After a year of searching, an Alpineweiß story
  • enrike
    • 342
    #451
    Wow! I really enjoy reading your thread, the attention to detail makes me want to make a better effort when working on my ride.
    • iwantspeed
      • 3164
      #452
      I went to the junkyard this labor day weekend.
      it was 50% off everything, I found a 1988 325I automatic with no crash damage, not sure why it was in the junkyard.
      the engine bay was covered in oil gunk and grease.
      A benefit from the car being automatic is that the subframe has lived an easier life and is less prone to engine mounts being pulled up on the passenger side and pushed down on the driver side.
      A benefit of it being covered in grease there is a slightly better possibility of the subframe not having any rust. After degreasing it and thorough cleaning with carb cleaner, no rust woohoo!
      fresh junkyard front subframe
      all clean with motor mount and sway bar reinforcement plates mocked up
      motor mount upper
      motor mount lower
      sway bar tab
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • iwantspeed
        • 3164
        #453
        New Burr king belt grinder makes quick work on getting these reinforcement plates to fit properly.
        Project
        Parts for Sale
        Feedback
        YouTube Channel
        • bzboardz
          • 1096
          #454
          i need to do this ^^ great work!
          • iwantspeed
            • 3164
            #455
            Yes,
            Once I install mine I will have a spare front subframe.
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              #456
              Hey guys I got a limited slips diff in a 3.73 ratio but the weird part is that it came from an automatic. I thought all automatics came with a 4.10
              Anyways. The output flanges turn in the same direction. So its good
              I counted the amount of rotation form input on the diff to the output flange.
              Scanned the vin and confirmed that the car has a factory limited slip.
              the diff id tag has an S before the ratio number signifying that it's a limited slip
              Factory stamp on top of the diff
              Got some maintenance items.
              Redline 75W90
              Output flange seals and circlips
              Rear diff cover gasket
              Inside it's guts. No metal shavings when I drained the diff
              No excessive wear pattern.
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • iwantspeed
                • 3164
                #457
                I just checked the back lash on my lsd diff,and I'm stoaked to find it to be only 0.003 thousands on the drive side of the ring gear and on the coast side of the ring gear.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  #458
                  I pressed the old bushing out.
                  New powerflex 70a durometer diff bushing.
                  I'm pretty impressed with the fit.
                  Nice tight press in fit.
                  Bushing is 2 parts with a sleeve and 2 big washers.
                  Thanks Bob(blackout) he took his bushing out of his prepped diff cover becuause I didn't have time to wait for shipping from powerflex. I'm trying to get this diff installed before the next autocross.
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • bzboardz
                    • 1096
                    #459
                    great choice with the powerflex!
                    • iwantspeed
                      • 3164
                      #460
                      Thanks to your feedback and positive review, it helped me make a decision.
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                      • iwantspeed
                        • 3164
                        #461
                        After installing the lsd diff I took it to an autocross with BMWcca at California speedway in the city of Fontana.
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • iwantspeed
                          • 3164
                          #462
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • iwantspeed
                            • 3164
                            #463
                            I have a busy weekend ahead of me.
                            Uuc dssr 187mm
                            Late model centered shift knuckle.
                            pillow ball
                            pin
                            selector shaft seal
                            output seal
                            lock ring
                            Garagistic front delrin carrier bushings
                            Brent5671 rear delrin carrier bushing
                            New Allen screws for my UUC evo3 lever
                            And a shift rubber boot
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • Crippled Crip
                              • Sep 2011
                              • 160
                              #464
                              love your build/car alex!
                              • iwantspeed
                                • 3164
                                #465
                                Your Derek's younger brother right?
                                Thanks.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
