MGB + M42 = Win
  • serdar255
    • Feb 2013
    • 395
    #286
    Why? Why did it take me so long to find this thread?
    Amazing work OP
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
    • E30stan
      • 658
      #287
      Top notch fabrication! Keep it up!
      • E30SPDFRK
        • 5716
        #288
        Hurry up and finish this thing, man!
        Byron
        Leichtbau
        • slammin.e28
          שמע ישראל
          • 12054
          #289
          I really had to bump this.....anything more?
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            #290
            Are you moving the project to Portland with you?
            • Thizzelle
              • 4422
              #291
              You're going to have to remove the intake to do an oil change?
              "I wanna see da boat movie"
              "I got a tree on my house"
              • AndrewBird
                The Mad Scientist
                • 11898
                #292
                Haven't worked on this in a while sadly. My GF and I are moving to Portland next month and the car will be coming with me, but for now, all I will have is a single car garage to store it in. We plan on taking about a year (our lease term) to save up some money and find a bigger, better place. Until then, I won't be working on the car at all.
                I will however be getting the engine and transmission mounted back in the car soon. It's the best place for it to be, mounted i the car, instead of on an engine stand. We are moving the middle of next month, so I will have it mounted by then. Pictures of that to come.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #293
                  No, there is a lot more room than the pictures might suggest.
                  • CorvallisBMW
                    • 13039
                    #294
                    I'm always willing to come lend a hand if you need it, 1 car garages aren't too terrible :)
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      #295
                      Well, the entire garage is going to be filled with stuff, not just the car. There won't be any room to work in it at all.
                      But like I said, we are only staying at this place long enough to get established and find something better.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        #296
                        Hey look, an UPDATE!
                        Built a new transmission mount tonight. The original one I made was hitting the inside of the trans tunnel after moving the engine back. I also never liked how one mount was at an extreme angle. Started by bending a piece of 1/8" strap to fit the trans.
                        I completely removed the old passenger side mount and drilled a hole for the rubber mount to bolt through. Then just pieced it together one piece at a time.
                        Here you can see the shape of the mount a bit more. Kinda complex.
                        Next up is lowering the engine/trans back into the car and fabricating motor mounts. That is easy as it is just a few pieces of angle like before. It also looks like I might be able to use the original trans crossmember mounting holes, which would save a bit of work. More to come in the next week.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          #297
                          The engine is in and mounted.
                          Engine mounts.
                          Cross member tubes.
                          Cross member out of the car.
                          Just enough clearance to the steering rack.
                          Lots of room in between the engine and radiator.
                          Threw on some fenders. It's been a long time since it was like this.
                          This will likely be the last update for the next year or so. The place we are moving into is an apartment complex, so I won't really have anywhere to work. The car will be in storage. After our lease is up, we will be moving into someplace with more room though and progress will commence.
                          • trippmann
                            • Dec 2012
                            • 118
                            #298
                            awesome build so far!!!
                            Originally posted by unloadedak
                            It's brand new. I've gripped the shaft a couple times and that's about it.
                            • wazzu70
                              • Jan 2005
                              • 1143
                              #299
                              Looks good!
                              -Nick
                              M42 on VEMS
                              • MR E30 325is
                                • Dec 2008
                                • 3300
                                #300
                                The last update for a year!
                                Shizza, that's going to be rough.
                                Excellen work.
                                My previous build (currently E30-less)
                                http://www.r3vlimited.com/board/showthread.php?t=170390
                                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
