After a year of searching, an Alpineweiß story
Originally posted by iwantspeed View Post1990 325is
m52b28
3.73lsd
g260 (1987 325is 5spd tranny)
Cliff notes
Fumoto oil drain valve f109 N works on the m20 oil pan WITHOUT needing the ADP 109 adapter. I have called fumoto and discussed this with them via email so they can update there website.
The drain valve sits above my e30 Motorwerks HIK fabrication skid plate
New parts
I have been wanting a fumoto oil drain valve for a while. Once i checked out there website I found out it needed an adapter to screw into the oil pan first so that the valve could clear the oil pan. This would cause it to sit to low and be vulnerable to shearing off.
I recently bought the valve and the adapter to see what how I could do it.
Turns out you can use a extra crush washer to space the valve out and get the included fiber washer to sit nice and flat.
axle boot tore on the driver side inner joint
really impressed with my brushless dewalt impact gun
it broke the axle nut free even with the lock ring still on
Untitled by ALEXANDER RENGIFO, on Flickr
pushing out the passenger side axle
driver side came out easy
Axles by ALEXANDER RENGIFO, on Flickr
axles on the work bench ready to tear them apart
after tearing them down i discovered you can not disassemble the outer joint closest to the wheel bearing.
so i removed as much grease as possible then soaked it in paint thinner.
axles dissembled and cleaned. waiting for redline cv2 axle grease to rebuild them.
i bought rubber boots inner and outer,
axle nuts
axle locking plates
all from rm European it was delivered in one business day.
Axles by ALEXANDER RENGIFO, on FlickrLast edited by iwantspeed; 09-27-2018, 11:16 AM.
rm european order and redline cv2 grease from amazon
Axle boots by ALEXANDER RENGIFO, on Flickr
axle greased up
Redline cv 2 grease by ALEXANDER RENGIFO, on Flickr
i borrowed a tool from my shop neighbor.
it pinches down to clamp the boots on the axles
Axles and trailing arms by ALEXANDER RENGIFO, on Flickr
the clamps provided with the boots came excessively long
i tried to cut the clamps with a pair of sheet metal tin snips but that didnt work
i ended up using a cut off wheel
clamps cut to size
yay!!!
axles done!
took the trailing arms off to grease the polyurethane trailing arm bushings and to paint the trailing arms.
black gloss paint
trailing arms painted and poly bushings lubricated with mobil 1 grease
i had to remove the filler neck to access the passenger side bolt closest to the 1/4 panel
one trick if you are removing the brake lines is to safety wire the brake pedal to the steering column.
