E30 M42 + Eaton MP62
  • Ian Bowers
    • Apr 2008
    • 1120
    Oh, they look like goodies.
    Blow the M42. The good way!
    Eaton M62
    42lb Injectors
    Intercooler
    8-9PSI on stock internals
    Spal 16" Puller
    Jackson Racing M62 Miata manifold
    Megasquirt II or III, whichever I decide
    New Euro 323i flywheel
    Spec stage II+ (iffy about it, but too late now.)
    AEM eugo wideband
    Sparco R505 seat
    And a bunch of other shit.
    I'm optimistic to have it together by my birthday in May, but seeing as I have no garage to work in, I'm at the mercy of the weather.
    Going on this:
    Which is currently at the bodyshop(Healdsburg Collision Center) getting repainted, the front fenders reworked, and the IS front lip/skirts paintmatched. Oh, and the antenna hole deleted. It looks kinda like this:
  • 89AlpineM3
    • 548
    nice
    • Danny
      • 14216
      Sucks considering I'll be looking at developing an m42 turbo kit soon and I need a guiney pig.
      • Ian Bowers
        • Apr 2008
        • 1120
        Mother fucker.
        • freeride53
          • 11972
          Good it looks.
          1983 Peugeot 505 STI
          1992 Volvo 240 Wagon
          • shEck3lls0
            • Jan 2011
            • 1154
            Can I be your guinea pig?
            1989 Alpine 325is 2dr m50 swapped
            Build Thread:
            Current ongoing build. Check it out!
            1991 318is 4dr rallycross
            Rallycross Build Thread.
            1991 Alpine 318is coupe - sold
            • trackjunkie21
              • Jan 2010
              • 3962
              :giggle:
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • MR E30 325is
                • Dec 2008
                • 3300
                What HP are you looking at making with that setup?
                I made 8 psi on my S52 swapped E30, and the almost 400hp it made wasnt quite enough.
                Good luck with the build and the timeline though!
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • Ian Bowers
                  • Apr 2008
                  • 1120
                  I'm aiming for around 200-220. If I build up my spare M42, I'll be aiming for significantly higher.
                  • ogbimmer
                    • Jul 2010
                    • 936
                    I like your stealth..
                    " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
                    • tg318is
                      • Jun 2008
                      • 2052
                      awwwyea! good luck with the build buddy!
                      Tim.
                      • Ryann
                        • 3350
                        FYI the only thing sketchy about the Spec kits are their Chinese bearings. Installed a Spec Stage III kit into a racer kid's '06 GTO, clutch was/is great, pilot bearing toasted after 2 weeks. Pulled apart and installed Timken piece and for good measure an OE t.o.b., all is golden @ 1 year+.
                        • Ian Bowers
                          • Apr 2008
                          • 1120
                          Originally posted by trackjunkie21
                          :giggle:
                          What're you giggling at? I'm not gonna be a sucker and gain an extra 2 cylinders, even though I've had the chance quite a few times. :p
                          Thanks! I'm not at huge risk for a ref ticket where I live, but I still want it to be discrete.
                          Thanks man!
                          I've heard people having issues with the Spec rivets as well, which is my main concern. I'll probably use the Euro 323 TOB I have here. Thanks for the heads up on the pilot bearing, though.
                          • DREWHALL
                            • Feb 2006
                            • 1207
                            I had a different issue with a Spec clutch, the splines in the friction disc itself. I had it in my GTI for maybe 2k miles. This was a STG 3 so supposedly good to 400 tq. The input shaft shredded the teeth out of the friction disc, shaft received no damage. My car had solid mounts, shrick cams, intake/full exhaust, tune, light flywheel, MAYBE 200 whp. I've heard several reports about the TO bearings begin junk, some making noise even when new.
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              Very nice! In for more pics
