ttrousdell's Project Thread (E30 M3 & S38 swap content)
  • Alpina
    • Oct 2004
    • 838
    #286
    Thats a hell of a thread,,,,,, fantastic i must say
    ps, reminds me of my own projects..
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    E34 550 V12 JML
    Finnish wisdom : If you want to Win,, hire a Finn
    http://alpina.123.is/pictures/
    • MJCRO
      • Apr 2012
      • 597
      #287
      Sounds so sick.
      • Jb325is
        • 2137
        #288
        So what are you going to do with the m5? I'm about to start a new swap on my e30 and am debating between building an s5x or s38. I couldn't find it in your thread, what mounts did you go with and did you run the subframe spacers?
        - '88 m54 coupe
        <3
        • ttrousdell
          • Nov 2009
          • 1770
          #289
          Once I get the S38 in the e30 running 100% Ill pull the other s38 and sell the shell. Ill keep the other engine and 280 trans as a spare or for a later project. Im not sure who made the mounts. They came with the engine when I bought it. The engine was originally in someones e30 M3. Not running subframe spacers but will prob make some eventually. For now ill just run no hood and hope I dont attract unwanted attention.
          Originally posted by F34R
          Awesome man! your smile says everything!! Now get your ass to upstate NY for some weekend backroads.
          Once I sort out the bugs definitely. Few things to do still.
          • Fix high idle
          • Get custom radiator hoses(the ones i rigged are temporary)
          • Install a fan
          • Resonance flap doesn't seem to be working.
          • Coolant gauge in cluster doesn't work (I have an aftermarket temp gauge installed but would be nice to have the one on the cluster functioning)
          Thanks. Was admiring your build long before i had an s38. Big help :up:
          At the moment I'm still chasing electrical issues. The first s38 came with a 25 pin harness but to my surprise the M5 that I have now (build date 3/90) came with a 20 pin very similar to the M30 and even M20B25.
          91' M5 C101
          1. Blue
          2. Blue/Yellow
          3. Black/White
          4. Brown/Purple
          5. Brown/Green
          6. Green/White 12V
          7. Green - 12V
          8. Purple/Black
          9. Black
          10. White/Blue
          11. White/Green
          12. Gray
          13. Green/Purple
          14. White/Black
          15. Not Used
          16. White/Yellow
          17. Pink/White
          18. Black/Yellow
          19. Green/Blue
          20. Yellow/Brown
          I was always under the impression that all s38s had the 25pin connector. Initially I thought I had a M30b35 harness which was good because I compared the two and found that they are nearly identical pinouts except for 3 and 10. I pulled out pin 8 and that was good enough for the engine to start and not have the harness melt. Sweet!
          I have not connected pin 20 to anything and i'm certain that is why I don't have a functioning coolant gauge.
          M30B35 (courtesy of Frank Macaluso's M30 swap Guide)
          1. Blue -Alternator Charge
          2. Blue/White - Oil static (check panel)
          3. Black/White - Fuel Rate (econo gauge)
          4. Brown/Purple - Coolant temp
          5. Brown/Green - Oil press light
          6. Green/White 12V - O2 Heater
          7. Green - 12V - Ignition Coil
          8. Purple/Black - Alarm System
          9. Black - Tachometer
          10. Yellow/Blue - Dynamic oil press.
          11. White/Green - Diagnostic Reset
          12. Gray -Check Engine Light
          13. Green/Purple - Fuel Pump Relay Pin 87
          14. White/Black - Speedometer
          15. Brown/Black - Neutral Safety (auto)
          16. White/Yellow -
          17. Pink/White -
          18. Black/Yellow - Starter
          19. Green/Blue
          20. Yellow/Brown -Ground coolant temp
          Air pump located just above the Ac compressor. From what i have read it pumps air into the exhaust manifold at start up to aid in reducing emissions. i don't plan on running it.
          The resonance flap system I do plan to have working. Right now I don't get any movement from the actuator which i've read tells you if the flap is functioning. I have have to control unit plugged into the harness. http://www.bmw-m.net/techdata/m5engine.htm
          The Build:
          • frontin540i
            • 28
            #290
            Subscribed.... :late:
            • ttrousdell
              • Nov 2009
              • 1770
              #291
              Small update. Installed a spal fan and recaros recently. Took the car out today and snapped a few pics.
              The Build:
              • F34R
                sLaughter
                • 12385
                #292
                Fucking sick man, we need to hangout very soon! This time at my place! Upstate back roads ;)
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • efficient
                  • Feb 2012
                  • 3312
                  #293
                  Very nice. What kind of steering wheel is that?
                  • JCarp90
                    • Feb 2011
                    • 1759
                    #294
                    This is fuckin sweet. I want an S38.
                    • Roysneon
                      • 4505
                      #295
                      So I'm gonna be that guy once again but...Wheel and tire specs?
                      17x8 et20?
                      Originally posted by mbonanni
                      I am a pursit now.
                      • Nick_S
                        • Apr 2011
                        • 3656
                        #296
                        good god this car is incredible. Fantastic work.
                        91 318is M50 swapped
                        05 Honda Pilot
                        24V swap thread
                        • ttrousdell
                          • Nov 2009
                          • 1770
                          #297
                          Momo. The BMW horn button was bought off amazon
                          Originally posted by Roysneon
                          So I'm gonna be that guy once again but...Wheel and tire specs? 17x8 et20?
                          Yes 17x8 et20. Your average RC090s. Tires are 215/40 with 1/2" spacers in front to clear the brake calipers.
                          The Build:
                          • litu
                            • 816
                            #298
                            Nice :)
                            https://www.facebook.com/Cry_77_IX-110483784967661
                            https://www.instagram.com/cry_77_ix/
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #299
                              Not sure how I missed this until now, fuckin' nice work!
                              • MPLFoster
                                • May 2013
                                • 1490
                                #300
                                errmahgawd that S38 is tits.
                                nice work.
                                form.follows.function IG @mplfoster
