After a year of searching, an Alpineweiß story
  • iwantspeed
    • 3164
    #436
    Got some parts delivered from Ireland engineering.
    Thanks Andrew
    Polyuerthane steering guibo
    21mm Polyurethane sway bar bushing.
    Beefier sway bar mounts
    Adjustable sway bar end links and mounts.
    Reinforcement plates
    • Engine,upper & lower
    • Sway bar tabs
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • F34R
      sLaughter
      • 12376
      #437
      Very nice attention to details and little things.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • kalib0y
        • Dec 2004
        • 3620
        #438
        Originally posted by iwantspeed
        I know the manager at my Local Wahoo's Fish Taco
        And I got a picture of my car at an autocross framed, I signed it and its hanging in the walkway where you wait in line to order at the Wahoo's in Aliso Viejo, Ca.
        Reppening a Motorsport hardware sticker, and above ARCHIE'S GIRLS.
        Sweet! what Wahoos is this at?
        95 7.1L 16V E36 M3
        Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
        LIKE my Facebook Page! CLICK HERE
        • iwantspeed
          • 3164
          #439
          Aliso Viejo Towncenter
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • iwantspeed
            • 3164
            #440
            Got my bar mocked up
            21 mm convertible sway bar
            Powdercoated in a lime green shade similar to st sway bars
            Ireland Enginnering adjustable links
            Ireland Enginnering poly bushings and mounts
            Ireland Enginnering sway bar reinforcement tab
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              #441
              I installed the race skids cross brace.
              I was suprised that it didn't interfere with my e30 motowerks skid plate there is about 1/4 - 1/2 inch clearance between the 2
              I wish there was a little more clearance for a socket on the bolts near the lollipop
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • archie
                • 5448
                #442
                88 M3 Diamantschwarz
                89 M3 Zinnoberrot
                56 Isetta
                LIKE ARCHIE'S on Facebook!
                • iwantspeed
                  • 3164
                  #443
                  Originally posted by archie
                  yep awesome
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • iwantspeed
                    • 3164
                    #444
                    old vs new
                    my goal was to get my sway bar parallel to the ground
                    the stock length for Ireland engineering adjustable end links in the shortest position
                    is still too long and causes the sway bar to sit upwards at static ride height
                    (DISCLAIMER) this only is a problem if your using a factory sway bar.
                    if you use a IE aftermarket bar the bolt hole on
                    the sway bar is in a different location AND "SHOULD" WORK FINE
                    the reason I chose the factory 21mm convertible sway bar, was from my research
                    it wouldn't cause any interference issues with the Race Skids Cross brace.
                    While a 22mm or larger bar may interfere.
                    so I cut the link 0.375 of an inch of both ends.
                    stock on the right
                    modified on the left.
                    mounted the sway bar
                    close up of the mounting hardware
                    i used a head bolt washer between the subframe and the Ireland plate
                    this picture is before cutting the end link
                    you can really see how far from being parallel it is.
                    Here is a picture after cutting 3/4 of an inch off
                    You can see some improvement
                    But it's still not parallel
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • watchamacoolitt
                      • Nov 2011
                      • 221
                      #445
                      Nice car!
                      • iwantspeed
                        • 3164
                        #446
                        Originally posted by watchamacoolitt
                        Nice car!
                        thanks
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • iwantspeed
                          • 3164
                          #447
                          I broke my glovebox handle:x
                          In my previous e30 it came with a euro glovebox handle and it was pretty sweet.
                          I decided to get one, they are only 22bucks.
                          I ripped of the old handle to get access to break into the glovebox to replace the latch
                          part number
                          old vs new
                          installed
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • iwantspeed
                            • 3164
                            #448
                            a few months ago i broke the plastic clip on the cruise control bowden cable where it get attached
                            the throttle linkage bracket on the intake manifold.
                            I didnt really care because I rarely use the cruise control i mainly do street driving.
                            The system does not weight that much so I decided to keep it and fix it.
                            A special order at irvine bmw and with the bmwcca membership total cost was 29 bucks.
                            I used this diy to replace it.
                            new cable
                            its pretty straight forward
                            remove 3 8mm nuts holding the mounting bracket
                            remove 7 small flat blade screws
                            gently pry the cover off with out damaging the rubber o ring gasket
                            with pliers lift up the brass piece that keeps the red gear from rotating
                            carefully remove the flat brass coiled spring
                            lift the red gear up
                            DO NOT REMOVE THE BLACK RUBBER BAND
                            pry the old hose with a flat head screwdriver
                            remove old hose
                            install new hose.
                            woo hoo ready for install
                            I also did a wire tuck for the cruise control, you can not see the wiring once installed
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • ak-
                              • 12422
                              #449
                              very nice
                              1991 325iS turbo
                              • iwantspeed
                                • 3164
                                #450
                                Originally posted by ak-
                                very nice
                                Thanks
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
