Order a brake fluid reservoir and hose for me too. I have the same issue, except mine is in the "leaking" stage, not so much dumping. :(
1991 BMW 325i Coupe - Build Thread - The end is in sight!
lol. mine dumped a whole reservoir last night. for me its the seals on the MC that are leaking to shit. which hose are you referring to? also I couldnt find a PN for the reserviour. but the plastic piece on mine seems ok.Comment
So another big update.
i spent 2 grand today. Got pretty much everything I need to rebuild the car sans some of the performance stuff.
here is what is left
Big thanks to Steve at BluntTech, Kevin at Modbargains.
we are making progress.Last edited by MaksV; 11-15-2010, 01:16 PM.Comment
more goodies.
real brake fluid, gaskets, head studs, waterpump, timing belt and tensioner, subframe mounts
more to comeComment
your car is sick! i love the color.
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
2009 Toyota 4Runner SR5 Sport 4WDComment
BimmerWorld Stud kit, and vinyl wrap for the cupholder came in today.
Today was a beautiful day, so I was like fvck studying lets go work on the car. Also I have been pretty stressed out lately and this helps. Tonight I am gonna watch the Stars play and write lap reports :facepalm: anyway enough of me time for the car
First we started with mechanicals - the only thing keeping the car off the road was that it was dumping a reserviour full of brake fluid an hour after it was refiled. time to find out why.....
turns out it was he grommets that connect the reserviour to the master cylinder. Also the tank was so filthy and full of crap it took me a good 30 minutes to clean it out....
and a closer look
they felt so nasty - no form to them completely desintegrated.
there were a bunch of pieces of them in teh whole so i took the time to clean the master cylinder.
then I cleaned the tank - when i started here was a layer of black sediment everywhere - just nasty inside and out, and now clean
new grommets installed - Thanks Steve at BluntTech
and all back together with clean fresh fluid
I then decided it was time to take a look at the brakes - take the wheels off one at a time. I also had some Wheel studs from bimmerworld that I wanted to install but I decided I want new rotors and pads first, The previous owner must have torqued the wheels to about 120lbs. I got to use my new 25" harbor freight breaker bar that I got for $6 on sale - totally worth it.
all rusty with splooshed pads and grooved rotors - obviously have been remachined once or twice. took some sand paper to the rust.
sanded and wheel studs installed for test fitting
I have to make a note here: these things are so nicely made - very high quality and a set of studs and lugs will only set you back $85 - totally worth it as well. Howeve you need a deep socket 17 to install the lugs unless you are running a spacer.
and with the wheel on
All in all I decided to wait and get new brakes - these are nasty and will not work for track duty - I am going to stay stock but get better pads - maybe Hawk? - so I saved the studs in their box for later and for now put the bolts back in. However I put some grease on them and the hub before I put them in to hold off the rust and such. I also took time to find out if I magically had an LSD - I do not. so I need one - 4.10 please for 200 bucks ? anyone?
Now again we must change our focus to the interior. First task was to finish with this phone holder thing. I gave up on the cupholder ideas since no matter how I set it up I didnt like it. So some cutting and vinyl wrapping later
and the finished product - while not perfect it holds the phone perfectly and charges it at the same time - perfect GPS all in all it will work for now.
Last bit for today is hardwiring the radar detector - in my e46 I totally did it using a resistor a switch and +ACC and ground - the same thing would not work in the e30 for reasons I dont understand. SO i finally gave it and very gently dissassembled the power cord that came with it and hard wire it that way.
BTW purple/white is ACC +12V. and brown is ground for both the e30 and e46
I just wired it into the harness for the self check.
Thats all for now, stay tuned.Comment
and more boxes....
thanks AKG - diff mount - RTABS - RTAB tool
and MR. INJECTOR - on ebay - excellent customer service - my rebuild kit got here before my injectors have - I got 19# ford injectors
and more parts - this basically brings all the big stuff to conclusion - now I just have some specialty performance parts to buy
again, I cant say this enough Big thank you to Steve at BluntTech.
Just a small plug - Guys when you need parts made by Meyle, Lemforder - stock parts that are not really special please, please, please go through guys like Anthony at BimmerBrakes or Steve at BluntTech. They are small indipendant guys that will provide customer service a world and above the big boys. so next time you are on Pelican, Turner, autohausAZ, bimmerworld, FCP groton, or BavAuto, stop for a minute and drop one of these two guys a line and see what they have to say - they all pull from the same source, but this keeps little guys in the community going and able to produce specialty products the rest of us enjoy (headers, turbo manifolds, brakes ect).
so just a thought.
Anyway the stuff:
Valve Spring Compression tool
New stock cam and PS belt
GC coilover kit -525F/750R
