^^^ I used Paintscratch to do my engine bay. I got the idea from EGK when he re-did his rear valance.. The sell by the can and pen. I also used there clear coat. It worked great.
Eta-to-M50: Build thread
Ive used Paintscratch too and didnt care for the mix and color like I did my local shit. I think I've used custom spray cans on every BMW I've ever posted up on this site :) No one ever noticed. Looked OEM.^^^ I used Paintscratch to do my engine bay. I got the idea from EGK when he re-did his rear valance.. The sell by the can and pen. I also used there clear coat. It worked great.
Josh - I know you've been waiting for my opinion to here it is: Go to your local Sherwin Williams Auto store, or some other local automotive paint store. See if you can get them to make you up a custom schwartz single stage spray can. They're like 15 bucks a can, and you can cover some serious area with just 1 can. You probably wouldnt need more than 2 cans total to hit the whole bay. Then cut and polish it with a PC or Griotts RO. It will turn out looking pretty damn good.
I used my local Sherwin Williams Auto store to mix up some spray cans of AWII. The minimum order is 6 cans @ $11/each but they match it perfectly to factory paint codes. It's good quality stuff, I'm very happy with it. And whatever you don't use can certainly be sold to other schwarz guys.Comment
I can probably have that done at either Industrial Finishes or APS here in town, I don't think we have a Sherwin Williams Auto paint store here. :( Darin, maybe I have have you do that for me, I can just send you the money?
On a related note, Andrew and I pulled out all of the braking system components today, the ABS module, lines and booster. Just a few more things to clean up, and it's time to paint!
Also just got finished ripping out all of that nasty, rotting sound-deadening stuff on the firewall/in the tranny tunnel, I'll probably just respray it in thick undercoating.Last edited by Jand3rson; 01-20-2011, 08:19 PM.Comment
looks good
ya that firewall insulation sometimes leaves some nasty residue,
i found mineral spirits on a rag did quick work with it.Comment
You are really cleaning up that engine bay, i like. Going to keep the battery tray or cut / trim it?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Are you planning on using any kind of heat barrier on the trans tunnel?
Aircraft Spruce and McMaster Carr can be your friend in this department.Comment
For sound deadening or solely for heat shielding? On an M20/G260 it doesn't get noticably hot in my experience. Is this a common step??Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
- I will do some kind of barrier in the transmission tunnel, really the only reason I removed all of that stuff is because it looked like shit, was crumbling, and was all moist and kind of rotting. I don't care about sound deadening. Levent just had the brilliant idea of doing heat insulation under the carpet around the trans tunnel, rather than on the underside.
- Yes, the ABS system remains, I took it out to finish cleaning and paint the engine bay
- No, I haven't gotten into any wiring yet, not will I really need to. Greg made me a harness adapter.
Good news on the paint front, I went to Industrial Finishes today, and asked them about having spray cans made with gloss back. They had to have a minimum of 8 cans at about $6 each, and the cost of the actual quart of paint. However, he remembered that they already had a few cans of another product in stock, a very high-grade gloss black spray lacquer that several shops in town have used with great results, so I picked up 2 cans of that and a can of clear, just for added protection and finish. Gonna finish cleaning the engine bay this weekend, start masking everything, and hopefully paint Mon/Tues!Last edited by Jand3rson; 01-21-2011, 09:20 PM.Comment
Just finished another deep clean on the bay, mainly the firewall, and lower areas below the strut towers. Going to give it one more good clean on Monday when my paint is ready, and then hit it. Cell pics from my G2, they're actually better than my camera... lol.
It is close, it merely waits...
Gonna look good. You should clean the rubber off your blower motor cover and paint that as well. Removing tat stuff will help with the install of a e30M3 wire harness cover if you decide to go that direction down the road.Comment
