As long as it's not sticking out (protruding) then I'd say you are fine to run it.
Andrew's 1989 325i Project
You have to spray them with brake clean to get the chemical coating off of them anyway before running them, so it's fine if you touch them.1985 M10b18. 70maybewhpoffury. Over engineered S50b30 murica BBQ swap in progress.
Originally posted by DEV0 E30You'd chugg this butt. I know you would. Ain't gotta' lie to kick it brostantinople.Comment
You should have gotten some caliper rebuild kits too while your doing the brakes. They arent much $$ and are easy to do. Just fyi
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
What, I am mistaken then. Ill order them I guess.
My car is late model so isnt that Girling?
Blunt shows this for front - http://www.blunttech.com/ShopByVehic...0Front&mode=PA
And rear - http://www.blunttech.com/ShopByVehic...20Rear&mode=PA
And it said two per car, but I guess that is wrongComment
