't M3 a house.
                        • kamotors
                          • Nov 2007
                          • 7102
                          great build
                          7speedshop.com
                          • TexasTerp
                            • Jan 2009
                            • 3541
                            Damn this is one amazing build for $2010!!!!
                            stephenbrody.com
                            • george graves
                              • 19996
                              Sub'ed (of course!)
                              Originally posted by Matt-B
                              • erik325i
                                • Jan 2005
                                • 3567
                                Awesome build! Keep up the good work.
                                Erik
