Got some more work in over the holiday weekend. Not exciting by more of regular maintenance in my opinion. First, my washer fluid system is not working. I am starting to go over all the faulty equipment. I just ordered new clear hose and while I wait, I installed the new modern OEM fluid reservoir cap. I know I need new hose and a screen for the reservoir so far.
Other thing I did today was replace my leaking power steering fluid hose from reservoir to steering gear. My car had the older style, hose to pipe and using clamps. The current BMW part is a single piece with the hose crimped to the pipe. My hose was all cut up around the bottom clamp.
Here are some pictures. The last 2 are to compare the gunk the fluid leaves behind around the rack.
Tank with old cap. Cap has crack across it on the inside, but visible from the outside. New cap installed.
Here is the original hose just loosen and starting to drain.
here she is bleeding (draining)
Comparing old with new, I used existing bolt but new washers
Cleaned the underside and here is new hose installed
Here is the difference in gunk build up, pic taken from front of car looking towards rear.
