Pantless Spencys zinno ETA fix-up thread. ~NOW RUNS YAY~
  • Cabriolet
    • 9620
    #451
    205/55-15 is the correct size
    Much wow
    I hate 4 doors
    • Danny
      • 14216
      #452
      Originally posted by agent
      Nearly three years, 28 pages and someone else doing the work just to get the car running... see you guys on page 43 for the wheel installation!
      :rofl:
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        #453
        To my defense, It was my first ever mechanical procedure, and I managed to take the head off, completely rebuild the head (didn't get it pressure checked fail)
        Then I put it all back together and it ran, but the head was cracked.
          • 37833
          #454
          Grover Beach, California
          BimmerHeads.com
          • golde30
            • 11464
            #455
            Or 225/50/15
            IG: @Baye30
            • lambo
              Captain Scene Points
              • 10953
              #456
              205/50 isn't bad for a low car, imo
              My friend has 205/50 on his ix weaves and it looks good
              • mbonanni
                • Sep 2011
                • 6236
                #457
                225/50 would be the best I think.
                Sent from my SPH-L710 using Tapatalk
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  #458
                  I like 205/50
                  • Vivek
                    attention whore/retard/bitch
                    • 6167
                    #459
                    Originally posted by Pantless Spency
                    I like 205/50
                    Don't. Steven has those, they look retarded. Your oil pan will be on the ground before it's low enough to actually look good. He has like two inches of clearance and an inch of wheel gap between the top of the tire and bottom of the front fender.
                    1992 Mauritiusblau Vert
                    2011 Alpinweiss 335is coupe
                    2002 540i/6 Black/Black
                    2003 GSX-R 750 (RIP)
                    • F34R
                      sLaughter
                      • 12376
                      #460
                      Lol I'll be getting full ground control coil overs, it's the only suspension set up I want! Haha.
                      Good man
                      Originally posted by golde30
                      That's too stiff on the front imo, 450/650 or 450/700 no rear sway are good setups that max out the off the shelf Koni SA
                      Agreed, that looks like a great daily with a fresh swap from Eric. 450/650 would be just dandy.
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • Pantless Spency
                        It's McRib time!!!
                        • Feb 2011
                        • 7283
                        #461
                        Stevens wheels are 15x9 tho.
                        So he is stretching the sidewall more making the profile even lower.
                        • Vivek
                          • 6167
                          #462
                          That's true, but either way the profile is just too short. And they're only 8.5 up front, another 1.5 inches isn't gonna lower the overall diameter all that much. 205/50/15 will be at least an inch too short whether it's on a 7j or 10j wheel.
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            #463
                            So you think 215s or 225's are more fitting?
                            • Vivek
                              • 6167
                              #464
                              Absolutely. It'd look 100x better. Just make sure whatever you get will fit at the height you want to be at. 7" et15 isn't all that aggressive so you should be fine on a 215, not quite sure about a 225 but meatier would look better.
                              • mbonanni
                                • Sep 2011
                                • 6236
                                #465
                                Do you plan to go pretty low spence?
