Due to overwhelming negative critiques of my fan shroud... well, to be honest, the negative critiques were correct, lol. It would have worked great, so long as I was sitting still...
Onward and upward... I re-made the shroud today into what I think is a fetching good example of over-engineering simple fan mounts. I cut the shroud loose from the core support and then thought maybe I could re-use some of it to make some mounts, which is what I ended up doing. The pieces were then re-welded to the core support and then primed. I'll seam seal it when I get ready to paint the car, which is fast approaching!:):):) On to the pics...
Little bit lower angle to show how I closed in the top...
Fan mounted...
New Setrab oil cooler mounted...
I have a bunch of fittings coming, they may show up tomorrow, for the coolers and to finish up the power steering lines and then I'll finish the cooling system vent line and the fuel lines and then it's getting dangerously close to take apart and get ready for primer time! Woo hoo!
Garey
Fan mounted...
Garey
