Wow Nice! didnt know you where swaping it!
Resurrection of my coupe
1986 "C2 2.7 Alpina" Sedan
1987 325ic Black Vert
http://www.r3vlimited.com/board/showthread.php?t=170548 -
/awesome motor! Perfect for a DDYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
'87 325ic, powered by S50.Comment
I started gathering parts for my own M50 swap. Last week. Can't let you Raleigh boys have all the fun, ya know?Comment
Haha! I was actually thinking of keeping the M20 around and rebuilding it for the cabrio...thinking about it anyway. Ive got 2 e30 mouths to feed! :shock:
When I met Andre, he was parting out his cabrio...now look at it! Be prepared to be negatively influenced by us Raleigh Boys! :DComment
Minor to say the least but its still an update.
I took the valve cover off to see if I can make it look better. We have all seen this. I took some paint stripper that I had laying around and went too work.
...and work it was but my main goal was to make a soda blaster (media blasting). This little rig cost me $1.50 (minus the gun) and $.99 for soda so I fired up my compressor to see what results I can obtain out of my cover.
About a box worth and this was the result. It did take the muck off.
Then wanted to clean the bolts/washers before putting it all back together so I shot 1 to see what it would do...
1st bolt soda blasted
2nd degreaser
3rd nothing
Im going to set up some sort or rig to clean these all up.
The cover still looked bad so I used more powa! A minute or 2 with the orbital sander and bam, alls good. Ill sand with a finer paper and paint it black. The cover should look nice after am done with it.
ok, better not leave this one unattended in my garage....or i'm taking it and putting it on mine. lol'87 325ic, powered by S50.Comment
Wax would just protect the surface it was applied to. In my case my surface was coarse. The 1k,1.5k, and the 2k wetsanding makes the surface smooth. I did all the wetsanding by hand cause I didn't have a da sander nor find a place that had circular sanding disks around me without buying in bulk. The malco products took out the swirls and fine scratches. I also did some research on YouTube to get an idea of how to do it.Comment
Well, its been a while. Collecting all the parts needed for the swap aint easy...at least no for me. Several trips to the pnp in this heat makes it worth the premium price some command on these parts but for the most part, all good deals and great members to work with. But the last piece came in the mail today so I guess I can update thread.
The plan is to do the swap on the weekend of June 15-17. But before then, I wanted to get some "quick and simple" things done. The plan was new VC and oil pan gasket and put on the manifolds. This should be easy, right....
Well the valve cover gasket was easy enough as I removed it a while ago. We took a better look at the cams, seems to look ok.
Oddly enough, I didnt take any pix of the part that took the longest. All but 3 exhaust studs backed out with the nuts...just too damn rusty. PB blaster was our friend but each bolt took us about 5 minutes to get off. We got them all off but it wasnt fun. The Dominos special of BBQ chicken made this task a little but more bearable. :)
Anyway, flips the block over to do the pan. I knew when I bought the engine that this bolt was already locked so it was nice not haveing to deal with this...
E36 sump removed...
E34 pans baffle drilled out...thanks AB!
and ready for the new gasket.
Flipped her right side up and put the plastics on just for a visual that it comming together, bit by bit.
Accesories are next but may wait for the swap weekend. I still have to make my harness so I have time.
Oh, btw, I scored a 98 M3 rack! This is gonna be fun once its all buttoned up!
Cheers!Comment
nice work, cant wait to see it done. what are your other plans?
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
I totally approve of everything !!
Superb taste in all endeavors.
Well done good sir.Comment
