After a year of searching, an Alpineweiß story
    Originally posted by 2mAn View Post
    Damn those times are so much faster than what people were running on Saturday... crazy
    yep pretty fast
    Project
    Parts for Sale
    Feedback
    YouTube Channel
      I had problem with my struts.
      The welds penetrated the inside of the struts
      Thanks to Ross for letting me use his bilsteins to test
      fit my strut tubes and Tyler and roland for helping me grind down the welds.
      Ended up using a dremel with a sanding drum and an extension.
      Also used a half moon file
      Finally it fits!
      Installed new hubs.
      Tightened down to the proper torque with the parts not on the car was a challenge.
      I bolts the struts into a bench vice. Had a friend push on the strut while i turned the torque wrench towards him. It would litteraly
      Move the vice and the whole bench.
      Wearing my SoCal e30 shirt
      Had a hard time holding
      The strut to
      Install
      The new shock glad nut.
      It's just awkward the strut wants to rotate.
      So I bolted the strut to my spare wheel that keeps it from rotating.
      Soo much better
      Thank you to Richard at michaelgelos for letting me use the bilstein tool for the gland nut.
      So much easier to Use than channel locks.
      Almost done.
      E30 strut
      Stock backing plates cut out
      Lower spring perch cut off
      Coilover ring welded on to support the sleeve
      M3 sway bar bracket welded on
      Gusset welded on from. Knuckle to strut tube
      New wheel bearings.
      Carbon fiber brake ducts
      Comparing the old strut to the new strut
      No gusset and a heavy backing plate
      Comparing lower spring perch
      Comparing backing plate
      Project
      Parts for Sale
      Feedback
      YouTube Channel
        With the new struts on the car I ran into an issue with the sway bar end links.
        They were too long.
        They have a wrench flat machined into it and it was close to the edge of the end link. It was to close to the right hand thread side of the link. And since I didn't have a left hand tap in a 3/8-24 i had to cut the links shorter on the right hand thread side and I lost the wrench flat.
        Garagistic adjustable end links.
        I was given these and was aware that they were long that's what I wanted, so I can cut them down to the size I wanted.
        I cut an inch off the links.
        And retapped a new thread into it.
        Holding the end links in the cnc indexer to machine new wrench flats for a 13mm wrench.
        Woo hoo one side rotate it 180 degrees at the same height and do the other side.
        Finished product. You can see the little black piece of the endlink that's how much I cut off.
        And the wrench fits the wrench flats I machined.
        Project
        Parts for Sale
        Feedback
        YouTube Channel
          I wish I had access to those toys. Lucky guy... Nice work
          Simon
          Current Cars:
          -1999 996.1 911 4/98 3.8L 6-Speed, 21st Century Beetle
          Make R3V Great Again -2020
            I love having access to all of these machines and tools. I don't take it for granted.
            Project
            Parts for Sale
            Feedback
            YouTube Channel
              Finally it fits!
              :up:
              1989 325i coupe 5MT Alpine White
              2003.5 M3 coupe 6MT Silver Gray
                I got some media ballast to help setup the ride height of the car.
                got a baseline ride height
                can't get too crazy with this since i will be corner balancing the car.
                scored some free sway bar end links that are in better shape than mine.
                soo excited that i found some scales to use.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                  drove over to richards shop
                  put the ballast in the driver seat
                  on the scales
                  work smarter not harder.
                  have a software setup for corner balancing the car it helps tell you what corner to adjust
                  make one change at a time
                  make notes
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                    race skids cross brace to m3 offset control arm bushing clearance
                    e30 motorworks skid plate
                    condor speed shop motor mounts
                    i made this oil distribution block
                    the adjustable end links before i cut them would hit the control arms
                    gusset to abs sensor clearance
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                      After changed the height on coilovers and making the sway bar end links shorter I needed an alignment.
                      This was also done with a full tank of gas, spare tire and the 150lb ballast
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                        Looking so good dude!
                          nice and detailed, great job.
                          1990 325is
                          m52b28
                          3.73lsd
                          g260 (1987 325is 5spd tranny)
                            Nice work, easily one of my favorite e30 build threads if not my favorite.
                            And holy crap on the caster!!! that's a lot of caster!
                              :hitler:
                              Thanks
                              Thanks
                              Thanks
                              I love caster.
                              If I get camber plates in the future I can dial in the caster and camber and get them even on both sides
                              I love how she drives right now
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
                                Update
                                Autocross with the bmwcca.
                                Changing wheels
                                Sexy m coupe as my pit neighbor.
                                First autocross with the new seats.
                                Instructors sexy estroli blue m3
                                Ready to drive.
                                This engine helped get my first trophy.
                                First in class.
                                4th overall.
                                All the late nights wrenching make it all worth it.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
