M20B29 w/ Triple Webers into my '71 2002
    • 37828
    #256
    Looking good Andrew!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • kid325e
      • Sep 2007
      • 6421
      #257
      Awesome, that engine build looks incredible. Keep it up!!
      Sent from my Nexus 4 using Tapatalk
      clutchCTRL!
      Move with a purpose.
      - 1991 325iX 4dr/5spd
      - 2000 323i AT
      2016 Mazda CX3 Sport AWD
      • SkiFree
        • Jun 2011
        • 2766
        #258
        Thanks again guys .... I'll finally have another two good size updates coming in the next week-ish!
        In the mean time .... some of you may have seen my best robot impression on the Clarion Builds 2002 project (I was NOT comfortable on camera, thank goodness for editing).
        Working on the Clarion project was interesting, the guy at Clarion who was setting things up behind the scenes was an old customer. I was really skeptical at first, thinking it was going to be another obnoxious stereo monster, but they kept things really nice and understated.
        The actual labor was primarily done down at Erik's shop (Coupe King), it's a crazy place if you haven't been there....
        (photo NOT mine, spot the m3 ... and the tii engines.)
        Why I bring this up now is that the car is finished and they're having a "press" shindig this coming week. Apparently Mr. Chris Forsberg will be putting the car through it's paces (and be giving ride-alongs). I'll try to take some pictures!
        ADAMS Autosport
        • abit
          • Jul 2011
          • 416
          #259
          this is good, keep it up! :up:
          http://instagram.com/mundieriss
          my 88' m20b30 HERE!
          • ForcedFirebird
            • Feb 2007
            • 8300
            #260
            Look at you! On TV!
            john@m20guru.com
            Links:
            • TrentW
              • 2815
              #261
              I really like the interior & exterior color choices they chose.
              And that shop is straight outta my dreams.
              • SkiFree
                • Jun 2011
                • 2766
                #262
                I promise I'm still working on this, have some substantial progress to post in a bit.
                but for some unsubstantial fun .... picked up these bits up this last weekend on Ebay!(they were miss-listed, came up purely by chance). Period Vilem B. Haan window levers and door handles.
                Neat story about Haan ... http://www.hemmings.com/hsx/stories/...feature16.html
                ADAMS Autosport
                • SkiFree
                  • Jun 2011
                  • 2766
                  #263
                  Alright, stuff has been happening!
                  Top of the list is pistons. As you will recall I did go through all the work on making nice offset dish pistons with Ross, but I always felt a bit off about it.
                  I want an engine that will be able to run 200k and that just wont happen with traditional forged pistons. I also wanted something that had the same piston to bore clearance as stock (eliminating piston slap and oil blow-by on startup) but not be brittle like a cast or 4032 alloy.
                  Fortunately last year Jeff sent me to SEMA and I got to talk to the guys at MahleMotorsport. They had a neat new-ish forging alloy called M142 that offered just the balance I wanted.
                  Fast forward through the development period and we ended up with a very tidy piston! Slipper skirts, cnc'd offset dish, graphal coated skirts, phosphate coated, no pin encroachment on the oil ring, powerpack rings, etc. I wrote a full .pdf on them if anyone would like more details.
                  They are speced for 84mm stroke, 85mm bore, 10:1 comp.
                  Right now I've got the block at the machinist to double check things before offering them publicly. ... and yes, the reason behind making these was completely selfish, I wanted them.
                  Fiddling around with the itb's I've found the Nuke fuel rail won't clear the linkage when running the Type 3 injectors. I have the option of using Type 2's (and the nuke rail) or the type 3's (and the stock rail).
                  Next up, seeing that the drivetrain is FINALLY almost finished I've started breaking down the car! The engine will be mocked up and new holes cut prior to starting the serious body work.
                  ADAMS Autosport
                  • AdOz
                    • Jun 2015
                    • 114
                    #264
                    I like Colorado it looks good with you keeping the oem look outside!
                    I'm looking forward to seeing how this turns out I considered the NA 6cyl route myself but had a change of heart!
                    TURB'02
                    INSTAGRAM
                    • SkiFree
                      • Jun 2011
                      • 2766
                      #265
                      Thanks, fortunately I got to ride/drive in a number of different types of 2002's before committing. M10's with sidedrafts, M10 turbo, two M42's, F20, and a couple M20's. The M20 swapped cars were just more fun for me. Different strokes, different folks.
                      Good luck on your project, looks like you are doing in right! I know there's another limey who is finishing up an M20 triple IDF build out your way.
                      ADAMS Autosport
                      • AdOz
                        • Jun 2015
                        • 114
                        #266
                        Yeah I know the one I think it looks good so far!
                        I'd have loved to have tried a few different options I was going to use an s50b32 but in honesty my main concern was having extra weight over the front of the car I'm hoping to mount everything back over and keep the weight down. As you said different purposes and they should both be really cool!
                        TURB'02
                        INSTAGRAM
                        • SkiFree
                          • Jun 2011
                          • 2766
                          #267
                          Yep, when one figures in an M10 with AC and the heavy battery up front its roughly the same weight as the M20 (sans power steering and AC). My driving experiences have backed this up.
                          What your seeing with the M42 is the heavier top end countered by a pretty tall overall engine height. I'm looking forward to seeing what you do with the engine placement, it's always great to see someones fresh take on something.
                          ADAMS Autosport
                          • AdOz
                            • Jun 2015
                            • 114
                            #268
                            I maybe should have done more research into the m20 as all I really did was look up weights and considered the weight being forward. But in honesty with the turbo and cooler and everything else il be at the same weight I bet. But I was hoping for something different and over 300hp. Maybe if I had the opportunity beforehand to try others I might have made a different decision however it's the first boosted car I've done so I think it's time to give it a go!
                            I don't need to worry about A/C in the UK my car never had it haha
                            TURB'02
                            INSTAGRAM
                            • SkiFree
                              • Jun 2011
                              • 2766
                              #269
                              No, with your 300hp goal it sounds like you've made the most logical decision.
                              Starting to get a plan on the interior!
                              ADAMS Autosport
                              • kid325e
                                • Sep 2007
                                • 6421
                                #270
                                ooooh, i'm liking where the interior is going.
                                clutchCTRL!
                                - 2000 323i AT
