My 318is DD so far...(Lots of pics)
  • Nick_S
    • Apr 2011
    • 3658
    So here’s my 91 318is I picked up and have working on for the last two months or so.
    After about a month searching for a decent E30, this one popped up on craigslist only 15 miles from me. It's a 91 318is, had some minor front end damage but mechanically mostly sound. Picked it up for $2k after talking the owner down a bit due to the cosmetic problems. A big selling point was it was in Germany till 96, then spent it's whole life until two years ago in the south and desert states. So there is literally NO RUST. Also already has fairly new Bilstein struts and H&R springs aswell as a UUC short shifter. The odometer doesn’t work as per usual buy rears 103,503 miles and from what the owner could tell me it stopped working about 3 years ago (his friend owned the car before him) so an educated guess is around 140K miles.
    The bad, the muffler wasn't connected so it was loud, really loud! Had a muffler shop weld on a Dynamax super turbo muffler. After that I could hear that both front wheel bearings were humming. Awesome. Didn't realize how easy they were or I wouldn't have had my buddy's shop put them in. After those minor hiccups it’s been geat.
    Here's the day I bought it. Not bad but looking pretty neglected and in need of some love.
    My Focus wasn't happy to relinquish it's garage space while the BMW got some work done, lol.
    Front bumper fell off and was run over apparently [IMG]file:///C:/Users/Nick/AppData/Local/Temp/msoclip1/01/clip_image001.gif[/IMG]
    Interior was decent. Sports seats with very minimal cracking and the rear cover was starting to come off at the sides, dash cracked, the usual.
    Over all though, the car was in good condition and I saw alot of potential in with a good detailing and alittle TLC. So here I'll show what I've been up to the last couple months to get it from the picture above, to this:
    First up was the interior. Pulled the seats and most of the center console.
    Yuck
    That's better
    Seats cleaned with Meguiars APC and then treated
    While cleaning I found a $.50 german coin under the console too.
    Next up on the interior was a set of Matt-B shift boots and a Momo shift knob.
    The stereo didn't work right at all, didn't turn on all the time. Speakers intermittently worked so I decided to pull the headunit and check the wiring...
    Yikes, what a mess.
    Rewired according to a wiring diagram found on here and sounds great now. Also while on my stereo I decided to add a bit of bass. Built a fairly basic box loosely based off the Luke box. No pics of it installed but it's a Rockford Fosgate 10" punch sub and amp.
    Punched out the ski pass panel
    Also relieved to find everything nice and clean under the carpet.
    Next up was the exterior. It was pretty tired, faded and dull. Some spots unfortunately were already worn through the paint nearly to primer. Anyways, it's not a show so on with the polishing.
    Products are my Griots Garage random orbital and 3M Perfect It compound and polish.
    The trunk was particularly water spotted so I opted to wet sand it.
    Little progress:
    My pad started out a nice tan..lol
    Shot of the completed quarter vs un touched door.
    Door vs fender
    With that done I started on the front end. Thankfully, the PO gave a pair replacement grills to fix it. Unfortunately, the car had euro grills so I had to ditch those. Oh well. I did my best to pull the fender back into place too. Not perfect but much better. The hood unfortunately I can't fix with my very minimal body work experience and was pretty badly faded and had a few rust spots so I'll eventually hunt one down.
    I opted to bomb the hood black. Was unsure at first but it's grown on me quite a bit, it hides the damage more too. Don't hate to much, it's not permanent, it needed resprayed anyways. Also did the kidneys aswell.
    After a month or so of searching I finally tracked down a front bumper cover for a reasonable price. Doucy on here hooked up it pretty good with some random trim bits aswell.
    I decided I wanted to keep this on a budget a bit so after some research on here I found Rustoleum Sunrise red is a very close match to Brilliantrot so I went the rattle can route with a few good coats of clear.
    After it dried I wet sanded with 2000 grit and hit it with 3M compound and polish and surprised myself a bit with the results.
    Used Dupli-color Trim Black paint on the bumper trim
    Not to shabby! Also re-did my valance.
    While keeping on a budget (also because my other car had to hit the shop , I needed turn signal lens and didn't want to $30-40 on new or used one. I cut up a cracked Tupperware container and made my own!
    Then tinted them so they're less obviously incredibly cheap
    Cleaned the turn signal housings
    Boom! Again, don't hate. These aren't permanent either.
    My fogs were in awful condition. Passenger side was cracked beyond use so I bought one off a user here. Pretty beat as well but I had plans.
    Started with this.
    Sanded with 80 grit to knock off most of the grit, then 100, then 180 then 250. Then used Dupli-color clean enamel to fill in the scratches. Wet sanded with 800 and cleared again. Repeated this till I had around 4 coats of clear then wet sanded with 800-> 1500 -> 2000 then buffed to another surprising finish.
    Here's a good comparison
    Figured the clear coat alone wouldn't hold up so I ordered in some Lamin-x
    Finished product. Not bad for $30 worth of product and an hour or two of time.
    Always liked lightly smoked tails so of course I decided to do mine. Was relieved again to find no rust what so ever on the rear end.
    Taped off
    Nightshaded
    Back on
    Wayyyyyy to dark for my liking or to be close to being legal. I don't want to get rear ended. Wetsanded with 2000grit and buffed out to a much better finish.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • Nick_S
    • Apr 2011
    • 3658
    Did some minor tuning up. All fluids, cleaned the intake and TB, replaced various hoses. Apparently the "mess under the intake" has already been taken care of. Replaced my valve cover gasket and painted the VC while off. Also found the PO had stripped out a few of the VC bolts [IMG]file:///C:/Users/Nick/AppData/Local/Temp/msoclip1/01/clip_image001.gif[/IMG]. It will be repaired but for the time it's not leaking so it's getting driven.
    Finished product
    Did my fuel filter too. Wonder how long this was in there?
    I should add I ride bikes. A lot of them. Mostly BMX which isn't bad to stuff in the car but taking my road bike, or mountain bike or my GF's bike sucks.
    This is getting old fast
    Scored a Thule rack off a friend of mine. Just waiting on some clips from Thule to mount the carriers. Stoked on this!
    That's where I'm at for now. All in all I've spent around $200 aside from the wheel bearings so I don't think I'm doing to bad. Future plans are first I need a lip. IS or Volvo, whichever I come across first for a decent deal. Various door seals, further maintenance and possibly new wheels. We'll see!
    Here's some "finished" current shots I took the other day with my DSLR.
    I’m no professional photographer so don’t be to harsh
    That’s all for now. Thanks for looking
    05 Honda Pilot
    24V swap thread
    • Shangsta
      • 1485
      Very nice progress soo far, definitely some amazing results for only spending 200
      :shock:
      • doucy2
        • Sep 2006
        • 1311
        looking great Nick, glad the bumper worked out, great to see this brought back to life. If you see any clean e30's with plastics up there give me a shout i'm in the market for one.
        • JubJub
          • Feb 2011
          • 256
          Kind of jealous of your detailing skills. You really brought that paint back to life.
          • Nick_S
            • Apr 2011
            • 3658
            Thanks! It helped too having most of the paints and detailing supplies already on hand.
            Will do, I'm on craigslist every morning. If I see one I'll shoot you a PM. Thanks again for the hookup!
            Ha thanks man. I've always been a bit of a fanatic detailer. I do a bit of work on the side for extra cash in the summer too. It will likely eventually get a respray once I feel like actually fixing the body dents and the fenders but for now this will suffice.
            Also forgot to add I did the mirrors in the same way I did bumper. Rattle can may not be as good as actual automotive paint but with the right prep and finish work it can look really good.
            05 Honda Pilot
            24V swap thread
            • A_Whelan
              • Jul 2010
              • 691
              Damn you went to work. Great stretch of that $200 and impressive results. Nice find and nice car!
              Any future plans besides the hood?
              r3vlimited Lanyard Group Buy!!!
              • Simon S
                • Oct 2004
                • 3758
                Very nice.
                -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                • drutt23
                  • Feb 2011
                  • 392
                  Nice work so far!! Keep it up!! I'll be paying attention to this one
                  1989 325i|1992 325i|And completely obsessed|:woowoo:
                  sigpic BMW. The Ultimate Driving Machine.
                  The Build...
                  • Nick_S
                    • Apr 2011
                    • 3658
                    Thanks I think I've done well myself.
                    -$70 front bumper and trim bits
                    -$30 for fog restoration and bulbs
                    -$25 shift boots
                    -$25ish for various paints
                    -$75 parts from Pelican
                    So maybe a little over $200 but still.
                    As stated, a lip is next. Front end looks incomplete to me. A Mark D chip is there too as it could use a bit more grunt. Maybe do an intake setup with heatshield aswell.
                    I'm getting some cheap Rage wheels but decent looking 15" 5 spokes off a friend for free I'd like to get some better tires on with less sidewall. And then I'll probably refinish my weaves and get some snow tires mounted on them.
                    Originally posted by Simon S
                    Very nice.
                    Thanks man. I actually read your entire thread a few times to get some ideas what to look for and maintenance that should be done.
                    I'll update whenever possible.
                    Thanks for compliments so far guys!
                    05 Honda Pilot
                    24V swap thread
                    • lambo
                      Captain Scene Points
                      • 10953
                      Wow. Those fogs turned out beautifully. The paint really turned around too. Nice work!
                      I kinda like the black hood lol
                      • selturk
                        • Dec 2008
                        • 1197
                        great job, looks pretty..
                          • 37833
                          God damn, I am very impressed with your cleanup work on this car. You made it look great.
                          Grover Beach, California
                          BimmerHeads.com
                          • Spiff325iS
                            • Jun 2004
                            • 1263
                            You cleaned the SH!T out of this car! I love how well single stage paint turns out after a good scrubbing- you did a fine job.
                            You'll love the M42- great motor, and not a pain in the ass to replace oil filters on.
                            The Red Dragon V.5 1991 318iS / 2013 F800GT
                            "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                            • bernzpeed
                              • 3917
                              what paint did you use to smoke the tail lights?
                              89 E30 S52
                              Transaction Feedback.
