MGB + M42 = Win
  • XW70
    • 290
    #256
    This manifold is awesome! keen to see how it turns out
    Delphin '87 325i Vert
    • AndrewBird
      The Mad Scientist
      • 11898
      #257
      No updates at the moment, just recently moved, so still getting the garage together. I hope to be able to do some work this weekend though.
      I'll leave you with a picture of the garage as it sits.
      • James
        • Oct 2004
        • 334
        #258
        Sweet a floating welder.
        This is a cool thread I want to see more updates.
        • blalor
          • 217
          #259
          I was just about to say the same thing!
          • deutschman
            • May 2008
            • 5958
            #260
            I was just about to say. First sealing mounted MIG I have ever seen. :D
            • AndrewBird
              The Mad Scientist
              • 11898
              #261
              I didn't have room for it on the floor anywhere, so on the ceiling it goes! I can still reach the entire bench and half the garage. Going to mount the bottle next to it with some nylon straps.
              • MattAvino
                • Jan 2011
                • 2147
                #262
                Any updates?
                E30 buildy things
                http://www.r3vlimited.com/board/showthread.php?t=195286
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #263
                  Only update is that I bought 4 jackstands from Harbor Freight today ($15 a pair!), so the car can finally go back up on stands. Though I will likely build some rolling platforms for them so I can move the car easily before I put it back up in the air.
                  • carguy101
                    • Jul 2009
                    • 495
                    #264
                    Sub'd if I hadn't already
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      #265
                      Back on the horse!
                      Starting working on modifying the front subframe. Removed all the suspension first, then marked out where to cut using a laser level to draw a line. E30 subframe ain't got shit on an MG subframe.
                      Marked
                      All chopped up.
                      Re-mounted to the car.
                      I was a little bit worried that I would have problems with the pieces flexing the frame rails inward and I would have to brace them outward until I re-welded in the center, but bolted up, it doesn't move at all.
                      Next up will be making some 1/4" plates to weld on the ends, then using DOM tubing to ladder brace across the bottom. Hopefully will get the plates cut tomorrow at work.
                      • deutschman
                        • May 2008
                        • 5958
                        #266
                        Good to see you back! Get after it
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          #267
                          w00t!
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            #268
                            Got some 1" x .120" DOM tubing from work today for the cross member. Still need to make patterns and get the plates made up.
                            • ecuastyle84
                              • Apr 2011
                              • 77
                              #269
                              Good stuff man, keep up the good work.
                              E30 Motoring "represent boyyy"
                              e30motoring@gmail.com
                              • tinkwithanr
                                • Jun 2010
                                • 377
                                #270
                                Nice progress. Funny your picked up 1" x 0.120 DOM today, I just got my tubing bender die in this morning for that exact size for some extra cage bracing. Great minds think alike.
                                Tinker Engineering - 2014
                                Mica - 2000 BMW 323i - The one that started it all
                                Fiona - 1975 BMW 2002 - The Definition of Project Creep
                                Heidi - 1988 BMW M5 - The piece of BMW history
                                Silvia - 2013 Subaru WRX - Stock, for now
