2.8 strocker
  • downernsp
    • Mar 2008
    • 1931
    2.8 strocker
    Hey guys/girls I have decided to build a strocker for my vert 1988 325i. Here is a picture:
    The reason for build is I screw up the engine broke a valve.
    F
    In addition while doing some parts swaps, I discovered the previous owner intalled a 2.7 eta wtf! down grade. One of the reason why I am doing a 2.7 strocker. I already have block and an I head 885 casting. I will keep you all posted. Furthermore, I was thinking on doing a good write up on this build to make as a stiky if not already done.
    I will be doing eta block, I head, larger ss valves, low compressio pistons Ross, h beam 135mm IE rods, 19lb injectors, miller maf sensor,war chip, cold air intake, adjustable fuel pressure regulator, and a surprise. :D
  • F34R
    sLaughter
    • 12390
    Stroker* and what crankshaft are you going with? Only way you can get the 2.8 is getting a larger crankshaft. The ETA will keep you at a 2.7/i conversion.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • Killacortes
      • 1937
      low comp pistons? boost? yes?
      r3v does not fuck around. First you get banned, then they shoot you
      • Huff
        • 2488
        So.. What's a strocker? It sounds delicious! Like a desert of some kind..
        • Stephen
          Шлем ишака
          • 10774
          strock me
          • SkiFree
            • Jun 2011
            • 2766
            I think he probably knows that, otherwise he would have said..... 2.7 Strocker
            ADAMS Autosport
            • sweet6e30
              • Feb 2011
              • 531
              lolz " strock me"!!!
              my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
              • Asrial Dune
                • 70
                I hope your surprise is a turbo.
                • 325ix
                  • Aug 2009
                  • 7783
                  I vote for really big turbo for twin screw supercharger!
                  Oh, and thanks for the Mark D chip!
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    so are you doing an m52 crank with a bore or are you doing the eta crank with a bore? either will get you to a 2.8, but you will be happier with the larger crank and a bore.
                    since you are getting custom pistons, the only extra cost will be the crank and the spacer.
                    BTW the rods are cheaper from JEGS/SUMMIT than from IE
                    • downernsp
                      • Mar 2008
                      • 1931
                      Both Eta and M52 are 84 stroke fyi.
                      Originally posted by Stephen
                      strock me
                      You sir and to kind
                      I may don't know yet, I will keep you posted.
                      I am going to do the eta just cause I have it already and don't have to g around looking for M52 crank.
                      Thanks for the info, I will look.
                      • Luis325
                        • 3847
                        Cant wait to see it done Flavio!
                        1986 "C2 2.7 Alpina" Sedan
                        1987 325ic Black Vert
                        • Wh33lhop
                          • 11705
                          strock me
                          lolsig
                          paint sucks
                          • 20gmr
                            • 404
                            FYI no they are not both 84mm stroke. eta = 81 m52=84
                            Dave @ Bimmerbuddies
                            Contact Bimmerbuddies for all your Parts and service needs
                            M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
                            Bimmerbuddies LLC
                            717-388-1256
                            2971a Roundtop Rd, Middletown PA 17057
                            *Ask about discounts for R3V members*
                            • Stephen
                              Шлем ишака
                              • 10774
                              Originally posted by Wh33lhop
                              lolsig
                              :rofl: just noticed that
