Malik's 87 325is build (DAILY DRIFT E30)
  • Mr. Tasty
    • Jul 2011
    • 3421
    #196
    how do you take off the top parts of the trim, when you shadow lined? I wasn't too sure how they were attached.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • ROLLingKING
      • Apr 2011
      • 1169
      #197
      ummm theres clips by the back window. one on each side. slide that piece onto the back trim and pry it off. I THINK i used a flathead to slide it on the track and then u kinda fold it up and slide it out. Theres a seperation when u take off the clip so u should be able to figure it out from there. But its possible if u slide the clip by the back window back and go from there.
      m20 is plenty. im simply a drifter.
      build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
      • Mr. Tasty
        • Jul 2011
        • 3421
        #198
        alright thanks man
        (Daily Driver)
        KW V2 Coilovers
        • ROLLingKING
          • Apr 2011
          • 1169
          #199
          alright thanks man
          i hope that can help. actually now that im thinking about it I had to pop off the trim from by the side mirror. then it slid forward off the track pulling it from the front I think.
          as you can see i dont really remember...
          • ROLLingKING
            • Apr 2011
            • 1169
            #200
            Drifting and Building again
            So this has been a lot longer of a break than wanted bu I have began modifying and driving again so shit will be coming very soon.
            • MattAvino
              • Jan 2011
              • 2147
              #201
              Checkin in on the progress.
              I forget, were you interested in my motor?
              E30 buildy things
              http://www.r3vlimited.com/board/showthread.php?t=195286
              • ROLLingKING
                • Apr 2011
                • 1169
                #202
                What up matt. Right now there isnt enough money for motor work. Im being patient and am still working on suspension. Next update will be interesting. Im in the process of converting to e46 CA'S and coilovers. Ive been taking pics of everything just been to lazy to post and write descriptions.haha
                • ROLLingKING
                  • Apr 2011
                  • 1169
                  #203
                  e46 control arms and bottlecaps do not work well together. waiting for a front sway bar from a vert and ill update this sorry build
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    #204
                    Gutting the interior
                    I want to take as much weight out of the car as possible so i knew i would be gutting this car eventually. at least take my weight out of the car.
                    My sunroof also leaks onto my pas side carpet and sometimes onto my driver side carpet so it smelled. It had to go. Im also 6 foot 2 and cant fit anyone in the back of my car. Its not meant to be a carpooler co its now permanently a 2 seater. Every time i try and upload a pic its telling me upload failed. Fuck you interwebs!!
                    Here are my weight reductions so far
                    Trunk Sound Deadening = 50lbs
                    Spare Tire = 25lbs
                    Rear Seat, carpet, and trunk carpet = 40lbs
                    Front Carpet = 25lbs
                    In car sound deadening = 10lbs
                    • MattAvino
                      • Jan 2011
                      • 2147
                      #205
                      bump
                      E30 buildy things
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        #206
                        Progress update coming this weekend
                        Ive been busy and lazy about posting all my pictures and progress but this weekend ill update all build progress up to this point.
                        heres a little driving progress clip in the meantime.
                        • MattTHEe30GURU
                          • Jun 2012
                          • 388
                          #207
                          Love it haha
                          Originally posted by fronton
                          He must have been staring right the pole, all the way into it. Happens to me playing mariokart every time.
                          1982 F250 Built 351W-sold
                          1994 325i-sold
                          1987 325es-sold
                          1991 318i Slicktop- work in progress
                          • ROLLingKING
                            • Apr 2011
                            • 1169
                            #208
                            wish there was better lighting but whatever
                            • martin318ise30
                              • 128
                              #209
                              hey love the build, just wondering if there is a thread on the whole e46 control arms nd everything else you need , im in desperate need of some more angle but cant afford the wisefab kit. thanks in advance
                              • ROLLingKING
                                • Apr 2011
                                • 1169
                                #210
                                e46 control arms e46 controlarms
                                if u can try slr. if u want the e46 control arms trick its e36 outer tierods, e90 or e92 inner tierods, AKG e46 polly control arm bushing for e30 chassis, and then weld the e30m3 sway tab on the strut housing. then u will need camber plates to bring your shit back in. even then the best camber u will run will be negative 3.5, yes thats -3.5 degrees.lol
