325ix dirt bomber project. Now with more diesel
  • dannyyisntt
    • 3141
    #61
    I love it lol. People always look at me like wtf?! whenever I mention that I wanna turn my ix into an off roader.
    • Erik j
      • Jan 2008
      • 939
      #62
      Went over to my friends studio to check on the skull. Here are a few pictures of it coming out of the copper plating tank. Some other pictures of his paintings and some of his glass work too.
      Tri color fabric for sale here!
      http://www.r3vlimited.com/board/showthread.php?t=105922
      • Erik j
        • Jan 2008
        • 939
        #63
        Wanted to make a little update to this. Been working on doing a m21 turbo diesel swap on this little thing. Got the m21 engine, spare turbos, spare head, spare intake, spare everything really... got 2 e28 524td harnesses and a 324td harness too to work with.
        Did a little mock up on the m21 head with my bigger turbo, and my top mount intercooler. The intercooler needs some work to get it to fit perfect, but its close. I need to relocate the oil filler neck someplace else, not sure where yet, but I might do a remote mount that just drains into the dipstick tube.
        • M42Power
          • Dec 2009
          • 519
          #64
          Do a front mount and relocate the intake inlet to the bottom of the plenum, that will help with tube routing
          Originally posted by kendogg
          Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
          OG RACECAR
          • Erik j
            • Jan 2008
            • 939
            #65
            Looking at a possible air-water system or a side mount insted of this intercooler.
            Stock ran no intercooler, But I will be doing testing both with and without the intercooler. Just need to find a awd dyno around here.
            • Rocla
              • 922
              #66
              Any issues using m21 engine with ix oilpan?
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • Erik j
                • Jan 2008
                • 939
                #67
                Shouldnt be any problems with the oil pan. The oil pick up tube will need to be "adjusted" maybe I can just swap the iX pickup into the m21.
                So after reading the electrical manuals, I have figured out my c101 wires. So I can go from the square e28 plug of the m21(not the same as the normal e28 one) to the round e30 plug.
                m21-----------e30
                Pin 1--------->Pin 1....To inst. cluster charging indicator lamp
                Pin 2--------->Pin 2....To check control, static oil level sensor
                Pin 3--------->Pin 13...Fuel pump control
                Pin 4--------->Pin 4....To cluster, coolant temp signal
                Pin 6--------->..............Not used with e30 FI (integrated idle control)
                Pin 7--------->Pin 7....12V to ign coil
                Pin 8--------->Pin 18...To starter, from ignition
                Pin 10-------->..............Not used on non-airbag cars? (would go to pin 20?)
                Pin 13-------->Pin 10...To check control, dynamic oil level sen.
                Pin 14-------->Pin 5.....To cluster, oil pressure warning lamp
                Pin 15-------->Pin 11...To cluster, SI reset
                -------------->Pin 16...Unused
                -------------->Pin 20...Unused
                I am going to order up a new c101 plug and pins and make the end of my m21 harness fit. I am also going to order up replacment plugs for all the old/broken plugs on the harness..... going all japandrew style on this harness.
                • LJ851
                  • 7919
                  #68
                  Not sure about the M21 but the ix oil pump/ oil pan set (rear sump) is unique to itself. Even the ix block is different where the pump bolts on and where the bypass oil goes. Not to mention the pump spins backwards compared to a regular M20. Definitely not an "adjustment" , You may want to look closer at the oiling system before you get too far along.I like your project!
                  Lorin
                  The M30 is God's engine.
                  • hi its me alec
                    • Apr 2008
                    • 478
                    #69
                    sweet engine + top mount. i really like the progression of this project since i saw it in your driveway a couple years ago. :D
                    WTB: early e30 sedan front doors
                    • Erik j
                      • Jan 2008
                      • 939
                      #70
                      Did a little searching
                      Just listen to that sound
                      Note: This is not my car, and I cant find the build threads for it... but its a m21 and awd.
                      • lambo
                        Captain Scene Points
                        • 10953
                        #71
                        http://www.youtube.com/watch?v=soKXBS6qphI
                        Holy shit that's cool
                        • Erik j
                          • Jan 2008
                          • 939
                          #72
