After a year of searching, an Alpineweiß story
  • thatphysicsguy
    • Mar 2013
    • 843
    #616
    Looking good man. Spotted your car in OC a couple days ago. We should cruise some canyons sometime
    '91 325i
    • iwantspeed
      • 3164
      #617
      Thanks. I live in Irvine and drive this car all over
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • iwantspeed
        • 3164
        #618
        The cockpit
        Project
        Parts for Sale
        Feedback
        YouTube Channel
        • theDELO
          • Nov 2014
          • 37
          #619
          Looks like you're investing in all the right places.
          What harness bar(?)/GoPro mount are you using?
          • iwantspeed
            • 3164
            #620
            Thanks theDELO I made my own go pro mounting bar. It will be for sale soon
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • 2mAn
              Señior Mod
              • 20207
              #621
              Originally posted by iwantspeed
              Whats the piece at the bottom of the cluster?
              Love that steering wheel, reminds me of the prototipo.
              A few of us are doing the speedventures autox on the 21st. You going?
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • iwantspeed
                • 3164
                #622
                The piece at the bottom of the cluster is an led shift light that I put specifically for autocross I would have a habit of riding 2nd gear to long bouncing off the revlimiter.=slow
                Now the shift light blinks bright red screamin shift and that = faster lap times.
                I made it so it's adjustable. You can set it to flash at any rpm that you set it too.
                I'm loving the steering wheel really makes a big difference
                The 21st is my 9 year anniversary with nicole. So you can count me out have fun out there. You should try disconnecting one end link on your rear sway bar. Passenger side is easiest since the exhaust is out of the way. Try it for one run and see if you like it.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  #623
                  did a cold engine valve adjustments to a snug 0.011
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • iwantspeed
                    • 3164
                    #624
                    Wife got me a set of harnesses for my birthday
                    Schroth Racing
                    6 point cam lock
                    3 inch
                    pull up lap belts
                    clip in 5th and 6th points
                    I wasnt satisfied with the choices of reinforcement plates avilable so I made my own.
                    Purchased 3/16 steel plate
                    made a template
                    got a layout to make the most out of the material i purchased to have little waste.
                    marked out the cut lines
                    i could only mockup the eyebolts on the floor.
                    I made just a 4x4 plate for the inner lap belts until i had time to drop the exhaust heat shield and exhaust and make the inner lap belt reinforcement plate
                    everything lines up so now its time to drill some holes
                    proper brideport vertical mill
                    holes drilled bottom square plates ended up looking exactly like the other ones for inner lap belt plates
                    quick coat of paint so they dont rust
                    the seat belt rail that the seat belt slides back and fourth on has a bolt that goes into the e30 chassis floor.
                    its a metric head bolt but uses an american thread.
                    its a 7/16-20 1.5 standard thread pitch.
                    I was able to get some through Evasive Motorsport in LA.
                    cheapest place i found
                    doing it again i would have purchased 2 long ones and 6 short ones.
                    I bought 8 38mm eye bolts
                    2 where a good length for the stock seat rail
                    the other 4 stuck out to far towards the ground
                    the other 2 stuck out to far towards the driveshaft
                    used masking tape to make them all the same for a cut line
                    bench vice and a quality blade made it easy
                    cut down to a good size
                    ahh this so :hitler: drilling holes into car goes against my core but necessary
                    quick spay paint to keep it from rusting
                    lather up some silicone sealant to keep the water and rust out
                    done
                    and a good picture of the inner lap belt plate
                    I could not find anyone with this plate documented on how they did i hope it helps.
                    the Center support bearing is completely in the way of where i wanted to install the eyebolt so its just barely behind it.
                    CSB is right here
                    All done
                    just needs to be
                    driver side
                    passenger side
                    5th and 6th belt are annoiying to adjust. do it out of the car make them the same and ziptie the excess
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • ak-
                      • 12422
                      #625
                      You're doing fantastic.
                      1991 325iS turbo
                      • iwantspeed
                        • 3164
                        #626
                        thanks got some goodies from ground control. will be posting soon about those
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • iwantspeed
                          • 3164
                          #627
                          Woot I bought these for myself as birthday present.
                          I have really wanted these for a long time but they are just a bit expensive.
                          I purchased a set of 60mm top hats and 2.5 inch top hats
                          I have a set of 60mm helper springs and 2.5 helper springs to play with.
                          I also ordered extra hardware just to have
                          I love taking everything apart.
                          mocking it up.
                          E30 Camber/Caster Plate,
                          60mm top hat
                          60mm Swift helper springs
                          2.5 to 60mm adapters that I machined myself
                          old setup
                          new 5k mile old stock upper bearing
                          custom top hat 14mm bilstein shock shaft
                          2.5 id hypercoil springs 330 lb 6 inch length
                          start with this
                          cool tool i purchased a while ago.
                          its a 3/4 socket with a hex shape on the top to grab it with a wrench and you can fit an allen tool inside to hold the shock shaft from spinning.
                          all gone no impact tools required
                          out with the old
                          camber plates in with the slot for caster adjusted to be close to stock currently running 9 degrees of positive caster.
                          strut bar back on
                          new springs
                          thanks to Mike an Engineer at Eibach for answering my questions. he is currently in the market for a badass e30 coupe
                          old vs new
                          Hypercoil 2.5 id .440 compressed length 4 inch free length
                          and pics with it in the car
                          Got the ride height set with 1/16 of an inch difference from driver front to passenger front with me in the car.
                          thats close enough ballpark before doing a corner balance.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • iwantspeed
                            • 3164
                            #628
                            I had a cheese holed lower airbox for a while now.
                            trying another setup with DEI gold heat reflecting tape on a separate airbox with no holes.
                            i like tinkering if you guys couldn't tell already
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • TeXJ
                              • 1914
                              #629
                              let us know what ya find out. Sounds interesting.
                              1990 325is
                              m52b28
                              3.73lsd
                              g260 (1987 325is 5spd tranny)
                              • kts
                                • Jun 2010
                                • 753
                                #630
                                Very curious to see what you find out with this setup.
