Kylie - S52 Swap 325e, now with moar Pictures!
  • TrentW
    • 2815
    #76
    Those seats look awesome with the suede. Is the rear staying original?
    • Rich@GTBPerformance
      • Jul 2011
      • 160
      #77
      Rear is getting the same treatment, didn't have time to snap pictures of the rear but Ill put some up once I'm down at the shop tomorrow.
      • samiam3356
        • Jul 2009
        • 1901
        #78
        Looking good mate!
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
          • Jul 2011
          • 160
          #79
          Kylie should be finishing up this week once we get headers and install the interior and exhaust!
          • Motorsports
            • Feb 2007
            • 2882
            #80
            What kind of headers you guys going with? interested in what you guys have in mind for the exhaust.
              • Jul 2011
              • 160
              #81
              Going Stromung for the exhaust. Not 100% on the headers yet
              Plus side, the headliner is done.
              • samiam3356
                • Jul 2009
                • 1901
                #82
                I love my Stromung exhaust. Not too loud and has a nice tone to it.
                $5 shipped?
                  • Jul 2011
                  • 160
                  #83
                  I am really looking forward to hearing the Stromung exhaust in person!
                    • Jul 2011
                    • 160
                    #84
                    Promise there will be pictures soon. Been in the shop the past two days with Levent and Joel, with Nico chipping in.
                    Interior is almost completely done. HVAC unit still needs fixing along with the Gauge cluster needs updating (5000rpm is not enough for an IS motor )
                    Exhaust was going in tonight.
                    Completed at the end of the first phase
                    M20 IS Motor and 5 speed Swap
                    M20 Maintenance Pack- Timing Belt, Plugs,
                    Thermostat, Water pump, All radiator hoses, Belts,
                    Valve Cover Gasket, Oil Pan Gasket(Paper),
                    Intake Manifold Gasket, Head Grommets, Breather
                    Hose, Oil Filter Housing Seal and Plug, Oil Filter,
                    20/50 Oil, Shifter Support Bushing, Exhaust
                    Manifold Gaskets, Spark Plugs
                    Getrag 260 Maintenance Pack – New Clutch, SS
                    Clutch Line, Selector Seal, Center Support, Guibo,
                    Shifter Foam, Output Shaft Seal, Selector Seal,
                    Clutch Pin, Fresh Redline Fluid
                    Head Gasket Kit
                    Head Bolts
                    Ireland Engineering Aluminum Light Flywheel
                    Powder Coated Manifold(wrinkle Black and Valve
                    Cover(Wrinkle Red GPS)
                    Z3 Short Shifter
                    Euro Bumper Set
                    Euro Valance
                    Ireland Engineering 22/19 Sway Kit
                    Black Rear Deck
                    Euro Bumper Set-Powder Coated Semi Gloss
                    Black - Repaint Trim
                    19lb Injectors (Flow Matched) and Mark D
                    Chip(New)
                    173 ECU w/ Mark D Chip installed
                    Misc Parts – HVAC Panel reinstalled
                    M3 Steering Rack
                    Brake Kits – Zimmerman Coated Rotors, UUC SS
                    Brake Lines, New Pads, Fresh Fluid
                    HR Sport Springs with Bilstein sports
                    E90 Drop Hats
                    New Battery
                    Stromung Exhaust
                    Rear Pipe Joint Section
                    Rogue Rear Shock Mounts
                    Rear Exhaust Shield
                    Wire Shield
                    New Flex Disc and Center Support
                    Cans of Undercoating – As needed for touch up
                    spots
                    OE New Tire Rod Assemblies with new Boots
                    Control Arm Bushings
                    Repair one boot on control arms – No need to
                    replace entire control arm.
                    Head liner Dyed
                    E brake Console reinstalled
                    OE Cat Mid Section
                    Exhaust Mounting Kit
                    Shifter Boot Kit – Black Leather
                    ZHP Shift Knob
                    Sunroof Crank OE
                    IS Side Skirts – New
                    Thinking about picking up a satellite radio for the car (maybe an alpine, to go with the alpine white)
                    2nd phase of the restoration will be the following (within the next year)
                    Full AlpineweissII painjob
                    Powdercoat/blackout chrome trim
                    Smoked Euro Elipsoids w/ HID headlamps
                    Euro Grill
                    Red tails (bye bye orange)
                    • dude8383
                      • Jan 2005
                      • 10387
                      #85
                      Wow. Thats a serious assortment of parts. Going to be LEGIT once its all said and done!!!
                      • zerokid5555
                        • 270
                        #86
                        Joel is the man!!
                        • iXguido
                          • Nov 2009
                          • 730
                          #87
                          Nice build list, pic would be nice to back it up ;) Keep up the good work!
                            • Jul 2011
                            • 160
                            #88
                            Been a while since the last update.
                            Officially the engine is fried at the moment. The first start up did not go to well. We are going to be pulling the engine and replacing it.
                            Looks like about 8 days away till we get a new motor to drop in. Almost pulled the trigger on a 24v setup but a little too far out of the budget at the moment, and I'd rather spend that on a paintjob.
                            I will be trying to get down to Guten soon, I have been away from Levent and Joel for a couple of weeks as I have sold my 335i and I am carless :(
                            Pictures soon. Taking requests! :)
                            • White325is
                              • Oct 2006
                              • 5947
                              #89
                              Do you need a engine? If so hit me up.
                                • Jul 2011
                                • 160
                                #90
                                Motor Problem solved.
                                It has more valves.... More to come soon
