318i DIRT
    318i DIRT
    Just picked up a 318i last year. It sat in the barn till a week ago.
    The car was stripped and caged. But not very well, Its a CSC cage 6 point. there is not much left of the car, as we started to pull it apart there is a TON of rust and holes in the unibody design.
    Time for some metal repair and to tie the subframes together before the car bends in half.
    The field is full of Rabbits/Lasers/ and of course, the favorite car of choice, 4cyl Mustangs.
    The season has started with a bang.. The coil wire had a rubbed spot that was leaking voltage to the strut tower (grounding out) Moved the coil wire away into the air, hit the starter and BANG, the fuckin battery blew its top, covering my face and eye in acid. after a quick wash and to the hospital for a freezing and IV solution to flush my eye, Doc's say they see no other damage.
    Putting new wires on the car and another battery, make sure it starts and still reves nice, then compression test and leakdown test and the motor is comin out.
    Pics should be up by midweek of where the car is at to this point.
    OH and the battery is being moved to whats left of the trunk with the fuel cell.
    staytuned for updates as the progression to the 2011 season gets underway, Target is testing first two firdays in may.
    Chad
    Car specs - 1984 318i with M10 1.8 and 5 speed, looking for auto trans for the season.
    DIRT is for racing, ASPHALT is for getting there!!
    sigpic1984 318i Total conversion to a DIRT race car.
    Check out our build on facebook @ www.facebook.com/brewstermotorsports
    K, Im new to the board, Gonna try to do some pics as the starting point for the 318i. All I can say is, welcome to Southern Ontario, land of rust and fun!!
      ok, that didnt work, Lets just say there is no wheel wells left, the unibody on the drivers side is non existint. the front sub frame is rotted. have the wiring harness stripped out and the engine ready to come out tomorow.
      Open to ideas on improving low end torque while not sacrificing the high end for the end of the straights, rumor I might need more pull out of the corner.
        Need pics.
        M10 Automatic must be slower then the Dirt itself.
        1985 325e M50TU(Sold)
        1991 318is Slicktop (Sold)
        1990 325is Brilliantrot S50/5 Lug Swapped.
        1992 525i Manual shitbox Winter Beater
          Need pics.
